Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 71
Thread: Engine 'hiccup' at 2750k
    Dec 15th, 2009
    Bay Area, CA
    2009 CC Sport, 2.0T, 6MT, Iron Grey, Tinted Windows, VW DG Sport Springs, APR Stg I, Carbonio Stg I
    03-02-2012 03:02 PM #1
    I have an 09 2.0T, MT with about 48k, APR stage I and Carbonio.
    I have had this annoying engine hiccup right at 2750k where the power delivery is not smooth. It is like a brief pause and drop in power as the engine revs, followed by a resumption of smooth power. It only happens at 2750k and is most noticeable in 2nd gear, though I can feel it in other gears as well. It only happens under partial throttle. With anything approaching heavy acceleration, it does not happen.
    It still happens in stock, but less noticeable.
    At 39k I had the intake manifold and all injectors and plugs replaced along with a carbon clean. I had the hiccup before that work was done and still have it afterwards. No CELs with this.
    Any ideas? Does anyone else have anything like this?
    2009 2.0T, 6MT, Iron Grey Metallic, Tinted Windows, Blue Tooth, APR Stage I, Carbonio Stage I, VW DG Sport Springs
    Audio setup: Focal 165 KRX2 in the front (crossovers removed) powered by Rockford Fosgate T400-4 (one channel per speaker); ARC Audio KAR 265 in the rear powered by Alpine PDX-4.100 (bridged); 8" 250W Powered Bazooka Sub; RF 360.2 Digital Signal Processor
  2. Member PirelliGolf's Avatar
    Dec 16th, 2005
    North of Toronto
    '12 GLI
    03-02-2012 08:06 PM #2
    I'm experiencing something similar although i've never noted the rpm's when it happens. I've had mine in for the intake manifold replacement twice. They've done some kind of wiring repair, twice. And on the last visit, they said there was no signal between the pedal and the TB so they performed a pin test and ended up replacing the ECM. They had the car for 3 days and the hiccup is still present. My car is stock, no chip or intake although they did try blaming the sprint booster even after it was removed.
  3. Member jspirate's Avatar
    Jan 15th, 2011
    Virginia
    2011 CC 6MT
    03-02-2012 08:51 PM #3
    I am aiming to get similar mileage. Well done my friend!
    Daily | Weekend | Project
  4. Junior Member
    Nov 18th, 2008
    Ann Arbor, MI
    2009 VW CC
    03-02-2012 10:50 PM #4
    Yes I have something like this. No cel
  5. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    03-03-2012 09:03 AM #5
    I get this once every blue moon
    But it's usually only one time during the drive & when I've got the cruise control set on a steady drive....it'll only hiccup/surge once, that's all
    Happened on the freeway most of the time around 75mph
    Took it to the dealer...no code, no issues they say
    2013 VW
    Dec 15th, 2009
    Bay Area, CA
    03-03-2012 11:25 PM #6
    Quote Originally Posted by snobrdrdan View Post
    Yes, that's the issue, with no code, the dealer is lost. I am considering taking it to a non-dealer mechanic who specializes in VWs and leave it chipped so you can really feel it.
  7. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    03-05-2012 08:41 AM #7
    Well he said they drove it and checked the readings when driving and it came back okay too
    2013 VW
    Dec 15th, 2009
    Bay Area, CA
    03-08-2012 05:38 PM #8
    Quote Originally Posted by PirelliGolf View Post
    Did any of the work you had done on your car ever lessen or temporarily stop the hiccup?
  9. Member PirelliGolf's Avatar
    Dec 16th, 2005
    North of Toronto
    '12 GLI
    03-08-2012 06:30 PM #9
    Quote Originally Posted by irongrey View Post
    Unfortunately not.
    Dec 15th, 2009
    Bay Area, CA
    03-08-2012 06:36 PM #10
    Unfortunately not.
    Interesting. What is the ECM?
    In any case, it eliminates more potential causes.
  11. Member PirelliGolf's Avatar
    Dec 16th, 2005
    North of Toronto
    '12 GLI
    03-08-2012 06:38 PM #11
    Engine Control Module (computer)
    Dec 15th, 2009
    Bay Area, CA
    03-12-2012 04:12 PM #12
    Ok, so it isn't the plugs, it isn't the injectors, it isn't the intake manifold, it isn't carbon build up, it isn't the ECU... so what is it??? What's left? Fuel pump? Valves? Vacuum system? Coils?
  13. Member
    Dec 15th, 2009
    Bay Area, CA
    04-26-2012 11:39 AM #13
    So I finally took my car to a shop recommended by a friend and they diagnosed the problem with my car immediately. I have been having misfires in 2 cylinders which, as they explained, were not bad enough for them to show up as CELs. They suspected bad coils, replaced them, and the problem, after like 25k is finally gone. The mechanic also said that VW has a recall out on these coils and will reimburse me for the work.
    So why the hell couldn't the dealership detect the misfires and why didn't they notify me about the recall? I always had the feeling with the dealership that they were paint by numbers. If the problem wasn't obvious, they didn't seem to have any ability to think for themselves and dig a little deeper.
    The mechanic explained about how often the coils will go out on a chipped car, and he recommended to change the oil at least every 5k on a chipped car. Finally, someone who seems to know what they are talking about.
  14. Member Brett_CC's Avatar
    Feb 23rd, 2010
    Virginia Beach, VA
    2010 VW CC
    04-26-2012 06:26 PM #14
    Thanks for posting this. This has been annoying the hell out of me for a while now. I experience the same thing. I will call my dealer and see if there is a recall out for these cylinder springs. Its completely gone now? How much did it cost you if you dont mind posting?
    APR Stage II, ATP Down Pipe, Magnaflow Catback Exhaust, K&N Typhoon Intake, A.W.E. Turbo Outlet Pipe, Steering Column mounted boost gage, Standard Suspension 32 way Coilovers, 19X8.5 Avante Guard Wheels, Clear Turns, R Line Tails, Euroswitch, Custom Shifter Stalk, Forge Short Shift Linkage, GC Body Kit, 35% Tint, beltronics hardwired radar detector.
  15. Member EC8CH's Avatar
    Mar 21st, 2012
    Fargo, ND
    2012 VW CC-R
    04-26-2012 06:36 PM #15
    Quote Originally Posted by Brett_CC View Post
    Pretty sure when he says "coils" he means coil packs which are not springs.
  16. Member
    Dec 15th, 2009
    Bay Area, CA
    04-26-2012 08:16 PM #16
    Yes, coil packs. They are $24 each and mechanic suggested I replace all of them at the same time. $100 for parts. $50 for labor.
    He also seemed fairly certain, given the recall, that VW would reimburse me for the parts.
  17. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    04-26-2012 08:17 PM #17
    Do you have the part number for the ones they used?
    There's an updated version (last letter of the part number tells you usually)...just wondering which ones they are using now
    2013 VW
  18. Member bordercitymadman's Avatar
    Jan 13th, 2011
    2010 VW CC Sport (MT)
    04-26-2012 09:37 PM #18
    ^ YEs! i agree with above, what is the latest Rev part# for the coils?
    I see some kits @ ecs tuning that have this one [07K 905 715F]
    2010 VW CC Sport (Manual) | Stage 1 APR Tune | St Coil-overs | VW 19" Concept Wheels | Neuspeed SSK
  19. Member
    Dec 15th, 2009
    Bay Area, CA
    04-27-2012 11:57 AM #19
    Been driving it for 3 days now and haven't felt the hiccup once.
    Still surprised I could have been having misfires and no CELs. I guess misfires are not either/or things, but rather occur on a spectrum.
  20. Member EC8CH's Avatar
    Mar 21st, 2012
    Fargo, ND
    2012 VW CC-R
    04-27-2012 12:14 PM #20
    On my 99 A4 I had a horrible engine stuttering problem that would sometimes even kill the engine. But there was never any CEL code and the problem would be gone if you simply restarted the engine. Dealer could never fix it or tell me what was wrong until I limped it over to them and made them drive it without shutting it off.
    First Tech that drove with me was like "yeah that's weird it doesn't trigger the CEL light" he had no clue what was wrong. He called over to the tech with Porsche badge on. He was like "seems like you MAF is bad". Plugs it into their diagnostic tool and says "yep, no way your airflow is that high at idle". I told him thanks and I bought a MAF sensor and installed it myself. That ended my almost 2 year struggle.
    It's amazing issues like these don't store codes for techs to check especially considering how lost they are without them.
  21. Member bordercitymadman's Avatar
    Jan 13th, 2011
    04-27-2012 09:16 PM #21
    I have this stupid hiccup happening right now, I can't get the dealer to determine anything. I just bought the coils and plugs I'll post updates tomorrow after i change them for those interested.
    Sent from my SPH-D710 using Tapatalk 2
  22. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    04-28-2012 05:21 AM #22
    Hmm....re-read the first post and I've sort of had this issue...but only a couple times and it's ONLY on the freeway it's happened for just 1 time during a freeway drive....around 75mph.
    Stock tune and since 2k miles....hasn't happened in a long time though.
    I thought it was my Carbonio intake
    Part numbers for the new coils???
    And do you "have to" change the spark plugs at the same time too? I only have 9k miles
    2013 VW
  23. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    04-28-2012 11:39 PM #23
    Bueller?
    It's either gonna be 07K905715F or 06H905115B or 06H905115A
    2013 VW
  24. Member bordercitymadman's Avatar
    Jan 13th, 2011
    04-29-2012 10:09 AM #24
    Bueller?
    This is what i thought also, but every place i called asked for my vin and gave me 06H905115A , that F version youhave there apparently it's for a different engine code than mine. So i ended up purchasing what the dealer recommended. Easy plug and play for both plugs and coils, basic hand tools, hickup gone. I'm still dead curious about the part numbers because i was shooting for the F rev.
  25. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    04-29-2012 02:28 PM #25
    Thanks man
    From what I've read 06H905115A is the newer one too according to a guy on golfmk6 that looked it up in ETKA:
    http://www.golfmk6.com/forums/showthread.php?t=36323
    2013 VW
  26. Member
    Dec 15th, 2009
    Bay Area, CA
    04-30-2012 02:21 PM #26
    Bueller?
    The new coil packs have the following P/N: 06H 905 115.
    Actually, that is the same number as the old ones too.
    Still running smooth.
  27. Member
    Dec 15th, 2009
    Bay Area, CA
    04-30-2012 02:23 PM #27
    Let us know if replacing the coil packs resolves your issue.
  28. 04-30-2012 03:23 PM #28
    If I ordered P/N 06E905115EKTN from ECS tuning to replace my coils in my 09 VW CC sport will those be sufficient? I have seen a lot of people posting about different part numbers. I ordered the red OE coils with plugs as well.
  29. Member bordercitymadman's Avatar
    Jan 13th, 2011
    04-30-2012 10:23 PM #29
    I don't see why they shouldn't work, i was simply curious as to what the latest rev is
  30. Member Brett_CC's Avatar
    Feb 23rd, 2010
    Virginia Beach, VA
    2010 VW CC
    05-01-2012 10:29 AM #30
    I called the dealer and there are recalls out for the ignition coils on several vw models but nothing for the CC. With an intake, tune, and full exhaust the "hiccup" is much more noticeable and if we have finally made some progress in the diagnosis, I will definitely spend the money to fix it if the dealer wont. There are so many threads on this problem especially in the 2.0 TSI forum.
    Please keep us updated if there are any changes or if the gripe comes back. Is this easy to do or are we better off taking it to a shop? Thanks man.
  31. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 05:48 PM #31
    I'm gonna post this up in another thread too, but....
    Check your coils!!!
    Remove the engine cover (pulls right off), and make sure they're seated all the way.
    Just push them all the way down until they stop.
    I only have 9k miles on my car and they were sitting 1/4-1/2" higher than they should've!!!
    2013 VW
  32. Member
    Dec 15th, 2009
    Bay Area, CA
    05-01-2012 07:21 PM #32
    Really? I have posted about this issue so many times and very few people have chimed in. I have seen a number of 'hesitate and surge' threads, but I think that is a different issue. Maybe not.
    My hiccup is still gone, but I have to say, in chipped mode, the torque delivery right at 2750rpms isn't the smoothest. Sometimes I still feel a little bump there where the power comes on suddenly (this is under heavy throttle) rather than smoothly. But it isn't the hiccup as there is no loss of power.
  33. Member
    Dec 15th, 2009
    Bay Area, CA
    05-09-2012 06:26 PM #33
    Ok, now I'm really upset. After one week of smooth driving, I felt the dreaded 'hiccup' which I now know to be a misfire. And then I felt it again and after two weeks, it is almost back to how it was.
    So by now I have replaced the intake manifold, plugs, ignition coils, injectors, and done a carbon clean and adjusted the throttle body, all to no avail.
    Even without getting an actual hiccup, I notice an ever so slight rough spot at 2700rpms (or so). With the tune, there is a big kick of power right there and the transition just ins't that smooth.
    Just to double check, I drove it in stock for a while and, as before, did detect the hiccup, though it is much less noticeable (in a way, that's a relief to me to know that it isn't just the tune, there's actually something wrong).
    But why can't anyone figure out what the problem is? I guess I did make some progress with the last place I took it too as they identified misfires. Will this ever get resolved????
  34. Junior Member zcar4me's Avatar
    May 16th, 2011
    Texas
    2011 CC Sport & 1992 300ZX
    05-09-2012 08:43 PM #34
    I've been experiencing the same issue pretty much since I bought the car. I have 25k on it now, and the problem is very intermittent, but it is there just like all of you have described.
    I checked the coil packs, and they pushed down slightly. I have not replaced them with the newest revision however.
    Curious if the ignition coils are just too weak for the TSI.
    Anyone read about the Okada coils?
  35. Member
    Dec 15th, 2009
    Bay Area, CA
    05-09-2012 08:48 PM #35
    Quote Originally Posted by zcar4me View Post
    I wonder that as well along with wondering if re-gapping the spark plugs (as some have mentioned) would help. But if this were the problem with tuned TSI's, I would think more people would have problems. It also doesn't explain the intermittent very slight lack of smoothness at 2700 rpms I feel in stock mode.
