VWVortex.com - Fuse box Diagram?
    Results 1 to 8 of 8
    Thread: Fuse box Diagram?
    1. n00b
      Feb 7th, 2012
      2008 Infiniti G35, 2002 Bugeye WRX, 2012 GF's Volkswagen GLI
      03-03-2012 04:51 AM #1
      Does anyone have a fuse box diagram for the 2012 GLI?
    2. Member CDN TDI's Avatar
      Jan 25th, 2012
      Canada
      2011 TDI Jetta 6MT, 1991 Turbo Diesel Jetta 5MT
      03-03-2012 04:16 PM #2
      Here you go. It's relevant for all MK VI Jettas. Both links are identical, but are mirrored in case one is down.
      2011 Jetta TDI Fuse 03.pdf
      Fuses on E-box, on left in Engine Compartment
      Fuse 1 - Not assigned
      Fuse 2 - 10/15A - Engine control unit
      Fuse 3 - 5A - Radiator fan control unit
      Fuse 4 - 5/10/15A - Lambda probe heater,
      Lambda probe 1 heater after
      catalytic converter
      Fuse 5 - 10A, 20A - Lambda probe heater1,
      catalytic converter,
      Fuel system diagnostic pump,
      Charge pressure control solenoid
      valve,
      Exhaust gas recirculation cooler
      change-over valve,
      Crankcase breather heater element,
      Vacuum pump for brakes
      Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
      Throttle valve module,
      Activated charcoal filter system
      solenoid valve 1,
      Continued coolant circulation pump,
      Auxiliary air heater heating element
      Fuse 7 - 20A, 5A - Ignition transformer,
      Fuel pressure regulating valve,
      Fuel metering valve
      Fuse 8 - 10A - Throttle valve module,
      solenoid valve 1
      Fuse 9 - 5A - Automatic glow period control unit,
      Electric fuel pump 2 relay,
      Fuel pump relay
      Fuse 10 - 5A - Speedometer sender,
      Brake light switch
      Fuse 11 - Not assigned
      Fuse 12 - 5A - Coolant circulation pump
      Fuse 13 - 5A - Water pump
      Fuse 14 - 5A - Engine control unit
      Fuse 15 - 30A - Voltage stabiliser
      Fuse 16 - 30A - ABS control unit
      Fuse 17 - 30A - Automatic gearbox control unit
      Fuse 18 - 20A - Automatic gearbox control unit
      Fuse 19 - 1A - Onboard supply control unit
      Fuse 20 - 30A - Onboard supply control unit (AW0)
      Automatic intermittent wash and
      wipe relay (AW1)
      Fuse 21 - 50A - Secondary air pump motor
      Fuse 22 - Not assigned
      Fuse 23 - 40A - ABS control unit
      Fuse 24 - 50A - Trailer detector control unit
      Fuse 25 - 50A - Terminal 15 voltage supply relay 2
      Fuse 26 - 60A - Automatic glow period control unit
      Fuse 27 - 60A - Radiator fan
      Fuse 28 - 40A - Onboard supply control unit (AW1)
      Fuse 29 - 40A - Onboard supply control unit (AW1)
      Fuse 30 - 50A - Terminal 75 voltage supply relay 1
      Fuse 31 - 30A - Amplifier
      Fuse 32 - Not assigned
      Fuse assignment - Interior Fuse Panel
      Fuse 1 - Not used
      Fuse 2 - 5A - Electronic steering column lock control module
      Fuse 3 - 10A - Instrument cluster control module
      Fuse 4 - Not used
      Fuse 5 - Not used
      Fuse 6 - 10A - Vehicle electrical system control module,
      Interior ceiling lights,
      Tail lights
      Fuse 7 - 5A - Fog lamp relay,
      Instrument panel and switch illumination dimmer switch,
      License plate lamps,
      Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
      Windshield washer pump
      Fuse 9 - 5A - Airbag control module
      Fuse 10 - 10A - Right steering column switch
      Fuse 11 - Not used
      Fuse 12 - Not used
      Fuse 13 - 5A - Automatic dimming interior rearview mirror,
      Light recognition sensor,
      Parking aid control module,
      Air quality sensor,
      High pressure sensor,
      Climatronic control unit,
      Tire pressure monitoring button,
      Back-up lamp switch,
      Left washer nozzle heater,
      Right washer nozzle heater,
      28-pin connector
      Fuse 14 4- 10A - Left steering column switch,
      ABS control module,
      Light switch,
      Airbag spiral spring/return spring with slip ring,
      Fuel pump control module,
      Data bus on board diagnostic interface
      Fuse 15 - 10A - 16-pin connector (diagnostic connector),
      Headlamp range control adjuster,
      Auxiliary heater operation relay,
      Mass airflow sensor,
      Positive crankcase ventilation heating element,
      Left front headlamp,
      Left headlamp beam adjustment motor,
      Right front headlamp,
      Right headlamp beam adjustment motor,
      Fuse 16 - 10A - Engine control module
      Fuse 17 - Not used
      Fuse 18 - 15A - Left front headlamp
      Fuse 19 - 15A - Right front headlamp
      Fuse 20 - 10A - Automatic transmission control module,
      Selector lever sensor system control module,
      Tiptronic switch,
      Ignition/starter switch
      Fuse 21 - Not used
      Fuse 22 - 10A - Ignition/starter switch,
      Converter box,
      Alarm horn,
      Interior monitoring sensor,
      Alarm horn relay,
      Dual tone horn relay
      Fuse 23 - 10A - Vehicle electrical system control module,
      Light switch,
      Rain/light recognition sensor,
      Compass magnetic field sensor,
      Fuse 24 - 10A - Vehicle electrical system control module,
      Access/start authorization control module
      Fuse 25 - 15A - Automatic transmission control module,
      Multifunction transmission range switch
      Fuse 26 - 15A - Brake system vacuum pump
      Fuse 27 - Not used
      Fuse 28 - 40A - Auxiliary heater operation relay
      Fuse 29 - 1A - Vehicle electrical system control module,
      Fuse 30 - 20A - Cigarette lighter,
      12 V socket,
      12 V socket 2,
      Blocking diode
      Fuse 31 - 30A - Light switch
      Fuse 32 - 20A - Light switch
      Fuse 33 - 40A - Heater/heat output switch,
      Fresh air blower relay,
      A/C control module,
      Fresh air blower switch
      Fuse 34 - 15A - Left front headlamp,
      Fuse 35 - 10A - Steering column electronics control module,
      Instrument cluster control module,
      Signal horn activation,
      Fuse 36 - 25A - Vehicle electrical system control module
      Fuse 37 - 15A - Left front headlamp DRL
      Fuse 38 - 15A - Right front headlamp DRL
      Fuse 39 - 15A - Low beam relay
      Fuse 40 - 15A - Towing recognition control module
      Fuse 41 - 15A - Towing recognition control module
      Fuse 42 - 20A - Towing recognition control module
      Fuse 43 - 30A - Front passenger door control module
      Fuse 44 - A25 - Rear window defogger relay,
      Fuse 45 - 30A - Driver door control module,
      Fuse 46 - 30A - Left rear door control module,
      Right rear door control module
      Fuse 47 - 15A - Fuel pump control module,
      Fuel pump relay,
      Fuel primer relay
      Fuse 48 - 20A - Vehicle electrical system control module,
      Fuse 49 - 20A - Climatronic control unit,
      A/C control module
      Fuse 50 - 30A - Front seat heating control module
      Fuse 51 - 30A - Power sunroof control module
      Fuse 52 - 20A - Dual tone horn relay
      Fuse 53 - 15A - Front seat heating control module
      Fuse 54 - 15A - Fog lamp relay
      Fuse 55 - 20A - Light switch,
      Fuse 56 - Not used
      Fuse 57 - 15A - Radio,
      Radio/navigation display unit control module
      Fuse 58 - 1A, 30A - Telephone transceiver
      DC/AC converter with socket, 12V-230V
      Fuse 59 - 30A - Amplifier
      Fuse 60 - 30A - Auxiliary heater control module
    3. Member grcarlo's Avatar
      Feb 25th, 2010
      2012 VW GLI
      07-12-2012 01:06 AM #3
      Not sure if that helps.. I went looking for the fuse diagram as well today and couldn't find it.. Anybody know where to find it in the 2012 GLI??
    4. Member
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      07-12-2012 07:41 AM #4
      Quote Originally Posted by CDN TDI View Post
      The 12 GLI has a bunch of changes.
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      07-12-2012 07:54 AM #5
    6. Junior Member
      Sep 22nd, 2012
      Fishkill, NY
      2010 GTi 4DR DSG
      09-25-2012 09:19 PM #6
      for some reason none of the links work for me. anyone else?
      2010 GTi 4dr DSG
      2011 Jetta
      2001 s4 stg2+
      2003 G35 Coupe
      2000 S2000 s/c
    7. 09-25-2012 10:23 PM #7
      Had this problem over the weekend. Penny fell in cigarette lighter and blew fuse. No diagram meant pull til I found it and I put the parking/nuetral one in wrong spot thankfully it was the only on I had pulled on that side. But yes I would love for someone to post up one for 12 GLI
      Jul 23rd, 2007
      Tulsa, OK
      2012 GLI Manual
      05-30-2016 10:38 AM #8
      Back from the dead.... I wish this document had the relays labeled. I need to find the starter relay
