#37
#38
Never ran the chip its still in the piece of foam it was shipped in
#39
The Professor
Melbourne, FL
92 Corrado OBD2 ABA Powered by MS3Pro
M & L EFI Performance
#40
This isn't legal in all contries in the world you know
here in norway we can't use standalone like MS (among others) but using the stock ECU is no problem, even if you change the parameters within the software (undetectable)
so. some of us risks loosing our license plates and drivers license. and risk getting a big-ass ticket
#41
The Professor
Melbourne, FL
#42
tell that to the ****ed up norwegian gouvernment :/ i wish it was this easy, i've actually been thinkin of modding the MS2 v3 unit i've got into a DF1 casing, need to lengthen the casing a bit, but its doable. making it hard to see that its been tampered with
and they won't open the ecu
#43
if someone needs SNS chips you can contact me. I know how to get them
#44
#45
what software and hardware do you use to burn these maps onto blank chips?
want to get something like that
any recomendations for this:
KR engine
s2 pistons/rods
k24 7200 turbo
s3 intake with injectors(393 ccl)
3bar fpr
what chip should i use?
#46
Well tonight i rebuilded my 16V back to kkk turbo again. (the turbonetics was to big....)
Audi S2 exhaust man (mod)
Audi S2 inlet man (mod)
KKK K24 7000 turbo, boost 1,5-1,6bar
3,5 bar fuel pressure regualtor
440ccm bosch injectors
S2 pistons
H rods
G60 head gasket
Digifant 1 ECU with 200kpa sensor. (also got a digi 1 ecu with 250kpa)
I have new bosch O2 lambda sensor - narrow band to the ECU.
Innovate LC-1 wide band - to LC1 db blue instrument.
-Have set the timing to 7-7,5 (with the blue temp sensor off, and around 2250-2500rpm)
Someone out there who have a good map to this set up?
With todays map, i've got some pinging/knocking (I also see it on the knocksense light)
#47
Just get a custom chip from sns, i think John's email i Jwatts@snstuning.com or jdwatts@snstuning.com![]()
#48
