VWVortex.com - questions for going withe webber dcoe 45's
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 31
    Thread: questions for going withe webber dcoe 45's
    1. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      98 vw gti, 1984 16v rabbit
      03-03-2012 08:54 PM #1
      my mk1 rabbit is swapped with a 2.0 16v from a 93 passat. im about to put on my new set of webber 45's what kind of work do i need done to the head to make it run like the monster i want it to? expense is not an issue at this point. all the work that will be done includes" entire gasket and seal set for block and head new water pump and low temp thermostat, high compression pistons and arp under cut head studs, venair silicone hose kit and shocktherapy wires set. swapping out the 4k tranny for an 020." basically the entire power house will be new. im trying to get all of this done by sowo and any knowledge would be much appreciated.
    2. 03-03-2012 11:41 PM #2
      #1 a 4K is an 020. 4k is the trans code
      #2 if cost is not an issue, dump about $10,000 into the head in porting, cams and valvetrain work.
      Up and Atom!
    3. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      03-07-2012 08:09 AM #3
      Is that even possible? 10k into a 16v head. cams port and polish retainers hd springs. thats maybe 3k done right.
    4. 03-07-2012 05:19 PM #4
      keep dreaming. a good, flow matched, port alone will be close to 3-4k. no hardware included.
      by the time you factor in all the hardware, there is at least another 2-3k. (cams, oversized valves, etc..)
      Fueling and induction, An extrudabody 16v ITB set-up is 2k, without injectors.
      now that we've gone through that, what is your REAL budget.
      Up and Atom!
    5. Member ncbrock's Avatar
      Sep 28th, 2010
      Raleigh, NC
      E30, Volvo 245
      03-07-2012 06:15 PM #5
      What you will need and lots of it: time, its as simple as that.
      Unless you bought your carbs from a known working setup your not going to make it to sowo unless you spend everyday working on it all day. I had everything ready all parts in and everything, planning on having it running in 2 weeks, which turned into 3 months and is still not running and I finally gave up and am turning it over to a shop. I started on Dec. 21st and I don't even think ill make it to sowo
    6. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      03-08-2012 12:45 AM #6
      ive already got my cams ti retainers and hd springs, i went with a tt set of 268 272. i have all the linkage and everything needed for the carbs setup. all i really need to do is send the head out "because there is not one machine shop in the area that can do it" and get the valves done port and polish. i just dont know if i want to send it all the way to oregon to get it done.
    7. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      03-08-2012 12:46 AM #7
      my budget is around 6k but i would like some of that to go to reupholstery and paint. seats are going to cost 12-1500 and paint somewhere around 1k
      Apr 27th, 2003
      oregon city, oregon
      79 rabbit
      03-08-2012 09:16 AM #8
      Quote Originally Posted by ncbrock View Post
      thats too bad you werent able to get it running right. one of the reasons i mentioned to give me a call was to go over all of the things that you are now dealing with so you could eliminate alot of waisted time. anyway, i can understand wanting to just get it running finally. i can almost guarantee however, that you will still need to make some jetting changes after getting it back. it seems that the main problem is it running lean at times so make sure to have all this checked. timing ( too much advance ). high mileage used carbs that leak at the throttle shaft bushings. an air leak with the soft mounts or the intake at the head. too little fuel pressure. the jetting in the carbs is wrong and if it seems to run fine but your afr #s are still lean, you may have an air leak in the exhaust before the sensor, and or the sensor isnt calibrated correctly or bad. anyway, let us know when you get her back.
    9. Member littlebill86's Avatar
      Apr 13th, 2008
      lancaster, ca
      2003 GTI 1.8t
      03-08-2012 01:37 PM #9
      send your head to jared at scch, he has been racing a ribbit long enough to know your needs. awesome pricing as well.
    10. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      03-08-2012 04:38 PM #10
      do you have a phone number or a link?
    11. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      03-30-2012 01:37 AM #11
      ok so i got my 6al blaster coil inline fuel pump 2.3-3 psi. and ordered the light weight flywheel and clutch kit from bfi for my new 020 CHE. and a mk1 rad. i want to run as clean and simple a set up as possible. i want nothing really showing in my engine bay. im going to run what wires i do need through the drivers fender using a piece of conduit. but im still kinda lost on what wiring i do need. do i need to keep the jet tronics stuff or can i run off the msd by its self. this is my first rabbit and my first carb setup. i refuse to cut corners and want it to be right the first time. any help advice criticism (constructive that is) would be greatly appreciated. im trying to learn this and more then willing.
    12. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      03-30-2012 01:41 AM #12
      oh and i tried to get in contact with scch and got one response but nothing after i was interested in the stage 3 16v head but never got the chance to even start. so im reupholstering the seats instead
    13. 04-02-2012 08:25 PM #13
      Have you had the carbs jetted and synced yet?
      also, you do not need the OEM wiring.
      Up and Atom!
    14. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:42 PM #14
      nope i havent even tried to start it yet im waiting on my clutch and flywheel and rad. the carbs are brand new out of the box.
    15. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:44 PM #15
      Sent from my DROID BIONIC using Tapatalk
    16. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:46 PM #16
      went red. replacing timing belt pullies and oil pan so the over spray doesnt bother me. the cams are 260 270 the valve cover was just finished to day pic will be up in a min
    17. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:46 PM #17
    18. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:51 PM #18
    19. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:52 PM #19
      new tranny old tranny and all the cis stuff thats going by by
    20. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 10:59 PM #20
      all of the wiring in the right is gone. i should have done a better build thread maybe put the pics in chronological order but oh well you guys will get it when its done.
    21. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-02-2012 11:00 PM #21
    22. Member
      Apr 27th, 2003
      oregon city, oregon
      79 rabbit
      04-03-2012 09:07 AM #22
      make sure to check the float measurements before mounting the carbs. allthough new, when i got my first pair of 45s, 1 carb was good but the other was off.
    23. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-03-2012 09:58 PM #23
      Just got in my 525mm rad
    24. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      04-03-2012 10:44 PM #24
      so when i remove all the stock wiring how do i run all my accesories head lights blinkers horn interior lighting stero without having to run a ton of seperate power wires? i hate wiring im retarded on this ****
    25. 04-04-2012 08:00 PM #25
      you only remove the engine harness.
      Up and Atom!
