Results 1 to 18 of 18
Thread: 1.8T Eaton M62 Supercharger kit
  1. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-04-2012 09:00 AM #1
    Kit utilizes Cobalt/Redline Eaton M62 LSJ supercharger (not included). Supercharger bracket designed to also mount alternator and accommodates two eccentric belt tensioners - its a very robust weldment. This kit is in a Corrado that has been driven daily for two years since its fabrication and ran using an untuned Emerald stand-alone ECU with a turbo manifold modified to serve as a header.
    Although I never got around to getting a proper 4-2-1 or 4-1 header then a dyno tune it works very well and one of the reasons I didn’t tune the setup yet. As you would expect with a supercharger the exceleration is impressive and with a proper header, cam and tune even more-so. Selling because I’m starting another similar project. $600 I accept paypal.
    Kit includes:
    1. supercharger bracket (MIG welded by professional)
    2. Intake manifold inlet hose connection plate
    3. 2 eccentric belt tensioners,
    4. intercooler to intake manifold 2-1/2 hose adapter plate (CAD drawn then professionally machined)
    5. VR6 throttle body adapter plate to mount VR6 throttle body to inlet side of supercharger (CAD drawn then professionally machined)
    6. VR6 throttle body
    7. throttle body cable bracket
    8. 3 silicone couplers (3.00”, 3.00” to 2.50” and 2.50”)
    If you plan to put this in a A2 chassis you may need to fit the straight 1993 Passat lower radiator support to the beam that holds the front engine mount (see picture). I will also include a modified a VR6 airbox with K&N filter and 3.00" 90 degree silicon coupler. This will allow cooler air in from behind the front bumper – perfect if you already relocated your battery to the trunk or hatch of your car and drive in hot climates.
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
  2. 03-04-2012 09:16 PM #2
    was this a twin charged 1.8t?
  3. Member dtcaward's Avatar
    May 10th, 2009
    maryland
    01 GTI VR6, 2010 GTI, jetta RIP
    03-04-2012 11:44 PM #3
    looks bad as$
  4. Member 05GTI6677's Avatar
    Aug 21st, 2010
    Arizona/California
    2005 MK4 GTI 1.8t (rip) 86 Cabrio
    03-05-2012 12:51 AM #4
    Does anyone have a video of this thing?!
  5. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-05-2012 06:29 AM #5
    Sure.
  6. Member 05GTI6677's Avatar
    Aug 21st, 2010
    Arizona/California
    03-05-2012 09:41 AM #6
    The video doesn't work
  7. Member ArcticFox's Avatar
    Nov 4th, 2005
    Rockaway, NJ
    03-05-2012 02:42 PM #7
    Too bad it doesn't fit an longitudinal 1.8t. Awesome looking project though.
  8. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-05-2012 11:23 PM #8
    Quote Originally Posted by ArcticFox View Post
    Could be a future project
  9. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-05-2012 11:26 PM #9
    Quote Originally Posted by adema69 View Post
    No but I did think about it.
  10. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-05-2012 11:28 PM #10
    Quote Originally Posted by 05GTI6677 View Post
    Sorry, I don't know what's up with that. I will look into it.
  11. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-05-2012 11:39 PM #11
    Quote Originally Posted by dtcaward View Post
    looks bad as$
    Thanks. I really should have got a 4-1 header or at least a NA 20v header and tuned it but I became busy and comfortable with it the way it was.
  12. Member cubanvr6jetta's Avatar
    Oct 22nd, 2009
    North bergen NJ 07047
    00 new beetle gl
    03-07-2012 11:25 AM #12
    is this for sale trade or what i dont see any price in here
  13. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-08-2012 05:00 AM #13
    Quote Originally Posted by cubanvr6jetta View Post
    It is for sale.
  14. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    03-26-2012 07:24 PM #14
    Video is now up.
  15. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    04-02-2012 06:12 PM #15
    how much?
  16. Member ArcticFox's Avatar
    Nov 4th, 2005
    Rockaway, NJ
    04-02-2012 08:52 PM #16
    Quote Originally Posted by mechd View Post
    Let me know how if you do.
  17. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    04-14-2012 09:44 PM #17
    $900
    Quote Originally Posted by Pat @ Pitt Soundworks View Post
    how much?
  18. Semi-n00b
    Jan 8th, 2007
    N.J.
    Corrado
    05-06-2012 02:31 PM #18
