Results 1 to 4 of 4
Thread: Where to buy Caliper Carrier Pins?
  1. Member 2a2gtis's Avatar
    Jan 30th, 2008
    Cuyahoga Falls, Ohio
    MKII gti 8v (driver) MKII gti w/rado vr, B4 Passat VR
    03-04-2012 09:58 AM #1
    There for a 1995 Audi 90 front brakes, the dual piston calipers. The dealer wants $27 ... a side. Advance auto wants basically the same (Wagner brand) And yes Ive googled it. They seem kind of hard to find at a reasonable price.
    Are any other Audi models using the same pins?
    Anybody recommend a site that I missed?
    Thanks - Chris
  2. Member 2a2gtis's Avatar
    Jan 30th, 2008
    03-04-2012 11:58 AM #2
    I kept searching... and found them at Autozone:
    https://www.autozone.com/autozone/pa...isOverlay=true
    They look like the correct part and a good price.
    Ill post again if they're the wrong part.
  3. Member 2a2gtis's Avatar
    Jan 30th, 2008
    03-19-2012 04:35 PM #3
    Yep.. they're the wrong part. Same with Advance.
  4. Member jetta5000's Avatar
    Jul 17th, 2006
    gettysburg pa
    98 a4 2.8 avant, 93 90cs quattro
    03-22-2012 01:36 AM #4
    see if you can find a u-pull-it junkyard nearby. something like that should be pretty simple to dig up.
    if i remember correctly the earlier 5000's, 100's and 200's share the same front brake setup as the 90's.
