VWVortex.com - VRT 24v aftermarket oil cooler for the track
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 46
    Thread: VRT 24v aftermarket oil cooler for the track
    1. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-04-2012 02:07 PM #1
      During the winter I've been working on the VRT - getting it ready for my 2nd track season with this ride. Last season I saw really high oil temps - the highest I saw was 305F after about 5 laps during a time attack session in 35 C heat.
      Recently I noticed that I have a low oil pressure problem. After dropping the pan / pump I found out that the relief valve is shot... and while I was there I took off the oil filter housing + cooler to check it out and I need a new cooler too.... so now I'm thinking about upgrading since it's all off anyway.
      I do occasionally have to use the VRT in the winter and sometimes as a daily, so I'm concerned about keeping the oil too cool - plus I have a big eurojet race fmic so I'm not too sure where I would mount it so it would work properly.
      May 12th, 2010
      95 VrT, 04 R32
      03-04-2012 02:41 PM #2
      There is zero issue with oil getting too cold in winter if you use a thermo sandwich plate. Oil won't flow though the cooler unless hot. I run a mocal in front of my rad and oil temps are under control.. never over 220 on hot days in traffic.
    3. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-04-2012 04:17 PM #3
      ^ thanks
      anyone have ideas of where I could mount the oil cooler so it gets good air flow? I'm running a eurojet race fmic so there's not a lot of room in front.
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      03-05-2012 07:12 AM #4
      Im running a 25 Mocal with thermo sandwich plate.
      Ive fitted my cooler in my front left scoop..neat fit..
      Steve
    5. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, Mk4 VR, A3 VR, B6 3.6 4Motion, B5 1.8T
      03-05-2012 01:22 PM #5
      Quote Originally Posted by sTT eV6 View Post
      Mine is similar but on the other side (ie US driver's side wheel well). Your appears to be in the front right, ie US pass side.
      "OP sounds like a MKIV guy"
    6. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-05-2012 01:54 PM #6
      Quote Originally Posted by V-dubbulyuh View Post
      I think that's where I'm gonna have to put it - cuz my surge tank is taking up space on the pass side frame rail. Although I think I can only fit a 19 row in the space I have on the driver's side.... will that be sufficient for a VR?
      v-dubbulyuh did u fit a 25 row on the driver's side? how exactly did you mount it?
      May 12th, 2010
      95 VrT, 04 R32
      03-05-2012 03:22 PM #7
      Probably not an option for you but here's mine
      [IMG][/IMG]
      [IMG][/IMG]
    8. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      03-05-2012 06:48 PM #8
      Quote Originally Posted by 24vGTiVR6 View Post
      Mine is a 19 Row and it is mounted identical to the one pictured there in the wheel well. The cooler sits vertical and spans the frame rail above and below. It is more than sufficient for a VR.
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      03-05-2012 06:52 PM #9
      Other side has the secondary water rad installed and I have a charge cooler rad I front of the water rad, so mine is the only option available for the 25 row
      Steve
    10. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-06-2012 08:19 AM #10
      thanks everyone
      I'm gonna go hunt the wrecking yards for a 19 row setrab today and work on fitting it on the drivers side. if anyone wants pics after let me kno.
    11. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      03-06-2012 08:52 AM #11
      Steve
      Steve
      What is confusing/misleading is that despite you stating that it is in the left scoop your pics show right. What am I missing here?
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      03-06-2012 02:40 PM #12
      My oil cooler is in the left scoop as you look at the front of the TT.
      Steve
    13. Member
      Nov 19th, 2008
      Atlanta-Chicago
      92 verde rado gernade(dd),90Q 20v, red rado 24v build
      03-06-2012 02:59 PM #13
      thanks everyone
      What cars come with 19 row oil cooler? I know Volvo has 13 row, and Saab 9000 has 16 row.
    14. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-06-2012 09:15 PM #14
      Quote Originally Posted by chc-rado View Post
      good question, I couldn't find a 19 row in the local wrecking yards
      I already have fittings + -10 AN braided line so I just need a thermo sandwich plate adapter + oil cooler.... which I'll probably just end up buying new.
    15. Member
      Nov 19th, 2008
      Atlanta-Chicago
      03-08-2012 08:56 PM #15
      Check out bat.inc they have load of mocal oil coolers and adapters too. 034 motorsports and BBM has them too. I like bat.Inc
    16. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-13-2012 08:03 PM #16
      I ended up grabbing a second hand Mishimoto sandwich plate & a 19 row.
      I want to delete the stock cooler - but the stock cap bolt is too long, so I'm gonna get a machine shop to make an aluminum spacer for me to get the sandwich plate adapter to fit with the stock cap
      Also I've got a question about the coolant lines that went to the OEM oil cooler - can I just route the coolant hose coming from the crack pipe down to the nipple on the block?
    17. Moderator DannyLo's Avatar
      Aug 2nd, 2006
      Not Vortex Approved
      03-13-2012 08:06 PM #17
      Think you could post up as you install it with some, maybe with some pictures if you could?
      It'd be nice to be able to get this thread added to the FAQ in the 24v forum, because I know everyone always asks about oil coolers, especially VRTs and it'd be nice to have something in the archives.
      I've been considering an external cooler for my 24v VRT myself, but mounting location and all the details are still a blur to me
    18. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-13-2012 08:19 PM #18
      Quote Originally Posted by Lieutenant Dan View Post
      sure.... I always take pics as I go so once I have it sorted out I can update this thread
    19. Member
      May 12th, 2010
      95 VrT, 04 R32
      03-13-2012 08:43 PM #19
      Not sure if the 24 valve is like the 12 but the stem of the cap should just be a pipe nipple cross-drilled. iirc the BBM kit came with both nipple lengths. see if your stem can unscrew like others. They can look molded together but aren't. If it it's threaded just make a shorter nipple.
    20. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-13-2012 08:53 PM #20
      Quote Originally Posted by vergessen wir es View Post
      doesn't look like it can come apart - it's all one piece and it's attached to the cap. And yah I was thinking I could just cut to the right length and use a die to make some threads. That might be easier.
    21. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-14-2012 11:06 AM #21
      bump-
      can I connect the coolant hose from the crack pipe to the nipple on the block to re-route? I figure that's the easiest / cleanest way to sort out the extra coolant lines for now until I can cap them properly.
    22. Member
      May 12th, 2010
      95 VrT, 04 R32
      03-14-2012 12:25 PM #22
      I know you want to delete the stock one but you could just run it along with the external and be done. That's how mine is set up fwiw. But yeah you can loop it. That's all the stock cooler is; a loop.
    23. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      03-14-2012 01:09 PM #23
      The Mocal ones come with long/short nipples. You can get the short ones off of really early production 8v that had no stock oil cooler.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
    24. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      03-19-2012 05:06 PM #24
      thanks everyone for the info / assistance
      I want to weld some brackets and mount the cooler today and I wanted to know about orientation..... does it matter? The only way I can get the -AN fittings to fit would be if the cooler was upside-down with the bungs facing down.
    25. Member
      May 12th, 2010
      95 VrT, 04 R32
      03-19-2012 05:12 PM #25
      They work the same in any orientation. Imho ignore warnings about air pockets.
