Page 2 of 2 FirstFirst 1 2
Results 36 to 46 of 46
Thread: VRT 24v aftermarket oil cooler for the track
  1. 04-06-2012 02:57 PM #36
    Quote Originally Posted by 24vGTiVR6 View Post
    the mounting bracket:
    I have made a similar bracket for my Corrado that sits under the driver side fender where the horns bolt to.
  2. Member Snitches Get Stitches's Avatar
    Jul 21st, 2007
    Southern NJ
    2002 Hybrid VR6T Jetta, 1997 Lifted Subie Outback
    04-08-2012 08:27 PM #37
    here is mine on an mkiv...passenger side. It is a 16 row mocal with a thermostatic plate replacing the stock cooler. I will let you know how it works.
  3. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-18-2012 09:54 PM #38
  4. Member pubahs's Avatar
    Apr 1st, 2002
    NYC & Niagara Falls
    95 VR6 Turbo
    04-21-2012 08:02 PM #39
    I like the brackets and use of that space on the passenger side. Just got rid of my CAI/MAF housing and filter that sat over there, think ill install my oil cooler setup there too
    Anyone else who made brackets, post up some more pics
    chris
    AD 3 AD Labs ..... LugTronic
    autocrat.
  5. Member mike minnillo's Avatar
    Sep 23rd, 2007
    Colorado Springs, CO
    MKIV 12v VRT GTI, B5 Passat Wagon
    04-22-2012 04:51 PM #40
    Very good thread. I'm getting ready to do an external on my 12vT, and had a question about the sandwich plates. I picked up a non thermostat one a while ago and was wondering if ill have any issues with oil no warming up or anything like that. Or should I just junk it and get one with a thermostat?
    Jack of all trades.
  6. Member 24vGTiVR6's Avatar
    Sep 13th, 2010
    24v VRT
    04-24-2012 08:02 PM #41
    If it's gonna be driven on the street at all I'd probably lean more towards a thermostatically controlled sandwich plate
    Oct 26th, 2010
    Little ol UK
    05 MK1 3.3 TT V6T
    04-26-2012 09:13 AM #42
  8. 04-28-2012 03:14 AM #43
    Anyone running an external oil cooler on a mk3 24vT with 02M trans? I'm building mine at the minute and there doesn't seem to be enough room for adapter on filter housing due to front engine mount...
    Pics from mock up back in December;
  9. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-28-2012 08:19 AM #44
    It will work no problem you just cant run the stock cooler.
    -Paul
  10. Member 24vGTiVR6's Avatar
    Sep 13th, 2010
    24v VRT
    04-28-2012 09:16 AM #45
    get the mocal VR6 thermo plate and u should have enough room (without the stock cooler)
    I'm thinking in your situation to tilt the sandwich plate towards the front of the car, and use 2 90 deg fittings to run to the left / right
    like snitches has above in the pics ^^^^
  11. 04-29-2012 05:07 AM #46
    Ok cool. Thanks guys. This thread just got me wondering as I haven't actually tried to fit yet.
    I'll have to block off that nipple in the block to that feeds coolant to the OE cooler too then. I'm not running an aux pump either.
