Page 1 of 2 1 2 LastLast
Results 1 to 35 of 37
Thread: FS: 2003 20th Anniversary GTI (BMP) 550whp
  1. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    1998 vw passat 1.8t & 2003 vw gti 20th anniv BT
    03-04-2012 11:03 PM #1
    This car is in excellent condition and currently sitting with my tuner in OH. There have been no short cuts taken when building this 20th and it's SOLID! The parts, pics and dyno sheet are all listed below.
    I WILL NOT DELIVER, YOU MUST PICK IT UP OR ARRANGE FOR IT TO BE PICKED UP.
    NOT INTERESTED IN TRADES
    Asking: $15,400/OBO. The build alone cost me just over 18k, this is a bargain so please only serious inquiries. Please send all offers and inquiries to: shotofgmplease@gmail.com
    This car has under 70k on the body and not even 3k on the engine.
    - Clear bra extra extension covering: half of hood, front bumper, half of quarter panels and mirrors
    - Koni coilovers
    - APR Catback exhaust
    - BBS CH Wheels with falkens
    - Shaved: hood, front bumper (emblem & rub strip markers), repeaters
    - Nuespeed front and rear sways & front strut
    - 42DD Stewart Warners guages (oil pressure, EGT & 40psi Boost)
    - Dieselgeek front skid plate
    - R/S/S/R Hella Tail lights
    - dual rear fog
    - OEM HID's
    - Hella Micro DE Fogs with 3000k HID's
    - HPA short shifter
    - Tint (VA legal) 50% front/35% rear
    - OEM R32 front wipers
    - OEM MKV rear wiper
    - BFI Stubby Antenna
    - Euroswitch
    - OEM Monster Mats
    - Alpine 9857 with Ipod Connect
    - Southbend DXD Stage 5 w/LWFW
    - Peloquin Differential
    - EIP Dogbone Mount
    - H&R 8mm spacers in the rear
    Turbo Components
    HSTuning Vband Turbo kit with HTA3076 turbo including:
    1) HSTuning Stainless Steel Tubular Exhaust Manifold
    - 1.25" 304l schedule 10 runner material
    - 3/4" thick 304l stainless steel head flange
    - Welded inside collector and hand smoothed to seamless point
    - Stainless Vband flange is welded to collector in a special jig to prevent deformation
    - Backpurged
    - 13 Copper installation nuts
    - OEM Exhaust Gasket
    2) TiAL MVR 44mm Wastegate
    - .7 bar spring standard, others available
    - 4' of vacuum line
    3) HTA3076 Turbocharger
    - Flows 57+ lb./minute
    - Machined Billet Compressor wheel with 54.8mm inducer
    4) HSTuning 3" Vband downpipe with stainless vband clamps
    - 304l stainless steel tubing with .065" wall thickness
    - 2 piece design for easy installation
    - Stainless oxygen sensor fitings
    - Stainless Armadillo style flex section
    5) HSTuning oil and water lines (hand bent stainless with flex sections, see photos)
    - Black/Titanium finish on A/N fittings
    - -4 Oil feed with Tial .030" restrictor
    - -10 Oil return (304l stainless with small braided flex section)
    - -6 Coolant feed/return (304l stainless with small rubber flex on return)
    - Adel mounting clamps with stainless bolts
    - HST Aluminum oil pan & turbo drain flanges w/ SS bolts and gaskets
    6) HSTuning external wastegate discharge with stainless vband clamps (304l stainless 1.5" .049 wall thickness). Re-routed into downpipe.
    7) HSTuning 4" Polished Aluminum inlet pipe
    - Black 5 ply silicone couplers
    - Velocity stack
    - Stainless worm drive clamps
    - 6" opening K&N filter fits over velocity stack
    8) Bosch 044 Fuel Pump
    - Includes HST fittings to install in stock fuel filter location
    - Fuel pump wiring harness
    - Supplemental fuel filter
    9) NGK BKR7E Spark Plugs
    10) OEM 45 Degree Heater Core Firewall Connector
    11) Eurodyne Maestro Suite
    12) Bosch 977cc Fuel Injectors
    Head:
    1) Ferrea Valves
    2) Cat Cams 3653 cams
    3) Cat Cams cam gear
    4) AEB casting
    5) Dowel pinned crankshaft and cam gear
    7) Cometic head gasket
    8) ARP head bolts
    Lower Engine: 2.0T
    1) Forged, Knife Edged, 92.8mm Crankshaft
    2) Integrated Tuscan I beam rods
    3) JE 83.00mm forged pistons
    Other Components:
    1) SEM Motorsports Intake Manifold
    2) 80mm Throttle body
    3) Labonte Motorsports Water/Alcohol Injection kit
    4) HSTuning Front Mount Intercooler kit
    5) APR 3" Cat-back Exhaust system
    6) Boostvalve Deluxe Dual Stage Boost Controller
    7) Southbend Stage 5 Clutch w/ Southbend single mass flywheel
    8) 42 draft designs stealth catch can
    9) 42 draft designs Vacuum block
    10) DEI titanium turbo blanket and downpipe wrap
    11) Fluidamper harmonic stabilizer.
    12) 42 Draft Designs shifter bushings
    13) VF Engineering Motor and Trans mounts
    14) 80mm Dodge hemi TB
    My car has also made it onto the Forced Performance website in respects to the HTA turbo it's running: http://store.forcedperformance.net/m..._Code=Turbo-FP
    Buy my 20th! 550WHP/480TQ only 3k on the engine: http://forums.vwvortex.com/showthrea...I-(BMP)-550whp
  2. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    03-05-2012 08:22 PM #2
    Oct 12th, 2011
    Campbellsport, Wi
    86 gti 8v, 00' golf
    03-06-2012 09:20 PM #3
    nice car, GLWS
  4. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    03-07-2012 11:52 PM #4
  5. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    03-16-2012 12:50 AM #5
    bumparoo
  6. Member speeedfrk's Avatar
    Nov 9th, 2004
    miltown, wi
    12 Golf R, 13 Jetta
    03-25-2012 09:52 PM #6
    super clean dub! id almost think about a trade offer. i just think it would be tough to not have awd anymore. you have good taste. clean and simple...just the way i like it.
    chris
  7. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    04-03-2012 10:24 AM #7
    appreciate the compliment.
    not looking for a trade regardless
    bumpizzle!
  8. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    04-23-2012 10:13 AM #8
    Bumpizzle
  9. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    04-25-2012 11:32 PM #9
    bumpsky
  10. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    05-03-2012 10:35 AM #10
    bumpizzle
  11. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    05-18-2012 12:01 AM #11
  12. Semi-n00b RockinTheRocco's Avatar
    May 1st, 2012
    1987 Scirocco G60 16v
    05-18-2012 02:35 PM #12
    Too bad im not rich! Nice Car!
  13. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    05-24-2012 10:23 PM #13
    booo
  14. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    06-05-2012 10:22 AM #14
  15. 06-17-2012 09:53 PM #15
    I am interested in your car. Where exactly in Ohio are you?
    I think the price is right and I should be able to pay cash.
    I am new to the whole aftermarket thing so one thing that would be essential for me is a list of everything that's on it and maybe a tutorial.
    I hope we can figure something out and I still think that this is the best car.
    Forrest
    Edit: just noticed this is a couple months old, not sure if it's even still available.
  16. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    06-18-2012 11:42 AM #16
    still available
  17. Member thegoose's Avatar
    Nov 28th, 2008
    St. Charles MO
    2003 GTI
    06-29-2012 05:33 PM #17
    glws bump!
  18. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    07-20-2012 11:00 AM #18
    bumps
  19. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    07-31-2012 10:31 PM #19
    bumpersons
  20. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-02-2012 12:08 PM #20
  21. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-06-2012 06:37 PM #21
  22. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-11-2012 02:22 PM #22
  23. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-12-2012 12:33 AM #23
  24. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-12-2012 09:30 AM #24
  25. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-21-2012 10:49 PM #25
  26. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-22-2012 03:39 PM #26
    bumps!
  27. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-25-2012 07:54 AM #27
    bump
  28. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-25-2012 02:19 PM #28
    New price!!!!
  29. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-26-2012 05:17 AM #29
    bumpy
  30. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-26-2012 10:05 PM #30
  31. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-27-2012 10:19 AM #31
  32. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    08-27-2012 04:35 PM #32
    boom!
  33. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    09-08-2012 08:19 AM #33
  34. Member shotofgmplease's Avatar
    May 20th, 2003
    nova
    09-10-2012 08:47 AM #34
    bumps
  35. Member speeedfrk's Avatar
    Nov 9th, 2004
    miltown, wi
    12 Golf R, 13 Jetta
    09-11-2012 09:59 PM #35
    i am amazed this car hasnt been picked up yet. anyone can tell that it was done properly.
    good luck! as you can see below, i picked up a new toy.
    UM ftw
