1986 VW Vanagon. Basic model with NO FRILLS such as AC, Pwr steering, pwr locks or pwr windows.
Customized for traveling.
These came with vinyl seats and no armrests.
2.1L stock Van eng--GEX rebult with less than 35k- no docs on that
4 spd stock tranny.
Load rang "D" LT tires that run at 65psi. Good tread.
Low Miles 103,000. All glass, doors, locks etc are excellent. http://www.thesamba.com/vw/classifie...php?id=1272868 for several pix and same ad
New in last 12,000 mi.
Clutch
clutch master cyl and slave
Replaced tranny oil
KYB Shocks
CAT converter
gas filter
New spark plug wires
New rotors, drums, couple wheel cyl currently about 75-80%
Wheel bearings.
New CVs and axels
ignition switch
waterpump & some hoses
1991 ECU
Other stuff I can't remember
tuneup last 1500 mi and fresh oil change with proper Mann filter
This van has decent Brown paint that could use a cut/wax job to shine.
One small dent in front of dr rear wheel...nothing bad or even noticeable. 1 door ding on slider.
Rear bumper is not perfect and missing one end cover. Top clamps to bike rack still installed.
Rear seats removed and custom bed built with 2 tool box lids. I am a custom woodworker by trade.
4" foam pad covered with ripstop nylon a little worn.
upper wood shelf above rear hatch with brite light for reading in bed.
2 bulb flourescent lite above slider for loading and unloading. Very brite.
Rear carpets removed and rubber installed inside toolboxes and area in front of bed.
Runs like a sewing machine. Clean ready to travel.
Front seats are mismatched but clean and comfortable. I have the orig seat but has small seam issue that could be repaired. Included in sale.
Cash, paypal deposit with cash balance only.
I am in Portland. terrance@hevanet.com
This rig is clean, up to date and well maintained. Everything works and is in place.No junk.
