VWVortex.com - Stock wheels with coil overs + spacers?
    Results 1 to 21 of 21
    Thread: Stock wheels with coil overs + spacers?
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-05-2012 04:40 PM #1
      Just wondering who out there has a setup like this. I have a 2012 CC Sport.
      Also, what are my options for coilovers? I've search and found several. How are the Megan ones I see on Fleabay for $850ish?
    2. 03-05-2012 04:43 PM #2
      I had STs with 12mm spacers front and rear.
      Slight rub but not issues.
      STs run like $799.
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-05-2012 08:25 PM #3
      I like. Now the rubbing was because of your height & spacers combination? What if you were slightly higher, would you've rubbed?
      I came across this thread about ST coils while looking around. Do you have this issue?
      http://forums.vwvortex.com/showthrea...g-ST-coilovers
    4. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-05-2012 08:42 PM #4
      So far I've found:
      ST Coilovers
      KSport Coilovers - http://thmotorsports.com/i-510570.as...gSeanNOFITMENT
      Tracer Coilovers - http://www.ebay.com/itm/TRACER-Coilo...cbef3d&vxp=mtr
    5. Junior Member
      Jun 19th, 2006
      New Jersey
      2013 GTI Autobahn, 2010 VW CC Sport
      03-05-2012 09:56 PM #5
      I have a set of KW variant 1. $800
      2010 VW CC 2.0T Sport DSG; GTI paddle shift wheel; RNS 510 retrofit with internal VIM bypass and headrest monitor output; OEM rear view camera retrofit; Euro Xenon full conversion; 9W7 bluetooth; Baryard/E-Level airide; H&R sway bars; Goldcoast kit; Brembo 365mm BBK; Custom widebody; 20x10.5, 20x11.5 ADV.X 3-piece wheels with 285/25/20, 295/25/20 Vredestein Sessanta; APR stage 3+(451hp), Peloquin diff, RSW I-beam rods
    6. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-05-2012 10:08 PM #6
      Quote Originally Posted by nemomd View Post
      How many miles on them?
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-05-2012 10:26 PM #7
    8. Junior Member
      Jun 19th, 2006
      New Jersey
      03-05-2012 10:38 PM #8
      2000 before I switched to air.
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-05-2012 11:07 PM #9
      I had air on my 66 Bug.
    10. Member Bthasht's Avatar
      Oct 6th, 2011
      757 VA
      2009 VW CC
      03-05-2012 11:10 PM #10
      Going thru the suspension thread in this CC forum was the best thing I did. There are several setups like you have asked for. The question is do you want to go low for looks? Or low for performance?
      FK for MKV= Lowest
      Vmaxx for MKV= Next lowest
      H&R Ultra lows=Real low and performance
      Koni= Low and Performance
      So on and so forth
    11. Member snobrdrdan's Avatar
      Sep 10th, 2008
      Southeast Michigan
      2017 VW
      03-06-2012 07:20 AM #11
      The consensus would be:
      12mm spacer up front
      5mm spacer in the rear
      Wheels flush and no rubbing
      I had ST's...no issue.
      cwwiii recommended this setup and he has Konis....no issue either
      2016 Tiguan R-Line
      2017 Passat R-Line
      Feb 12th, 2012
      2015 Gti MK7, & 2013 Tiguan SEL
      03-06-2012 07:41 AM #12
      Quote Originally Posted by flexnix View Post
      Is this your car? It looks stunning.
    13. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-06-2012 11:15 AM #13
      Quote Originally Posted by TheDoc46 View Post
      Nope, but it's the same color I have though.
    14. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-06-2012 11:17 AM #14
      Quote Originally Posted by Bthasht View Post
      FK for MKV= Lowest
      So on and so forth
      I care for a nice ride and not going super low. I just want to go enough and with spacers to look decent on stocks. My price range is $800-900.
    15. 03-06-2012 03:39 PM #15
      My STs made a bit of noise at first. But it is more or less gone now. Everyone once and a while on the odd cold day (LA cold so like 60F) it happens.
      But overall I am impressed. I never had rear rub issues ever, even with 2 big friends in back (and i am all the way down).
      I rub in the front most often. Now that i am running 18x9 rims I noticed rub increased slightly.
      But all my dubs have rubbed so I am used to this.
    16. Member snobrdrdan's Avatar
      Sep 10th, 2008
      Southeast Michigan
      2017 VW
      03-07-2012 10:20 PM #16
      Konis
      $980 SHIPPED:
      http://www.redline-motorworks.com/pr...0.htm?CartID=1
      Coupon Code: GETKONI4LESS
      They go low, offer adjustability, and performance
      2016 Tiguan R-Line
      2017 Passat R-Line
    17. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-15-2012 05:31 PM #17
      Quote Originally Posted by snobrdrdan View Post
      First time I purchase spacers. 5x112...hubcentric 57.1 mm right?
      And do I just go with any brand or go with H&R. They're double the price...average for no brand ones is around $40-50 for a pair.
      1966 VW Beetle 1600DP on Air Bags (SOLD in 1/2013)
      1998 VW GTI VR6 Driver Edition (SOLD)
      1999 Pontiac Grand Prix GTP Turbo Conversion 482 HP/512 TQ.... 11.55 @ 120mph (SOLD)
      2012 VW CC Sport (Current)
    18. Member snobrdrdan's Avatar
      Sep 10th, 2008
      Southeast Michigan
      2017 VW
      03-15-2012 08:18 PM #18
      Totally up to you for the brand.
      Some people have had issues with the ECS Tuning ones sticking to the wheels (should use anti-seize on them to avoid that)
      I had H&R and didn't have any issues though, and I trusted them more.
      5mm don't come in wheelcentric...only hubcentric
      On the 12mm though....you DEFINITELY want hub & wheelcentric (has the lip for the wheel)
      5mm:
      http://www.ecstuning.com/Volkswagen-...cers/HR/ES153/
      12mm:
      http://www.ecstuning.com/Volkswagen-...ers/HR/ES5109/
      2016 Tiguan R-Line
      2017 Passat R-Line
    19. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-18-2012 07:37 PM #19
      Experience with vogtland coilovers?
      Some guy locally is selling the part# specific jetta mkv....so i went on achtung and noticedbthey use a different part # which includes the gti.
      The ones the guy is selling new locally...part# 968554 http://www.vogtlandsuspension.com/p1...duct_info.html
      The ones sold by achtung !.. Part# 968545.... http://shop.achtuning.com/vogtland-9...and-jetta.aspx
    20. Member
      Apr 29th, 2004
      Miami, FL
      2012 VW CC Sport
      03-18-2012 07:49 PM #20
      Seems like Ill be calling them Monday. http://www.vogtland-na.com/contacts.asp
    21. Member snobrdrdan's Avatar
      Sep 10th, 2008
      Southeast Michigan
      2017 VW
      03-21-2012 10:36 PM #21
      Those are gonna be similar to the ST's & not stainless
      They actually look the EXACT same as ST's except for the purple springs
      2016 Tiguan R-Line
      2017 Passat R-Line
