VWVortex.com - water-meth very soon :)
    Page 2 of 2 FirstFirst 12
    Results 26 to 44 of 44
    Thread: water-meth very soon :)
    1. Member Track5tar's Avatar
      Feb 16th, 2010
      Salt Lake City, UT and Las Vegas, NV
      Mine: 2010 Passat Hers: 2012 B8 A4
      03-07-2012 10:25 AM #26
      Quote Originally Posted by Tutti57 View Post
      Haha. Ok, I see what you mean. So if you have, say, Uni stage 2, will you need to keep meth in the tank all of the time?
      I will be because I can only get 91 octane here in Utah. The meth would bump me at least to 95 octane. Uni's tune will adapt to that. In turn I'll get better performance. Why don't you get a tune? You'll spend $300 or so on a meth kit. Might as well get a tune for double that lol
      Unitronic > APR Switched from APR to UNI and never looking back
      CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
    2. Member Tutti57's Avatar
      Jun 20th, 2011
      Rochester, NY
      2006 Passat 2.0T, 2003 Audi A6 3.0
      03-07-2012 10:33 AM #27
      I plan on getting both! Just planning ahead wondering how the tune works with meth. What if I get a 93 tune, will it adapt if I run the tank dry it would it be a problem?
      2006 Passat 2.0T Tiptronic | Unitronic Stage 2 | DG Springs | Newsouth Boost Gauge | BFI Tranny Insert | Rev D DV | BSH PCV fix | eBay Downpipe w/cat | Autotech Exhaust | DDM HIDs | Bentley Manual | VCDS - Car for sale! $6,000
      2003 Audi A6 3.0
    3. Member Track5tar's Avatar
      Feb 16th, 2010
      03-07-2012 10:44 AM #28
      Yep it'll adapt which is awesome. You'll want to turn off your pump before it runs dry though lol.
    4. Member SDbirdman's Avatar
      Jan 20th, 2011
      San Diego, CA
      2010 Candy White Passat 2.0 TSI
      03-07-2012 10:52 AM #29
      Isn't it much worse to run out of water?
      Unitronic Stage 2+ -- K04 turbo w/Unitronic DV Relocation -- 42DD 3" catless downpipe -- APR Intercooler -- Unitronic Intake -- BSH Throttle Pipe -- AWE Outlet Pipe -- Votex front lip -- HiDef side skirts -- painted rear valence -- mkvi wheel w/DSG paddles -- R-Line Pedals -- TRS HID headlights & projector fogs -- Euro side markers -- Skyline Euro Tail Lights -- Podi gauge and pod kit -- GFB DV+ -- 034 Motorsport Steet Density Mounts
    5. Member Track5tar's Avatar
      Feb 16th, 2010
      03-07-2012 12:05 PM #30
      Quote Originally Posted by SDbirdman View Post
      wha? lol meth and water already premixed in the tank
    6. Member Track5tar's Avatar
      Feb 16th, 2010
      03-07-2012 12:06 PM #31
      so life is good, I just found methanol in my area for $3.59 a gallon.
    7. Member Track5tar's Avatar
      Feb 16th, 2010
      03-07-2012 02:16 PM #32
      looks like its gonna be a month til I can get this in. my ecu is gonna take like 2 weeks to get back to me
    8. Member Tutti57's Avatar
      Jun 20th, 2011
      Rochester, NY
      03-07-2012 07:56 PM #33
      What tune are you getting? I just scanned through the treads and didnt see that.
      2003 Audi A6 3.0
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      03-07-2012 08:08 PM #34
      All of UNIs tunes adapt
      Sent from my EVO
      Unitronic Stage III w/ PT5558BB Turbo Unitronic.ca, IE HPFP, 3in B&B TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC/Forge SS, 42Draft Design CNC Shifter bushings, BFI stage 2 motor/tranny mounts, 034 Dogbone, KW V2 coilovers, Nuespeed 25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
    10. Member Track5tar's Avatar
      Feb 16th, 2010
      03-07-2012 08:35 PM #35
      Going from apr 2+ to uni stage 2
    11. Member Tutti57's Avatar
      Jun 20th, 2011
      Rochester, NY
      03-07-2012 08:39 PM #36
      Gotcha
      2003 Audi A6 3.0
    12. Member SickTRed08FSI's Avatar
      Apr 28th, 2011
      Syracuse, NY
      08 Passat 2.0T, 11 Volvo XC60 R Design
      03-07-2012 09:59 PM #37
      So I had a great conversation with Dave from BSH today. He said that utilizing the bung furthest away from the throttle body will give the mix more time to atomize, and that they have not had any issues with this setup. I`m going to get the Snow Performance stage 2 setup and connect directly to my BSH TB pipe. Honestly, I think that a spacer would throw off my whole dv relocation setup and the tb pipe itself.
      #fukur2cnts
      Detail Johnny - Serving the Greater Syracuse area
    13. Member Track5tar's Avatar
      Feb 16th, 2010
      03-07-2012 10:41 PM #38
      Quote Originally Posted by SickTRed08FSI View Post
      That's how I wouldve ran it if I got the bsh pipe. That's actually how I was planning then I heard about tb failures. I'm not trying to stop you from getting the bsh, just shaing the knowledge. I know a lot of guys who've been running bsh pipe just fine but I don't want to risk it. Everything is money these days. The money I save from not getting the pipe plus the money I would pay for a new tb, basically gets me an intercooler.
    14. Member SickTRed08FSI's Avatar
      Apr 28th, 2011
      Syracuse, NY
      03-07-2012 11:50 PM #39
      See....I already have the TB pipe. My thing is.......if it was proven to cause issues...then obviously BSH being a reputable company would change their product design. BSH has spent years developing with Snow performance, from what Ive read. Yet, many think that it causes issue, therefore going to the spacer. The question is....does the spacer work as well as pre throttle body injection?
      #fukur2cnts
    15. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      03-08-2012 12:03 AM #40
      its a well know problem. the meth causes the throttle body to swell. It can take time and it also depends on how rich of a mixture you run.
      Also different locations give different effects.
      If you put yours down low in the throttle pipe it will have more of a cooling effect and less of an octane boosting effect. if you put it up higher its more of a octane boosting effect and less of the cooling.
      Also a higher water content will cool more where a higher meth content will increase octane more.
      Nino is looking for more of an octane boosting effect so to get the best and safest (for the throttle body) using the spacer is the best
      For you John being lower i would run a lower meth content and you shouldn't see issues at least not for a while.
    16. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      03-08-2012 12:10 AM #41
      here's an awesome thread about W/M
      http://golfmkv.com/forums/showthread.php?t=50805
    17. Member Track5tar's Avatar
      Feb 16th, 2010
      03-08-2012 01:03 AM #42
      I know BSH is a great company, I have some of their stuff. I also know that my cooling will not be as good as yours because the tb pipe setup allows the mist time to cool the air. I'd like to have that too but rather not screw up my tb. I'll use this setup for very little cooling but mostly octane boost like bill said. for cooling, I'll get a fmic. there isn't one right way or wrong way. though you can't have it all, we sacrifice some to gain some. I respect your decision. as a fellow car enthusiast and b6 owner, I just hope your tb stays safe.
    18. Member x9t's Avatar
      Sep 19th, 2005
      Bay Area-CA
      07 Passat 2.0T 6MT/96 Passat GLX VR6/ 87 Scirocco 16V
      03-08-2012 02:37 AM #43
      You pay to play.. all mods have some risk.. same thing with PCV, DV, pulleys.. aftermarket "can" cause issues.. its on you to do your research and understand what your installing and if it is worth it. I dont want to install meth on the B6 but I will install it on the B4 (plan to SC).
      Still waiting on pics.. may just do it at the end.
      JT
      Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
      Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
    19. Member Tutti57's Avatar
      Jun 20th, 2011
      Rochester, NY
      03-08-2012 07:34 AM #44
      Quote Originally Posted by Bill6211789 View Post
      I just read through that monster. Good stuff.
      Do we have any B6ers currently running a setup?
      It sounds like upgraded intercooler and meth is the way to go to get all of the benefits. An S3 IC and a meth kit together is well under a $G, not bad!
      2003 Audi A6 3.0
