Results 1 to 12 of 12
Thread: need help o2a
  1. Junior Member
    Jan 27th, 2012
    ft worth, tx
    03-06-2012 01:58 PM #1
    what is the best way to bleed the clutch on an o2a transmission?
  2. Member Tim.vw.'s Avatar
    Dec 9th, 2008
    THE 860
    90 stg 5 g60, 90 stg 1-2 g60, 93 vr6 slc, 97 tdi, 99 jetta gl, my fav..93 Wolfsburg fox 4 door
    03-08-2012 11:09 AM #2
    2x search isn't helping any. I'm trying to bleed my tdi just put a new slave in. And now I can't get it to go in gear ive been bleeding and bleeding with no success hopefully someone can lend a hand
  3. Junior Member
    Jan 27th, 2012
    ft worth, tx
    03-19-2012 01:49 PM #3
    yeah, i'm not getting anything help wise
  4. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    03-20-2012 01:58 AM #4
    gravity bleed it at first, and then just pump bleed it like you would for brakes.
    biggest mistake most people make is cracking the bleeder too far.
  5. Junior Member
    Jan 27th, 2012
    ft worth, tx
    03-20-2012 09:42 PM #5
    thanks for the help, ill have to try this when it gets dry and i have the time...
  6. Junior Member
    Jan 27th, 2012
    ft worth, tx
    03-21-2012 05:59 PM #6
    just bled, no change.
  7. Member Tim.vw.'s Avatar
    Dec 9th, 2008
    THE 860
    03-23-2012 10:44 AM #7
    Ive bled it 6 ways to Sunday. Im thinking of changing out the master. Just to rule it out although it does have pedal pressure. And isn't leaking I jacked the as end up 3 feet to gravity bleed it didn't work.
  8. Junior Member
    Jan 27th, 2012
    ft worth, tx
    03-27-2012 05:17 PM #8
    replaced my slave, im now doing the master...
    Oct 7th, 2000
    Detriot Area, Mi
    1997 DE GTI VR6T
    03-30-2012 03:04 PM #9
    Personally I use a pressure bleeder for both the clutch and the brakes. This makes it quite easy for the clutch because the bleeder screw is about the lowest point in the system.
    What was the reason for bleeding, new parts? Just asking because it could be a bad part or just stubborn air bubbles. Just throwing parts at it can be expensive.
  10. Member Tim.vw.'s Avatar
    Dec 9th, 2008
    THE 860
    03-30-2012 08:15 PM #10
    Mine was driving fine no leaks then one day just stoped going in gear replaced slave bleed the crap out of it and nothing. I have a vac pump for brakes and hydro clutches. I used that but never got a solid stream after hours of pumping and dumping. Was think of using the opposite to pump fluid in push air bubbles up to res. I dunno glad someone is taking time to help out. I'd hate to break apart the motor and tranny and replace everything if it's not internal Tia
  11. Junior Member
    Jan 27th, 2012
    ft worth, tx
    04-02-2012 10:20 PM #11
    the master cylinder was bad
  12. Member Tim.vw.'s Avatar
    Dec 9th, 2008
    THE 860
    04-03-2012 07:56 PM #12
    Hope it's the same for me. Did u see any signs it was bad before u took it out?
