Results 1 to 11 of 11
Thread: BeHelp me pick the right parts to get my vrt to hook up.
  1. Member cant get a password's Avatar
    Sep 24th, 2004
    Pflugerville,Tx
    2002 Passat wagon,2001 Audi TT Quattro, 1995 megasquirted VRT Cabrio
    03-06-2012 02:47 PM #1
    Hey guys I have a vrt Cabrio with a stock tranny from a 93 passat and have a spare tranny from a gti. I do not know the tranny codes off the top of my head but can get them when I get home . I want to install an lsd and maybe a ring and pinion swap if that will help me along. I also would like to get some drag radials too was looking at doing some diamond racing rims in a 15x8. I will not be drag racing much just want to hook up better than what it does now.
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    03-06-2012 03:29 PM #2
    If it is a stock vr6 passat trans then they are both CCM trans codes and completely identical. 3.38 R + P
  3. Member cant get a password's Avatar
    Sep 24th, 2004
    Pflugerville,Tx
    03-06-2012 03:52 PM #3
    Yes stock trannys so eould a r&p swap when I do a lsd be worth the cash Bildon has a 3.94 right now on sale for $300.
  4. Member
    Dec 22nd, 2002
    CT
    03-07-2012 05:45 AM #4
    for a turbo vr6, use the stock 3.38 r&p... = longer gears
    3.94r&p = shorter gears, more burnout machine and broken parts
    I use Mickey Thompson ET streets 225/50/15 drag radials on my car
    GL
    2010 MB GLK350 4matic
    2009 Gti 2.0t powered by APR (Sold! last VW purchase!)
    2001 Gti 1.8t powered by Dalhback (sold and will be missed :') )
    1988 Jetta Carat Vr6 powered by www.LugTronic.com (99.9% done!!! )
    1987 Scirocco 16v w/t3t4 57trim powered by SDS (sold but never forgotten)
  5. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    89 jetta carat, 90 gti vrt
    03-07-2012 09:27 AM #5
    keep the 3.38 i use the mickey et streets 235/60/15 still spin a bit but they are better then the regular street tires
    67mm - vrt
    mad slow
  6. Member
    Dec 22nd, 2002
    CT
    03-07-2012 01:14 PM #6
    I wish i can fit the 235/60 inside my mk2 fenders...
  7. Member 2ToneTurbo's Avatar
    Feb 14th, 2007
    fall river. ma
    91 jetta coupe. 97 jetta drag car
    03-07-2012 09:40 PM #7
    Quote Originally Posted by PjS860ct View Post
    GL
    3.94 r&p with 24.5s on 13s reving to 8k is good.! On street tires it burns 1st to 4th.. I tried 3.39 on my aba16v coupe and it sucked..
    Aba 16vt jetta coupe 11.2 @132
    Run your car not your mouth.
    C . T . R
  8. Member cant get a password's Avatar
    Sep 24th, 2004
    Pflugerville,Tx
    03-07-2012 11:25 PM #8
    I have to run a 15" rim to clear my brakes I put g60 setup on my cabrio. I will just get the lsd and skip the r&p swap. what are the +/- to running a 205/50/15 or 225\50/15. Is there a better choice that will still fit under my stock fenders I remember seeing a mk3 running 17x8 with drag radials on here.
  9. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    03-08-2012 12:42 PM #9
    pjs my 235/60 are on my mk2 =]
    67mm - vrt
    mad slow
  10. Member
    Dec 22nd, 2002
    CT
    03-08-2012 01:12 PM #10
    Picture please!?!? my 225/50 barely fits... how high is your suspension?
    Thanks
    - paolo
  11. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    03-18-2012 06:55 PM #11
    i had to cut the fender a little and im still adjusting the suspension but the coils are up a bit
    67mm - vrt
    mad slow
