Results 1 to 9 of 9
Thread: reminders for the NHRA rule changes
  1. Banned
    Oct 23rd, 2011
    03-08-2012 12:56 AM #1
    hey fellas, check those belts, helmets, etc.
    some new changes come about this year, one that is being enforced at my track. cars >135 or between 7.50 - 9.99 require oil containment device. it wasnt mandatory last year, but this year it is.
    also, any car required to have a cage of course also needs a window net. now they are requiring 2 yr updates on the net.
    be glad most all of you guys dont need to deal with driveshaft loops. just another step in keeping us safer i guess.
    last two years i was fine with trans blanket instead of flywheel shield, so i should be good to go this year as well.
    just a reminder. our season opened last weekend, and the team (Kaizenspeed) i was supporting with pit crew and video was almost not able to run due to his belts being 2 months out of date.... i would have run home (20 minutes away) and got mine out of the car for him if i had to, but still.
    and he set a new PB sunday, 3rd quickest in the US now for Outlaw Honda FWD. 8.53 @ 174.
  2. Member H2OVWRacr's Avatar
    May 11th, 2000
    EscoCali
    02 Jetta Wagon, 93 SLC, 90 Coupe
    03-08-2012 01:53 AM #2
    that was moving.
    what track is that?
  3. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    03-10-2012 01:04 PM #3
    Holy Hell that moving.....Nice to see the PACNW delivering the goods.
    Woodburn drag strip.
    www.woodburndragstrip.com
    500HP 1990 Cowrado
  4. Member XXX008XXX's Avatar
    Mar 25th, 2002
    2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
    03-15-2012 09:18 AM #4
    thats the H2B car correct???
    10.30@145 .68 35R
    10.08@141 / 148
    Force Fed Engineering
    Lugtronic
    Boost Factory
    Dec 14th, 2001
    Greensburg, PA
    03-15-2012 10:03 AM #5
    Quote Originally Posted by XXX008XXX View Post
    Yup-- very nice car.
    Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
  6. 03-15-2012 11:03 AM #6
    car is well sorted out for sure
  7. 03-15-2012 12:21 PM #7
    oil retention catch pan....
  8. 03-15-2012 10:02 PM #8
    and, i have already bought a new SFI current rated window net, and made a pan. i am going to work on installing the pan tonight.
    BUT;i read a new update, and it says my local track is RECOMMENDING an oil retention device whereas it stated "mandatory" the other week. and the window net has been changed back to rulings from last year, no 2yr SFI cert for a "RIBBON TYPE" net 7.50 - 9.99 or any car required to have a cage/net. mesh net needs cert.
    also, pay close attention to your gear if you use IMPACT produced safety stuff.
    WINDOWN NET RULE AMMENDMENT
    The 2012 rulebook required all full bodied cars running 7.50 and slower to have a currently dated SFI 27.1 window net, regardless of type (i.e. ribbon or mesh) if they were required to have a roll cage. This was a change from previous years where a ribbon-type window net did not require an SFI certification. The NEW rule amendment has basically rescinded the 2012 requirements and we will now be going back to the same requirements we have had in the past which are as follows: For full bodied cars running 7.50 and slower, that require a roll cage, they must have a window net. The net can either be a non-SFI ribbon-type net OR a currently dated SFI mesh-type net.During 2008, 2009, and 2010 SFI decertified various previously SFI certified products.
    IMPACT PRODUCT DECERTIFICATIONS
    The result of those decertification’s is that any SFI certified products listed below that were manufactured by Impact prior to 1 January 2009 are decertified and may not be used where a SFI certified product is required. It is the competitor’s responsibility to provide objective evidence that each such product was manufactured 1 January 2009 or later.
    •SFI 3.2A/1, 5, 15, and 20 Suits, Jackets, and Pants
    •SFI 3.3/1, 5, 15, and 20 Gloves, Shoes, and Boots
    •SFI 3.3 Neck Collars and Head Socks/Helmet Skirts
    •SFI 16.1 and 16.5 1-3/4″ (for JDRL) and 3″ Driver Restraint Systems
    Acceptable objective evidence examples are:
    •A sewn on embroidered SFI tag for SFI 3.2A/15 and SFI 3.2A/20 Suits,
    Jackets, and Pants dated 2009, 2010, 2011 or 2012.
    •An Impact sewn in/on manufacturers date label marked with an indelible pen or punched for SFI 3.2A/1 and SFI 3.2A/5 Suits, Jackets, and Pants; SFI 3.3/1, 5, 15, and 20 Gloves, Shoes, and Boots; and SFI 3.3 Neck Collars and Head Socks/Helmet Skirts.
    •An original or copy of a receipt from Impact or other supplier or a written notice from Impact indicating that the SFI 3.2A/1 and SFI 3.2A/5 Suits, Jackets, and Pants; SFI 3.3/1, 5, 15, and 20 Gloves, Shoes, and Boots;and SFI 3.3 Neck Collars and Head Socks/Helmet Skirts were manufactured 1 January 2009 or later.
    •An Impact sewn on manufacturers date label punched January 2009 or
    later for SFI 16.1 and 16.5 1-3/4″ (for JDRL) and 3″ Driver Restraint Systems.
    NOTES
    No SFI certified Impact helmets are involved in the decertification.
    No SFI 27.1 certified Impact window nets are involved in the decertification.
    A SFI decertified product may be used in applications where a SFI certified product is not required such as some seat belt/driver restraint applications, etc.
    Some arm restraints have SFI certification; NHRA does not require SFI certified arm restraints for any application.
  9. 03-16-2012 12:56 AM #9
    pan is done and mounted.
