Page 15 of 16 FirstFirst ... 5 11 12 13 14 15 16 LastLast
Results 491 to 525 of 531
Thread: Electronic Stability Control - How to turn off/disable?
    Mar 4th, 2010
    Winnipeg
    2013 .:R RB
    10-04-2012 07:24 PM #491
    Quote Originally Posted by ThatVdub View Post
    MPG's must have dropped some?
    Have to pay to play. Nothing major, a couple miles per gallon maybe.
    2013 R RB - HPA Comp Controller - HPA Red 75A Motor Mount - HPA Short Shifter - 42DD Shifter Bushings - TyrolSport Solid Shifter Bracket Bushings - Carbotech Bobcat 1521 (Daily) - Carbotech XP12/XP8 (Track) - Unibrace UB - Euro Springs
  2. Member goforit2007's Avatar
    Mar 22nd, 2007
    Mount Prospect, IL (Chicagoland)
    2012 4dr Base Rising Blue Golf R
    10-04-2012 07:38 PM #492
    Quote Originally Posted by DViggen View Post
    I've spent a bunch of time, and some money (about $500) working on figuring this out....I think I will try and test my theory this weekend after giving my wallet a small rest. I had a request in another thread for Canadian Golf R codes...but was told "it's been posted earlier in the thread" (btw - great way to not support someone trying to figure out an issue) and I only have one Canadian Golf R code to go off of (there may be more...but I haven't done a recent search).....when I have 3 different US codes to figure out what I need/want done.
    If it works out...it will be a rather simple fix....
    awesome! let us know how it goes!!!
    -2012 Rising Blue Base 4dr 2012 R (current daily driver!)
    -1995 Spec Miata
    -1994 Sentra SE-R (PTE track beast in-the-works)
    -1995 Infiniti G20 (NASA PTF/TTF track rat) and 2012 NASA Nationals PTF Champion!
    Oct 23rd, 2006
    2012 Golf R
    10-04-2012 07:52 PM #493
    I have the comp controller and since installing a month(ish) ago I'm getting about 0.5 - 1 mpg less per fill then before.
  4. Member Vickroy6's Avatar
    Dec 27th, 2011
    Cleveland ( Bay Viilage)
    2012 DBP Loaded 2-Door Golf R, 2011 CW Tiguan W/Sunroof & Nav
    10-04-2012 08:19 PM #494
    Spoke with APR at H2O and they are working hard on a tune to turn off the ESP in addition to the ASR. Fingers crossed.
  5. Member MKV Aaron's Avatar
    Oct 17th, 2007
    Westerville, Ohio
    Golf R
    10-04-2012 09:33 PM #495
    The fact that you can't turn off ESP has kept me from purchasing an R.
    The first time it is publicly available, either from a tuner for purchasing, or via Vag Com, I will purchase a Golf R within a month. Guaranteed.
    Lets hope it makes its way out soon.
    Dec 2nd, 2011
    Burlington, NC
    2012 Golf R RB 2D L
    10-04-2012 09:41 PM #496
    Quote Originally Posted by MKV Aaron View Post
  7. Member MKV Aaron's Avatar
    Oct 17th, 2007
    Westerville, Ohio
    Golf R
    10-04-2012 09:54 PM #497
    Quote Originally Posted by jsausley View Post
    I used to live in Burlington for 2 years when I was younger.
    And there is nothing screwy about what I posted. I don't want electronic intervention when I drive, simple as that. My GTI can get the ass out on command and makes it very entertaining to drive, but the non defeatable ESP kicks in and ruins all the fun.
    Not to mention with higher HP applications, it comes into play with simple throttle usage.
  8. Member droopy1592's Avatar
    Nov 13th, 2002
    Atlanta/Raleigh
    2012 RB Golf R
    10-04-2012 10:14 PM #498
    Light rain yesterday... nice film of oil, got all 4 loose in 2nd AND 3rd... nice long slide, no esp kicking in.
    In many ways then this car is like herpes. Great fun catching it but not so much fun living with it every day. - Jeremy Clarkson
  9. Member velocity196's Avatar
    Feb 19th, 2006
    Washington
    2006 MK4 GTI, 2012 Golf R
    10-04-2012 10:34 PM #499
    Quote Originally Posted by droopy1592 View Post
    Hahaha that makes me giggle!
  10. Member Vickroy6's Avatar
    Dec 27th, 2011
    10-04-2012 11:01 PM #500
    Someone will figure it out sooner than later but hopefully not before its sold out in your case.
  11. Member MKV Aaron's Avatar
    Oct 17th, 2007
    Westerville, Ohio
    Golf R
    10-05-2012 11:39 AM #501
    Quote Originally Posted by Vickroy6 View Post
    I would be in the market for a CPO version anyway. They are just starting to touch into the high 20s, so my plan (if they can disable ESP) is to pull the trigger when I can get one for about 28k plus ttl etc.
  12. Member vweatsvtec's Avatar
    Dec 16th, 2009
    pearl river ,ny
    86 rocco 03 jetta . 2012 r on the wayyyy
    10-17-2012 12:55 AM #502
    I don't know if this would help or not but... Can we get any info from a 2013 gti and have that help figuring any of this out. From what I've heard they have the ability to fully disable traction control. Again I have no idea if this will help or not, just a thought.
  13. Junior Member
    Sep 8th, 2012
    2013 GLI A/Nav DSG BLK
    10-28-2012 02:23 AM #503
    I've read almost 80% of this thread and thus far I've come to the conclusion that I am still confused.
    Is there a defeat available by unplugging the ABS fuse?
    Has anyone successfully done this?
    Are the side-effects simply lights on the dash, no abs, and no ESP?
    aaron
  14. Member
    Dec 2nd, 2011
    Burlington, NC
    2012 Golf R RB 2D L
    10-28-2012 06:36 AM #504
    Quote Originally Posted by praecurvo View Post
    aaron
    Yes. You can unplug the ABS and it will work, but then you will have no ABS and you will have lights in the dash.
  15. Member
    Aug 13th, 2008
    Minneapolis, MN
    1995 M3, 2012 GLI
    10-28-2012 01:53 PM #505
    aaron
    Has anyone determined for sure whether pulling the ABS fuse disables the steering-angle sensor? And, if so, does disabling the steering-angle sensor have implications for the AWD and where it decides to send power?
    DD: 2012 GLI
    Gone but not forgotten: 2010 Golf 2.5
    Summer fun: 1995 M3
    Former E36 318i driver and self-appointed Chairman of the Momentum Preservation Society.
  16. Junior Member
    Sep 8th, 2012
    10-31-2012 12:09 AM #506
    Quote Originally Posted by Charlie84 View Post
    Scary BUMP!
  17. Member bzflag's Avatar
    Apr 27th, 2003
    Pell City, AL
    '12 R, '94 F150
    10-31-2012 10:43 AM #507
    Pretty sure Mike@tyrolsport confirmed this. There's a link to his thread in the FAQ.
  18. Member
    Feb 27th, 2008
    IE, ca
    11-24-2012 06:38 AM #508
    so all-in-all what ive gathered from this lengthy thread is that the USA finally got an awd MANUAL golf but cant use it to its fullest ability because of the ESP?
    ive been a VW guy my entire life and days like this make me wonder why!
  19. Member climbingcue's Avatar
    Feb 2nd, 2001
    Morristown NJ
    08 Kawasaki Teryx, 2012 VW GOLF R 12.58@106 mph on 93 Octane
    11-24-2012 09:02 AM #509
    Quote Originally Posted by BIGboySTARK View Post
    You are correct, no winter driving schools for the USA Golf R...
    CAT 2
    Skela official test driver
    Texas Mile October 2010 171.6 mph
  20. Member ScratchRob13's Avatar
    Feb 6th, 2006
    New England
    '12 VW Golf R, '01 Audi A4, '07 Duramax
    11-24-2012 10:24 AM #510
    I pulled it the other day, and had fwd only, no abs, and severe disappointment.
    If you are looking at the fuse panel under the hood, standing at the front of the car the top right corner, second fuse from the top is the abs.
    2001 Audi A4 QM 1.8T | Under Construction...
    2007 Chevy Duramax | BT Dieselworks 1000+rwtq
    2012 VW Golf R | Mini-Avant
  21. 11-29-2012 09:14 PM #511
    I've been following this issue and saw this posted today:
    http://www.youtube.com/watch?v=d0Aq2mJuT44
    I did a quick search of the forum and couldn't find anything like this. Is this a hoax, or really someone who's defeated ESC?
  22. Member Coderedpl's Avatar
    Jul 9th, 2006
    Valley Stream, NY
    2012 VW Golf R 4dr Rising Blue
    11-29-2012 09:16 PM #512
    Quote Originally Posted by Lastlucidthought View Post
    Bad at searching then:
    http://forums.vwvortex.com/showthrea...-thread-needed
    Current: 2012 VW Golf R (rising blue) / UM tuned
  23. 11-29-2012 09:23 PM #513
    Deep regrets, much thanks.
    BTW, Google search for Golf R Stability control turns up this thread. If it's sorted, good news.
