Page 3 of 16 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 531
Thread: Electronic Stability Control - How to turn off/disable?
    Nov 10th, 2010
    B7 RS4
    03-10-2012 12:23 PM #71
    Quote Originally Posted by surefooted View Post
    UWhile I understand TechEd's point and the fact that it does apply to 99% of all drivers (yes, most people aren't as skilled as they believe, even during track days). However, there are still the 1% that can drive the isht out a car and would like to fully defeat all aids.
    And the Golf R is, in theory, intended for that 1% market segment. For the other 99% there are plenty of other VWs, and even Golfs, in various flavors. Have to agree with the somewhat douchey guy in the review video - if you are going to put an R badge on a car, you need to follow through completely.
  2. 03-10-2012 12:30 PM #72
    Why would APR have to look into providing a fully disablable option if in fact the Euro versions have it already? Wouldn't it be more efficient to simply flash a Euro program for the ESP? This leads me to believe that the Euro version and the US version are exactly the same and that somewhere along the way the word 'disable' got lost intranslation.
    Also, in this video I am guessing that in the first half the guy is driving with the ESP engaged and in the second half he has it disabled. If this is the case, it looks to me like driving with the ESP engaged is more fun for a driver with my skill set.
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    03-10-2012 02:13 PM #73
    it's hard to see the tires in the clip
    a good set of snows will allow the ESP system to work at it's fullest
    if it had the all season pirellis or dunlops ..... that could have allowed for all that drifting
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  4. Member VWPDX's Avatar
    Jul 7th, 2011
    Portland, OR
    2012 Golf R (2012-) 1997 GTI-VR6 (1998-2007)
    03-10-2012 02:37 PM #74
    Quote Originally Posted by DudeLePowSki View Post
    The Euro versions actually don't have it. As demonstrated by the Cupra vs. R video, stability control gives drivers the illusion they are going horribly slow. I would love to see you guys post track times with and without the abs fuse pulled. The R badge comments are as ridiculous as Xalfa. Again, I contend performance is probably not significantly decreased. Look at the VW/Audi/Volvo R line. Are they really that extreme? Its a model not a spec. As a whole reviewers and tcl types don't understand the appeal. "I don't get it. Its slower than a STI." "I know the interior is nice, but I can get an A3 for that price."
    Sent from my DROIDX using Tapatalk
  5. 03-10-2012 02:46 PM #75
    Quote Originally Posted by VWPDX View Post
    Fantastic point. Finally we can put to rest the difference in ESP between Euro and US versions.
    Also, the above European test driver is ripping it up with the same ESP options as the US version. If in fact snow tires (= traction in snow) do make the ESP operate to it's fullest in snowy conditions, I'd tend to side with TechEd in the fact that proper tires for performance oriented driving (on a dry track) do contribute to high performing, fun track runs with ESP engaged.
    STOKED.
  6. Member
    Jul 26th, 2002
    Houston
    2012 Golf R
    03-10-2012 02:54 PM #76
    Quote Originally Posted by BsickPassat View Post
    ASR is a fuel cut
    EDL is brake based, only up to 25 mph
    ASR worked through the brakes.. fuel cut was only if that didn't work or at higher speeds.
    I could make that light flash on wet roads and never felt fuel cut... b/c it was at low speeds.
  7. Member DaLeadBull's Avatar
    Feb 14th, 2011
    Whitehall, PA
    2012 RB Golf R
    03-10-2012 03:02 PM #77
    STOKED.
    http://www.youtube.com/watch?v=b4D7IYOxUxY
    If this is the video you guys are referring to, then look at the post date. It's from 2010.
    I thought the 2 stage ESP was only available in 2012 models in ROW Golf R's.
    Oct 23rd, 2006
    2012 Golf R
    03-10-2012 03:18 PM #78
    Again, that's not the point. It's not what's faster or slower. It's not what's more safe or more risky. It's give me the choice! That's it. Plain and simple. It's not unheard of and it's not "ego-driven, group-think rubbish". Other cars from other manufactures in the same segment as the R give the driver the choice.
    May 10th, 2010
    North Jersey
    03-10-2012 03:22 PM #79
    Quote Originally Posted by 12vdubber View Post
    EDL = brakes and is limited to a certain speed. fwd = 25 mph, haldex 4motion may be higher
    asr = fuel cut, works at all speeds
    with ESP.... that's brakes
    Other Rides:
  10. 03-10-2012 03:31 PM #80
    To the question of whether the ROW cars disable ESP...
    Volkswagen has equipped its most potent Golf GTI and R models and its entire Scirocco range with a new ESP system that allows the driver to fully disable electronic aids.
    VW has responded to criticism from media and customers that said the models were not adjustable or sporting enough, were too sensible compared with rivals and did not allow the driver full control of the vehicle.
    All 2012 model year Sciroccos and Golf GTIs and Rs built from May will be fitted with the new system and will reach showrooms from July. The new ESP set-up is a two-stage system that controls traction control and braking. Pressing the ESP off button once will disable the traction control, while holding it in for more than three seconds will fully disable both traction control and electronic braking systems.
    The system will only cut back in should the driver press the brake pedal in the middle of an ‘emergency’, be it if control of the vehicle is lost by the driver or if they want the car to straighten up by itself. If the brake pedal is not depressed by the driver the ESP system will remain inactive.
    The new ESP system is a standard fit to all Scirocco models, plus the Golf GTI and R, and is available for no extra cost over the standard car. There are no plans to fit to the Polo GTI at this stage however.
    http://www.autocar.co.uk/News/NewsAr...llCars/255389/
  11. 03-10-2012 03:33 PM #81
    Quote Originally Posted by webcrawlr View Post
    I can respect that opinion for sure. If the Euro version does have full disable then get your car flashed with the Euro code for the ESP. Simple fix not worth arguing at this point considering the lengths at which people have gone to replace simple Euro car specs like LED lights.
  12. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    2010 Audi B8 S4 3.0 TFSI 6MT & 2007 VW MKV GTI 2.0T FSI DSG
    03-10-2012 04:02 PM #82
    We have both a US and Euro Golf R at APR right now. I'll see if either offer full ESP disabling through the ESP button.
    GoAPR.com | Facebook | YouTube | Twitter
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    The bitterness of poor quality is remembered long after the sweetness of low price is forgotten.
  13. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    2 Door bugatti coupe...er, i mean Golf Racecar
    03-10-2012 04:31 PM #83
    Quote Originally Posted by Arin@APR View Post
    yay Arin
    You Aint About That Life | ETYolo
    Ruined Blue Golf | 42 Draft Designs
    Buy My Autopilot V2
  14. Member DaLeadBull's Avatar
    Feb 14th, 2011
    Whitehall, PA
    2012 RB Golf R
    03-10-2012 05:16 PM #84
    What model year is the euro version?
    I think only the 2012 euro R's came with the fully-defeatable ESP.
  15. Member
    Oct 23rd, 2006
    2012 Golf R
    03-10-2012 05:21 PM #85
    Quote Originally Posted by DaLeadBull View Post
    According to the article posted a couple above here it's 2012's built in May and forward. No one should have the 2 step ESP yet.
    http://forums.vwvortex.com/showthrea...1#post76340239
  16. Member BlazinVR's Avatar
    Jun 14th, 2010
    Forest Lake, MN
    '01 GTI VR6, '01 A4 1.8T
    03-10-2012 07:16 PM #86
    "All 2012 model year Sciroccos and Golf GTIs and Rs built from May will be fitted with the new system and will reach showrooms from July. The new ESP set-up is a two-stage system that controls traction control and braking. Pressing the ESP off button once will disable the traction control, while holding it in for more than three seconds will fully disable both traction control and electronic braking systems."
    question: does turning off traction control also turn off automatic braking through hard turns? i'm guessing it doesn't
    MK4 Forum:
    Quote Originally Posted by SaleenEatedUrVDubb View Post
    Hey guys I have a 2.0 but I can't really hear my Turbo. What BoV should I get?
  17. Member
    Nov 10th, 2010
    B7 RS4
    03-10-2012 08:04 PM #87
    Someone is utterly and completely missing the point, and "I contend" that person is VWPDX.
  18. Member DaLeadBull's Avatar
    Feb 14th, 2011
    Whitehall, PA
    2012 RB Golf R
    03-10-2012 09:29 PM #88
    That article was from Feb, 2011. I think they meant from May 2011 onward.
  19. 03-11-2012 03:40 PM #89
    ...I have to acknowledge this is a hard topic..."moving down" from an 2008 E90 M3, this might be a deal breaker for me...I already have a RB R on order from Austin VW dealer and I am now thinking to safe "a bit" more and get myself into a TT RS....
  20. Member
    Nov 10th, 2010
    B7 RS4
    03-12-2012 12:47 AM #90
    Quote Originally Posted by itofigari12 View Post
    Save up. TT RS is the shizznipple.
  21. Member VWPDX's Avatar
    Jul 7th, 2011
    Portland, OR
    03-12-2012 12:55 AM #91
    Quote Originally Posted by xalfa View Post
    I contend the goal of Racing is to post the fastest time.
  22. Member
    Nov 10th, 2010
    B7 RS4
    03-12-2012 01:11 AM #92
    I have never raced and don't intend to. But I do enjoy Driving. Sometimes on a track. And if I can't be fully in control of my car when it is at the limit, and software keeps me from even approaching that limit, then that is just not driving.
  23. Member BlazinVR's Avatar
    Jun 14th, 2010
    Forest Lake, MN
    03-12-2012 01:32 AM #93
    skip to 5:00 in this video. even motortrend doesn't like the automatic braking.
    can you imagine how much brake pad this car would go through on a track?
    MK4 Forum:
  24. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    03-12-2012 10:42 AM #94
    TechEd needs to realize that not everyone is buying this car to only track with and post low times. He also needs to realize that some people like to have fun in their car. He also needs to realize that safety should be an individual and personal concern.
    I say release the defeatable ESC program to the masses. Let Darwin do some work. Over time these inflated ego type "racecar racer" 16 year olds will wipe themselves off the maps, and the R in the US will become even more rare, and hold it's value even better.
    If somebody wants to go have fun in a snow covered parking lot, they should have every right to. If they want to pretend that they can take the turn up ahead at 90 MPH so long as that stupid ESC program isn't on, then they should be allowed to try.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  25. Member VWPDX's Avatar
    Jul 7th, 2011
    Portland, OR
    03-12-2012 10:57 AM #95
    I argue that the software doesn't really keep you from the realistic limit of the car. Luckily, they didn't go and put a D badge on it. Anyhow, this is a hypothetical discussion. I can see the other side's perspective of wanting unhindered access without pesky braking. Realistically, a few percent of Golf/GTI buyers are R buyers. A few percent of R buyers would actually utilize a full disable safely on a track. Thus, I can see VW's perspective as well. Either way, I own a R and I don't care. If you don't own a R, you should probably care less. If there is enough numerical demand, I am sure someone out there can figure out how to bring you the new 2012 EU programming for a price. As a side note, several weeks ago, I happened on a parking lot filled with over a foot of fresh powder. The hooligan bug did bite me. With the traction control disabled, it gave me all of the hooligan fun I could ask for and then some.
  26. Member BRSomm's Avatar
    Apr 21st, 2011
    Hamilton, ON
    2012 CSG Golf R
    03-12-2012 12:25 PM #96
    A good argument could be made that if you learned to drive without engaging the nannies you'd be faster.
    Tiff felt faster in the Seat but was actually slower.
    If you're arguing that you simply want to be able to hoon around, then the nannies need to be defeatable, but arguing that you're faster without them?
  27. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    03-12-2012 12:27 PM #97
    Quote Originally Posted by BRSomm View Post
    yes but the seat was only fwd, while the R is awd
    Buy My Autopilot V2
  28. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    03-12-2012 01:25 PM #98
    I have a North American and ROW German Golf R at APR right now and I can confirm that both cars only disable ASR. ESP will not turn off by pressing the button. This even includes holding the button for lengthy periods of time.
    Unless the controllers on the ROW German spec Golf R were messed with, looks like Golf R's all over the world are like this.
  29. 03-12-2012 01:44 PM #99
    Thank you for checking that.
  30. Member
    Oct 23rd, 2006
    2012 Golf R
    03-12-2012 02:36 PM #100
    Arin, it looks like this will change with ROW R's that get produced from May forward. There was a link to an article on it above.
  31. Member
    Nov 10th, 2010
    B7 RS4
    03-12-2012 04:30 PM #101
    I'm arguing exactly the opposite. I'm not a racer and could honestly care less about seconds on a 2 minute lap. I've never paid attention to lap times when I have been on the track and mine probably SUCK. But I want to have the option to be fully in control of my car and have my skill, not software, determine how fast I can drive. I also want the option to hang the @ss out when I feel like it because that is a very slow but very fun thing to do.
    If the goal of the engineers was to make even the worst drivers marginally faster around a track then they should have offered DSG only.
    VW: Screw your desire for "involvement" and "enjoyment" and your irrational need for a "third pedal." We know even the best of you will be tenths faster on average around a track with the DSG, and you will be safer while doing so. So that is all you get. Sorry.
  32. 03-12-2012 04:36 PM #102
    Arin, multiple articles are saying that VW is going to change that or did change that at some point. When was your ROW golf built?
  33. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    03-12-2012 05:45 PM #103
    I'll check tomorrow but this R's been in the US since before october 2010, so it's not new.
  34. Member
    Nov 10th, 2010
    B7 RS4
    03-12-2012 06:29 PM #104
    Seems like the sketchy information available now says hold out for a build date >= 5/12.
  35. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    03-12-2012 06:34 PM #105
    I wouldn't believe news articles unless I've tested and confirmed.
