#177
#178
Is there a Dynamic/ Yaw Sensor on VW's????
If so... look for a wiring diagram, and cut power to it. (Via a Spliced Switch)
#179
#180
Out of curiosity, any know if a button could be wired to the ABS module in a similar fashion to the Jetta GLI ESP defeat solution published by AWE tuning?
http://www.awe-tuning.com/products/v...ctivation.html
B.
#182
I am a bit confused by your response. The Ross-Tech website describes "44-steering assist " adaptation channel - 09 as the Steering Angle Sensor activation/deactivation. Which is exactly what is described by the translated German posts I put up yesterday.
From: http://wiki.ross-tech.com/wiki/index...ist#Adaptation
Channel 009: Steering Angle Sensor
The Adaptation Channel determined the Functionality of the internal Steering Angle Sensor. Depending on the Combination of Steering Aid and Brake Electronics the internal Steering Angle Sensor needs to be deactivated.
Possible Settings:
* Internal Steering Angle Sensor active
* Internal Steering Angle Sensor inactive
* Internal Steering Angle Sensor inactive (only ASR MK70)
Were you able to change the value and see if it deactivated the sensor (and ESP)?
B.
#183
Just so I understand what I might be waiting in line for, by "calibration changes" can I take it to mean that you are altering the interpretation of the incoming voltage from the wheel, steering, yaw, what-have-you sensor to change the intervention threshold to a point where you'd have to be spinning like a top before it would activate? More to thhe point, is this a pure software update or a hardware one that alters the output voltage from a sensor(s) to fool the existing software? Or something else?
2012 R CW 2DR
2011 F150 SCrew 5.0
2009 WRX
2000 911 C2 Aero Brumos Special Edition 'B59'
1970/73 911 RSR residing within a 2011 ATC 24 ft VNose
#184
Tailwagger, I imagine APR is going to play it close to the vest with this sort of information. Naturally, I'm also curious about the details - but if I were APR, I'd keep tight reins of this finding.
Hopefully, whatever adaptations they've found can be woven into the ECS software and activated with existing switchgear.
#185
2012 R CW 2DR
2011 F150 SCrew 5.0
2009 WRX
#187
#188
Old - 2001 GTI 1.8T - Matchstick Red (for sale), 1997 Jetta GLX VR6 - Black
New - 2012 Golf R - CSG
#189
2012 R CW 2DR
2011 F150 SCrew 5.0
2009 WRX
#191
I have a VAG-COM. Anyone have an R I can experiment with?![]()
#193
I posted a link in another of these type of threads a while ago and couldn't be stuffed trying to find it. Basically it was a link to an article in an Australian magazine that had a test on APR's Australian Golf R. They had the ability to fully disable ESP and on a racetrack with a professional driver it was 0.1s quicker with ESP turned off. Speaking to Guy Harding who runs APR in Australia he said he is quicker on the track with partial ESP disable (ie will still cut in at some point) than with it fully disabled. Whilst Guy wouldn't call himself a professional driver his skill level is probably better than average.
It has been confirmed by a number of people in Aus that have cars built post May 2011 that they have the 2 stage disable. I don't think any of them have been on the track to test whether they are faster with it off than with it on. I have also been told by the Service Manager at my local dealership that the 2 stage disable is not an upgrade that can be done on older vehicles which makes me think that they have changed hardware to make it happen from the factory. Obviously there is a way to do it with software but that will have to wait for APR or others to release.
Golf R 5 door, DSG, EVOMS CAI, TXS DP, Recode Tune, Autotech HPFP internals, Godspeed Project FMIC. 12.581 @ 107.49mph
#194
Forget the track, I want to be able to get sideways in the snow!![]()
#196
Hmm interestingly it appears very worthwhile to mess around with...TyrolMike has posted confirmation in his thread that changing that steering sensor code does indeed disable ESP.
booom......
http://forums.vwvortex.com/showthrea...husiasts/page5
Originally Posted by TyrolMike
So there is a simple workable solution for those want it.
And to think all it took to find was an hour of using google.
B.
#197
Don't get much snow down here, but I do plan on autocrossing this car and maybe going to a Gymkahana from time to time. There are also three really good race tracks within a reasonable distance of me, Motorsport Ranch, Texas World Speedway, and The Driveway. Also the new F1 track isn't too far once it's built. Either way, disabling the stability control is a good thing because it forces you to learn how to drive the car, which is the real reason to do such events, or go to the track. If the electronic nanny saves your butt every time you make a mistake, you can't learn, or you learn to depend on it.
#198
#199
#200
non-defeat ESP took the Mk6 Golf off my list, good to see progress is being made. Maybe it'll be a contender again.
TedEd : If ESP were so great on track, why did they give special ESP off versions to early media impressions, and why are media impressions so overwhelmingly negative now that they're testing versions with non-defeat ESP? For example, no mention of non-defeat ESP in the Golf R Lightning Lap blurb, plenty of loud whining about it for the Jetta GLI (which, thanks to esp got it's ass handed to it by the Civic Si).
No ESP: you can correct mistakes, suffer a bubble but keep going.
With ESP: if you screw up, oh well, here come the brakes and the big slowdown show. Try again next lap, do not pass go, do not collect $200
I don't particularly dislike ESP, there are very few people anymore who are hardcore anti ESP, but you've got some sort of new stability control stockholme syndrome, railing against those folk who enjoy having the option of having it off.
If the Golf R is really so dangerous that it shouldn't be driven with the ESP off, then the solution isn't to give it non defeat ESP and sell it as a sports car, it's to re-engineer it until it works properly.
My hunch is the golf is just fine and the stability control can please be put onto a button, and if somebody decides to go 130 with the stability control and the tail goes all wig-a-wag on them with their hamfistiness, then they pushed the button to kill the esp and can please sod off.
Unless you think the Golf R belongs in the illustrious company of other vehicles that aren't safe to drive without ESP, like the Smart ForTwo or the Can-Am Spyder.
#201
Man, I envy the people buying a $38k car as a dedicated track car.
2002.5 Jetta 1.8T - TOTALED (dodging deer)
2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
1992 Corrado SLC - The toy & DD
2012 Golf R - The weekender
#202
#203
Neither am I, not by a long shot, but I trust them enough that they won't screw up simple things like "this sucks and it's pissing me off"![]()
#204
It is possible to four wheel drift without the ESP kicking in. I've done it on mud and I assume you'd be able to do the same on snow. You just have to be smooth. The fact that changing the codes for the steering will disable the ESP indicates that steering input is one of the factors that ESP uses. If you are hard on the wheel it is more likely for the ESP to cut in. Be gentle and you'll find you can get a nice drift going.
#205
#206
After a few days of fully beating on the Golf R in conditions that rival some of the best track situations ESC didn't spoil the fun even once! I never felt the car lose power and even at the point of the tires beginning to tell me they were at their limits the car kept going! I am hooked this a very capable and fun car.
Working on my photos but in this one you can see the car in a pretty tight corner where staying between the lines is critical.
http://www.photoreflect.com/store/Or...o=1343&pc=1567
#208
Coding Differences between US and our Canadian Counterparts. I got to plug into an EH car today and this is the difference in coding.
Canadian:
Sunday,22,April,2012,06:55:22:43878
VCDS Version: Release 11.11.3
Address 03: ABS Brakes
Control Module Part Number: 1K0 907 379 BJ
Component and/or Version: ESP MK60EC1 H31 0121
Software Coding: 144B800C49248000281301EC921A0141310000
Work Shop Code: WSC 01357
VCID: 7BDB2D57FAFE411
Advanced Identification
Identification: TT1-012
Revision: 00H31001
Date: 17.12.11
Manufacturer number: 0303
Test stand number: 0FC9
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 2000.14.00
Flash Tool Code: 00000 000 00000
Misc.
Hardware number: 1K0 907 379 BJ
Workshop System Name: J104
VCDS Info:
Labels: 1K0-907-379-60EC1F.clb
United States:
Sunday,22,April,2012,06:57:02:43878
Software Coding: 144B800C492A0000280E01E7921B0041B70000
Revision: 00H31001
Date: 07.11.11
Manufacturer number: 0304
Test stand number: 0475
Flash Status
Misc.
VCDS Info:
Someone do some testing. I am driving home from wookies and unable to do stuff.![]()
2012 Golf R - Black WETDUB
HPA Softwares, APR HPFP, Scorpion TBE, Forge Twintake, HPA Mount, APR Flap Delete, Dieselgeek SS, RNS-510, 9w7 Bluetooth, JL 10w6 W/ Stealthbox, JL XD600/1, JL Cleansweep, P3cars.com Boost Gauge, Backup Cam, Color Matched Side Markers w/ bulb delete, LED Everything.
(Build Thread)
#209
In many ways then this car is like herpes. Great fun catching it but not so much fun living with it every day. - Jeremy Clarkson
#210
Hmm, my current coding is
144B800C492200FD281101E992220041B70000
and I tried
in both Lcoding helper and in the new coding field and both times got a error 31 coding out of range.
