Page 2 of 9 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 292
Thread: 01 Audi TT225 compound turbo setup
  1. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    03-16-2012 08:56 AM #36
    Wouldn't your overall power be restricted to the flow of the small turbo's exhaust housing?
    bagsarefordeadhookers
    -TCC
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    03-16-2012 07:35 PM #37
    Thats the great thing about this setup even if you are restricted by the small turbos exhaust housing it doesn't really matter. I think Im only going to be running the small turbo somewhere around 17psi which is well under what it can handle. You got to think, the larg turbo is for low pressure, your supplying your smaller turbo (high pressure) with already compressed air where it will then be compressed again and blown into the motor. This is why you can run much higher boost levels. I think we only have to run the large turbo at around 11psi to supply the small turbo with enough pressure to compress it to the pressure we need to make 500hp. I say "I think" because i am not the expert on this stuff. I understand the concept and all but as far as the math goes, thats all my mechanics job. There are a couple of faq sites about compound turbos. They have really good info that is pretty easy to understand until it gets into the math portion of it all. Take a look, they will be able to explain alot better than i can.
  3. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    04-09-2012 11:44 PM #38
    So what's up with some progress
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
    Jul 8th, 2009
    Kuwait
    2002 Audi TT Quattro LMNS Edition, 2004 R32 4mortion DSG
    04-10-2012 07:12 AM #39
    Quote Originally Posted by 01ttgt28 View Post
    x2
    Quote Originally Posted by groggory View Post
    FAQ'd
    keep up the great work Mr.Groggory
    Reading>posting .
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-10-2012 07:06 PM #40
    Update...FRUSTRATION!!!
    The motor hasen't come back from the machine shop yet and i found out yesterday it was because my mechanic never paid the deposit for the work on my motor in the first place(even though i gave him $2000 for engine and powder coat already). So therefore my motor has been sitting there not being worked on for about a month and a half. I called the machine shop yesterday to see what the hold up on it was and low and behold found out i was being screwed. So I called my mechanic and used a few choice words and that seemed to get results.
    He went by there today and paid the deposit so hopefully it will be done by the end of this week. I will be sure to keep you guys posted as soon as there is some progress.
  6. Member ttwsm's Avatar
    Feb 27th, 2011
    Minneapolis
    2005 TT 225Q
    04-10-2012 07:27 PM #41
    Wow that's a bummer. I hope things go better from here on out! Too often it seems like things that start badly also end badly...
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-10-2012 10:03 PM #42
    Well hopefully things start moving forward a little better. After speaking with my mechanic he seems to be back on track. Over the last month I've only talked to him a couple of times about my car, but since our little discussion yesterday, hes been blowing up my phone. So I dont see any problems with things not getting accomplished on his end once the motor comes back. Their moving into a new shop in the next couple of weeks, so he would like to get it done before then.
  8. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    04-10-2012 10:15 PM #43
    Nice it always helps if you flash a couple more thousand in his face
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-10-2012 10:19 PM #44
    I should do that...loan me a couple, Im good for it
    I did get a new intercooler. Its a treadstone TR1035
    Aug 12th, 2010
    Dallas, TX
    2003 Audi TT
    04-11-2012 04:17 PM #45
  11. 04-15-2012 08:00 PM #46
    any more updates?!?!
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-16-2012 06:07 PM #47
    Sorry nothing really to report yet. The machinist finally started on my motor last Thursday so if he dosent run into any complications then it should be back to the shop near the end of this week. Then the real fun should begin...I'll keep you guys posted.
  13. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-20-2012 07:34 PM #48
    Good news fellas!!! Block will be back on Monday
    Im taking the day off to go help with the install so I will try and take some pics of everything as it happens.
  14. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-24-2012 10:11 PM #50
    Didn't get a chance to take pictures of the motor yet. Should be back in the car tomorrow but i did snap one of my newly powder coated SEM intake manifold, LOOKS AMAZING!!!
  15. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-25-2012 06:27 PM #51
    Got some last minute parts in today.
    Aeromotive Adjustable FPR
    Aeromotive Fuel Pressure Guage
    42DD MAP Sensor Flange
  16. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-27-2012 03:08 PM #52
    After two and half months, here it is. Taken right after delievery so its sitting on a tire on the floor.
  17. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    1989 16v, F250 Diesel, 2001 TT
    04-27-2012 04:15 PM #53
    been waiting for this build to get going.
    HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
    HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
    Looking for Custom Tuning, Shoot me a PM ! ME7.X !
  18. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-27-2012 06:46 PM #54
    Your tellin me. I was over there today helping install the motor. Got the mounts in and was lowering it into the car when I had to leave. Should be in by now though so now we can start with the fun stuff.
  19. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    04-27-2012 09:21 PM #55
    Now where talking lets see what happens
  20. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-27-2012 11:40 PM #56
    Clutch, Friction Plate and Tranny installed. Motor is in but it was too dark to take pictures.
  21. Member
    Nov 10th, 2009
    San Antonio, TX
    2000 Audi 180Q Aviator Gray
    04-28-2012 09:51 AM #57
    Me gusta the power. Post any engine pic please
    EDIT: Sorry, engine pic WITH turbos
    Sex should be like a Civic; slow, obscene, and loud enough for the neighbors to hear.
  22. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    04-28-2012 02:43 PM #58
    Talk about perspective, the quattro 02m is huge, almost the size of the engine
    ...now get to bolting stuff on, good luck
  23. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    04-28-2012 03:20 PM #59
    Haha...JC, my mechanic said the same thing. The O2M is huge in relation to the motor, and its a heavy beast. The motor looks so different in the car without all the emissions bs. Talk about loads more room and all for nothing. All that extra space is now going to turbos and piping...well worth it, I HOPE!
  24. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-02-2012 07:36 PM #60
    By the way, anyone looking for 225Q parts, I got plenty for sale. If anyone wants them, Im letting them go for cheap, including my old FMIC and upgraded K04. Let me know and I will send you some picks of anything you want.
  25. Member
    Nov 10th, 2009
    San Antonio, TX
    05-02-2012 07:47 PM #61
    Quote Originally Posted by Dowski12 View Post
    What kind of ko4??
  26. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-02-2012 09:32 PM #62
    Its a K04-22 but its been ported out It was only on my car for about 4 months and Im not gonna say I didn't give it some gas here and there but there is no shaft play. I wasn't sure if there was really any difference between mine and a regular K04 but I had my turbo guy check it out and he said its deffinitley been modified.
  27. n00b
    Apr 12th, 2012
    DFW
    03/Audi/TT225q
    05-03-2012 09:53 AM #63
    Im glued.
    Send me a PM with prices on your FMIC and turbo.
  28. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-03-2012 07:29 PM #64
    PM sent.
    Got some more of the poweder coat back. The vlave cover didn't turn out as nice as the SEM. I haven't seen it first hand but if its not up to my standards ill just take it in to get redone when I take my wheels. Im tired of waiting so I can live with it for now.
    Also got my black PTP turbo blankets and black heat wrap in the mail today. Ill have pics of everything thus far this weekend.
  29. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-05-2012 08:44 PM #65
    Bolted on the valve cover and SEM manifold. Turbos will be back from powder coat tonight and starting the layout on monday. Stay tuned
    Dont mind the stock fuel rail, just plugging the injector ports till we get the custom rail finished.
  30. Member
    Nov 10th, 2009
    San Antonio, TX
    05-06-2012 10:14 PM #66
    Ask and you shall recieve. Bolted on the valve cover and SEM manifold. Turbos will be back from powder coat tonight and starting the layout on monday. Stay tuned
    Looks nice. Me gusta
    Can't see the turbos with the engine in the bay, even if they WERE on...
    Need a photo with it out and the turbos on plz
  31. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-07-2012 12:44 AM #67
    Turbos arent in yet. Im going over there tomorrow morning to decide on the layout of where we are going to mount them. JC wants to either put both behind the motor or both on the driver side of the motor. I want one top mounted behind the motor and one on the drivers side. I have final say so we will throw the turbos in tormorrow in different configurations to figure out which works best.
  32. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-07-2012 08:15 PM #68
    Went to the shop today, Intercooler is mounted. We had to trash the crash bar and we might have to trim the bumper, not sure yet.
  33. Member lite1979's Avatar
    Sep 8th, 2005
    Buffalo, NY: Last call 4AM!
    2001 Audi TT 225 QC
    05-07-2012 10:10 PM #69
    So is your rad support the only thing connecting the left and right up front now, or do you still have the old IC pipe on the bottom providing support?
  34. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    05-08-2012 12:14 AM #70
    That transition pipe between the old SMIC's is long gone. We left the mounts for the crash bar connected. Thats what we used for the FMIC supports. We ground the ends off and then welded some thick metal L brackets to it and drilled two holes to connect to the IC, worked out pretty good. So basically yeah, the radiator support is the only thing upfront now. I figure if I wreck in my car I'll probably be doing something extremely stupid, at an excellerated rate of speed and that wimpy crash bar isn't gonna save anything anyway
