Page 7 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
Results 211 to 245 of 292
Thread: 01 Audi TT225 compound turbo setup
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-20-2012 05:15 PM #211
    After talking with Rob, he seems to think the TS setup on such a small frame turbo, wouldn't do very much in the way of spool. He said the GTX3071R would give me just as good spool by itself and paying $1400 for a tubular TS manifold would just be a waste of money. He also suggested a PTE 5558 CEA DBB turbo instead of the GTX. Says it gives better spool at a lower cost. Not sure about Precision though as far as reliability goes. Not to mention all the Precision/Garret crap going on right now, precision is just making themselves look stupid
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-28-2012 02:46 PM #212
    So, more good news. Afte Integrated Engineering got my motor taken apart they found that the last machine shop left all kinds of crap in my motor. As soon as they got the head off, there was a bunch of dirt, hair and metal shavings that they said looked like welding slag, sitting ontop of the pistons. The piston ring lands had dirt and grim in them so when you turned the rings it feels gritty. Also when they painted the block, they got paint in the oil filter galleys, coolant flange ports, and on the bottom of the block where the oil pan is suppose to mate to it. When they pulled my oil pan bolt, it was cross threaded and there was more metal shavings. When they installed my ARP crack damper bolt, they didn't use loctite and it wasn't torqued to spec. Thats all they found so far but I'm sure I will be adding to the list the farther they get into it. Guess I'll be calling Jensen's auto machine shop this week looking for my money back. Modding cars is so much fun
  3. Member Tempes_TT's Avatar
    Oct 23rd, 2010
    Monticello, MN
    2000 180q TT
    08-28-2012 04:12 PM #213
    Quote Originally Posted by Dowski12 View Post
    Quote Originally Posted by DCMS371 View Post
    You do realize women are biologically programmed to ruin men's lives by making them get rid of anything that they might enjoy more than spending time with the woman right?
    Quote Originally Posted by SchmidTT View Post
    Has anyone really been far even as decided to use even go want to do look more like?
    The "This will take longer than it should" build...
  4. Member All_Euro's Avatar
    Jul 19th, 2008
    Calgary, AB
    05' VW GLI
    08-28-2012 04:46 PM #214
    In light of this, and whatever else comes to the surface, it's a good thing you had to switch shops to finish your engine build. Better to find out now than when it's all buttoned up and you're terrorizing the track!
    KO3 @ 30psi...
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-28-2012 04:51 PM #215
    Yeah, for sure. At least the motor is in the right hands now.
  6. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    08-28-2012 05:00 PM #216
    If you are that worried about spool, you could go 2.1l since you dont have the ALH block for 2.2l. That combined with a good awic setup with 2.5" hot side and 3" cold side piping to reduce lag as much as possible. I think I have a total of 2.5-3 ft of piping doing this. Stay away from the tubular manifolds and just go a nice cast PPT or similar to control heat and keep the velocity of the exhaust gases up. I haven't been able to drive enough for a good review on the 5857BB but from the little I got to drive it so far, the spool is definitely bearable and I'm not stroked (yet ) if you stroke it and stay with a 3076 to 5858 sized turbo i think you'll be happy with spool and power. Also, get a vband housing if you can. I really wish I would've
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-28-2012 06:34 PM #217
    We are doing a Billet 5858 DBB on a vbanded housing, .64 A/R, 2.5-3" IC piping, and tubular mani. I'm already goin to be stroked so even with a tube mani I should still get pretty decent spool. I'm pretty sure later on down the road I will re-visit the compound setup using my 5858 and something smaller that will match up good, but for now a single setup is more in my budget after wasting so much money on crappy mechanics.
    Rob also offered to paint my car...well kinda. We are going to do a little plasti dippin just for fun. I'm thinking either doing gunmetal with black accents, or the new matte blue with black accents. At the moment I'm leaning more towards the blue simply because the gunmetal looks too much like primer. The blue is really bright and will definitley turn heads. Rob has plasti dipped cars before so I assume it will turn out pretty decent, but if not it can always come off.
  8. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    08-29-2012 08:39 AM #218
    I hope you took pics of the mess with the motor that way you have proof just in case
    They say they didn't do that
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  9. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    08-29-2012 08:59 AM #219
    Do not do this. Trust me. I've done it and regret it.
    It gets everywhere & it sucks to wash and collects dirt. It also isn't that easy to get off and good luck getting it out of the seals.
    bagsarefordeadhookers
    -TCC
  10. Member poopie's Avatar
    Feb 21st, 2005
    Philadelphia, PA
    08-29-2012 12:10 PM #220
    good choice on the turbo! to answer you earlier question, yes i'm bored and stroked to 2.0l with a journal bearing billet 5858 .63 AR hot side. It is an awesome set up. From what i read, you don't really gain too much on the spool up with the triplex BB 5858, but the response and respool between shifts is much better. With the 2.0l it still feels like it has more torque down low than my chipped tt 225. You are flowing much more air even though you aren't at the same PSI levels.
    The compound set up would be cool, but i think a single turbo set up is more reliable and predictable. If you run into issues i think more people will be able to help you out.
  11. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-29-2012 03:24 PM #221
    Quote Originally Posted by 01ttgt28 View Post
    Yeah, IE took a bunch of pics for me and sent them to my phone and I asked them to take as many as possible so I have something to back me up.
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-29-2012 03:31 PM #222
    Quote Originally Posted by DougLoBue View Post
    Yeah, I remember how much trouble it gave you but the only difference is I have someone else to take care of all that head ache. Im only planning on leaving it on for like 6 to 8 months while I wait to respray my car. At that point I'm gonna sand blast the whole car anyway so I wont have to worry about peeling tiny pieces off at a time. Im gonna do all the prep work myself to save a little money on the respray.
  13. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-31-2012 02:06 PM #223
    Dont know if anyone cares, but this is the look I'm going for on the car once the build is done. Took me like 7 hours using paint on the computer to finish this...dont judge me
  14. Member 1fast2liter's Avatar
    Apr 3rd, 2005
    beaver dam WI
    2000 audi tt 180q
    08-31-2012 03:12 PM #224
    I like it
    Sent from my Motorola Electrify using Tapatalk 2
    infinity front,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, modded 225 exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,
  15. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    08-31-2012 07:08 PM #225
    Thanks
    By the way, anyone looking for an intercooler, I'm selling my brand new Treadstone TR1035, w/completed cold side SS pipe, and I have extra SS pipe to complete the hot side. I'm going AWIC and need to sell it asap to help pay for the fab work. If anyone is interested let me know, I'll let it go for $250 plus shipping.
  16. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    09-11-2012 05:49 AM #226
    Before
    After
  17. Member
    Jul 31st, 2009
    Northern California
    2001 Audi 225 TTQ
    10-04-2012 01:41 PM #227
    Any updates?
  18. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    10-13-2012 04:28 AM #228
    Not really much to talk about as of yet. The motor is back from Integrated Engineering and is in the car. Currently I'm just getting the funds together to complete everything.
    On a side note, I haven't been able to get ahold of JC to get the money he owes me. After talking to a lawyer about the whole situation, I'm thinking the $2400 we agreed on isn't gonna cut it at this point. If I'm going the legal route, might as well go for the full amount plus damages, since JC has decided to give me the run around. I'm pretty sure that A$$hole changed shops too. I've been by his shop about 15 times to try and collect. Every time its closed up and all the cars he used to have sitting out side are gone. Go figure
  19. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-13-2012 08:00 AM #229
    Dame u think he would close up shop over $2000 that's crazy maybe he has some other problem
    Going on ????
  20. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    10-14-2012 01:57 AM #230
    I dont think he changed shops just because of the money. He had already found a new shop, but to my knowledge, he wasn't moving for a couple of months. I think it was just a perfect opportunity to move earlier, and avoid paying me at the same time.
  21. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-14-2012 07:31 AM #231
    Dame that sucks looks like u took th shaft!!!!
  22. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    10-18-2012 09:34 PM #232
    Yeah, with no lube...
    I'm waiting on a quote for the rest of my build. Once I know how much the rest of this is going to cost me, the updates should come a little quicker.
  23. Member All_Euro's Avatar
    Jul 19th, 2008
    Calgary, AB
    05' VW GLI
    10-19-2012 10:30 AM #233
    Your perseverance is noteworthy for sure
    Looking forward to the final results
    KO3 @ 30psi...
  24. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    10-30-2012 03:24 AM #234
    Well, got all the fund together and paid the man...parts are on the way. Waiting on my Precision 5858, a BBM oil cooler, and an AWIC set up to get here. The motor is being picked up for my custom tubular v band manifold tomorrow, so hopefully should have some pics in a week or so
    I'm so glad I get to spend money again, I was going through withdraws
  25. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-30-2012 08:48 AM #235
    [QUOTE=I'm so glad I get to spend money again, I was going through withdraws[/QUOTE]
    Lol!!
  26. 10-30-2012 08:59 AM #236
    "Never argue with stupid people, they will drag you down to their level and then beat you with experience."
  27. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    11-17-2012 04:22 AM #237
    Finally some progress!!!
    Custom made exhaust mani in the works
  28. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    11-21-2012 02:45 AM #238
    Turbo came in today.
  29. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-22-2012 11:42 AM #239
    Two turbos ???
  30. Member
    Jul 8th, 2009
    Kuwait
    2002 Audi TT Quattro LMNS Edition, 2004 R32 4mortion DSG
    11-22-2012 02:25 PM #240
    Two turbos ???
    Same size??
    Quote Originally Posted by groggory View Post
    FAQ'd
    keep up the great work Mr.Groggory
    Reading>posting .
  31. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    11-22-2012 06:32 PM #241
    haha...only one is mine, the other is going on an STI
  32. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    12-04-2012 02:22 PM #242
    BBM oil cooler, pretty impressed with the quality
  33. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    12-04-2012 09:59 PM #243
    Are u ditching the factory oil cooler???
  34. Member
    Nov 2nd, 2011
    Ogden UT
    01 Audi tt225
    12-05-2012 12:11 AM #244
    Yes, the kit comes with a thermostatic sandwhich plate so there really is no reason to keep it.
  35. Member
    Aug 12th, 2010
    Dallas, TX
    2003 Audi TT
    01-10-2013 07:12 PM #245
    Any updates?
