VWVortex.com - 2.0t FSI Warranty extension moved to recall
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 50
    Thread: 2.0t FSI Warranty extension moved to recall
      Jun 15th, 2011
      05 Passat Wagon, 1988 Cabriolet and just added a 2015 Tiguan S
      03-09-2012 10:55 PM #1
      I am sure you guys know by now, but VW has now recalled the intake flap motor, the low fuel pressure sensor, and the PCV and pipe.
      Dealers will be checking and replacing(if needed) the parts on 2.0t FSI up to 10years 120,000 miles.
      Just a heads up folks..
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      03-09-2012 11:12 PM #2
      Quote Originally Posted by Humble Mechanic View Post
      What pipe?
    3. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      VW Mk2 Tiguan TSI, VW Mk7 Golf TSI
      03-09-2012 11:45 PM #3
      Any pointer/link to the recall? I couldn't see anything on the web?
    4. Member
      Jun 15th, 2011
      03-11-2012 02:23 PM #4
      @VWvortex, thanks for moving this
      @Boosted, the pipe that comes up to the back of the valve cover. It has a check valve in it.
      @VW_nc, The only links I have are back office type VW links. I will see if I can find something to link for you. You can call your local dealer and have them check your VIN to see if your car applies. NOT all 2.0t engines have all of the recalls.
      That being said, VW may not be calling them "recalls" It might be more of a required update. Customers are not notified of required updates.
    5. Member BeBop!'s Avatar
      Jun 18th, 2009
      Santa Barbara
      03-11-2012 03:34 PM #5
      Has anyone received an official recall letter from VW?
    6. Member najel's Avatar
      Apr 10th, 2008
      Mankato MN & Bielefeld Germany
      66 Mustang & 03 Jetta GL & 09 JSW TDI
      03-11-2012 04:18 PM #6
      It would be nice to know what the VIN ranges are. When i called my dealer they did not see any recalls or RVUs for my car, just the warranty extensions.
      Thanks for sharing this info!
      Owning a VW is like having a hot girlfriend that's mentally unstable
      Jun 15th, 2011
      03-11-2012 05:10 PM #7
      Quote Originally Posted by najel View Post
      Since all of the info I have is from VW, I am not sure what I can and can not post. They are calling this an UPDATE, NOT A RECALL!!! VW does not have to inform customers of updates. If you have this engine, call your local dealers and have them check your VIN. If you have the action open, go have the dealer inspect it and see if it needs to be replaced.
    8. Member x9t's Avatar
      Sep 19th, 2005
      Bay Area-CA
      07 Passat 2.0T 6MT/96 Passat GLX VR6/ 87 Scirocco 16V
      03-11-2012 06:41 PM #8
      x2 they are not recalls. If your car happends to throw a CEL which is caused by a PCV or the flapper motor they will replace it.
      JT
      Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
      Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
    9. Member low_passat's Avatar
      Sep 11th, 2010
      Goodyear, AZ
      '07 B6 Passat
      03-11-2012 07:36 PM #9
      These were just changed over to a RVU campaign last week according to jhines(dealer tech if you don't know). What that means is if you car falls into the VIN range these parts will be changed if that are different the the p/n's listed below whether you have a CEL or not.
      Quote Originally Posted by jhines_06gli View Post
      Here is VW info:
      IMRC- 24W2 Campaign
      06F 133 482 E
      PCV Stuff- 17D9 Campaign
      06F 129 101 P Valve
      06F 103 215 B Pipe
      Plus the new gaskets and clamp
      Fuel Sensor- 24W3 Campaign
      06E 906 051 K
      2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
    10. 03-11-2012 07:54 PM #10
      i work for vw not alll bpy engines are recalled for the flap motor and the pcv and turbo pipe
      all have warranty extensiuons though...any passat jetta or gti with bpy will get a new pcv and turbo pipe...only passats will get flap unless it goes bad then it will still be free and no low fuel pressure sensor that only gets replaced if the pump takes a crap
    11. Member low_passat's Avatar
      Sep 11th, 2010
      Goodyear, AZ
      '07 B6 Passat
      03-11-2012 08:19 PM #11
      Quote Originally Posted by 2013cc View Post
      No offense, but I'm going to go with the word of one of the most respected techs here on vortex over a guy who registered today and has 1 post.
      Here's the thread in the 2.0T motor forum
      http://forums.vwvortex.com/showthrea...-just-released
    12. Junior Member
      Sep 10th, 2008
      TN
      2007 2.0T 6MT 2013 2.5 SEL-Premium
      03-12-2012 03:18 PM #12
      Is it a recall or warranty extension?
    13. Member insomniac2's Avatar
      Mar 13th, 2011
      Chicago
      Candy White - 08 Passat 2.0T
      03-12-2012 04:23 PM #13
      thanks for the usefull info
      I just called my dealer, they found the just released RVU campaings for PCV and flapper motor for my VIN. taking it in tomorrow to get them replaced !!
      one question, whats this pipe called that you are talking about ? just want to make sure they change it while they are at it.
      Adam
    14. Member
      Jun 15th, 2011
      03-12-2012 09:23 PM #14
      Quote Originally Posted by insomniac2 View Post
      I forget the exact name of it. It goes along with the PCV valve. Out of all of them I have replaced, I have had 1 that didn't need to be replaced.
    15. Member
      Jun 15th, 2011
      03-12-2012 09:26 PM #15
      Quote Originally Posted by SKM348 View Post
      It WAS an extension, now it is a required vehicle update(RVU). That means they will replace it if needed when you go to the dealer. My dealer(ALL are required to) checks RVUs Recalls updates ect, every time a car comes in. Just another + of bringing your car to the dealer
    16. Semi-n00b
      May 9th, 2011
      Rock Hill, SC
      '08 B6
      03-14-2012 12:50 AM #16
      got this done to my car, as i got left dead in the road twice. Had a low pressure cel go on and off for a while then constant on then died the other day and threw an alternator malf light. but the alt was good dealer didnt say what it was but gave me all the recalls
    17. Member
      Jun 15th, 2011
      03-14-2012 11:22 AM #17
      Quote Originally Posted by trey212 View Post
      So your car is running fine now?
    18. Semi-n00b
      May 9th, 2011
      Rock Hill, SC
      '08 B6
      03-14-2012 12:17 PM #18
      it actually died twice in 4 days i was dumb and didnt go to a vw dealer first. but so far its running great
    19. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      03-14-2012 12:47 PM #19
      How long does it take to have this service performed?
    20. Semi-n00b
      May 9th, 2011
      Rock Hill, SC
      '08 B6
      03-14-2012 12:53 PM #20
      Quote Originally Posted by vw_nc_dude View Post
      i had it towed up saturday night, they were closed sunday but they called me saturday morning at like 9:30
    21. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      03-14-2012 12:59 PM #21
      I assume Monday morning 9:30?? So they fixed it maybe in 1.5 hours?
    22. Semi-n00b
      May 9th, 2011
      Rock Hill, SC
      '08 B6
      03-14-2012 01:09 PM #22
      haha correct, they got it done monday morning
    23. Member
      Jun 15th, 2011
      03-14-2012 11:25 PM #23
      If you have all 3 campaigns open, it should take about an hour. We can do them faster, but no need to rush.
    24. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      03-15-2012 03:44 PM #24
      Just called the service department and was told that only the PCV is to be replaced. The intake manifold runner control motor has the warranty extension but apparently is not to be replaced at this time for my vehicle which is a 2008 Passat. Does this make sense or should I press for the intake motor to be replaced as well?
    25. Member
      May 8th, 2005
      Foxboro, MA
      2012 A6 3.0T Prestige, (2008 Passat Lux 2.0T Hi-Def), (1999 Jetta 2.0L)
      03-15-2012 04:22 PM #25
      Hey everyone-
      Had two of the three updates done this week. I dropped the car off for the day so I don't know how long it took.
      For reference, they are as follows:
      UPDATE 17D2 - Positive Crankcase Ventilation
      An update may be required, caused by a malfunction of the crankcase ventilation pressure regulating valve or turbo intake pipe resulting in excessive vacuum or excessive pressure being applied to the engine crankcase.
      The guide pin of the check valve in the intake manifold side of the valve may break, preventing the check valve from correctly sealing when boost pressure is present in the intake manifold. Intake boost pressure may thus be applied to the engine crankcase, resulting in possible oil leaks.
      A whistling noise or air rushing sound may be the consequence of an excessive amount of vacuum being applied to the engine crankcase. This condition can be detected by verifying whether the oil filler cap is being firmly held in position to the engine even after it has been unlocked.
      The fix for this replaces the crankcase ventilation pressure regulating valve, the valve's gasket, two clamps, the turbo inlet pipe, and the inlet pipe's gasket.
      UPDATE 24W3 Fuel Pressure Sensor
      Due to fuel intrusion into the low-pressure system fuel pressure sensor, a false signal may be sent to the controller, resulting in a reading that is out of tolerance.
      I can't say for sure how this helped the car, because I had a lot of other maintenance done at the same time.
