Results 1 to 7 of 7
Thread: Eurovan steering wheel replacement---what will fit?
  1. Member Passat514's Avatar
    Mar 31st, 2005
    WI
    07 Passat 3.6 wagon, '07 Audi Q7
    03-09-2012 10:53 PM #1
    If anyone has replaced their steering wheel on an '01-'03 EV with one from another model VW, can you advise which models had the same diameter/spline arrangement in the hub?
    Our's is disintegrating in the 11 o'clock area (I think its where the PO held their cigarette while driving).
    I recall someone fitting a 3 spoke wheel from a MKIV golf/jetta but never identified if it was a direct fit.
    Cheers!
  2. Member Spectaculiciousnes's Avatar
    May 12th, 2008
    Vancouver, WA
    '78 Rabbit; '85 Quantum wagon; '82 Callaway Rabbit truck; '02 Eurovam MV; '10 Ducati 1198S Corse
    03-11-2012 03:01 PM #2
    I think the mk 4 is one of the ones that fits the splines. The thing with Vanagon & Eurovan steering wheels is they're bigger in diameter though. If you like to rest your arms on the arm rests while steering you won't be able to do that as easily with a smaller diameter wheel. That was a major factor for me. I ended up spending $400 on a Projectzwo leather wheel for my Vanagon when I changed it out
    www.desmolition.com
    Follow me on Facebook at ducatiscotty
    Apr 30th, 2004
    '02 EV MV Weekender, '11 GTI Autobahn
    07-04-2012 04:36 AM #3
    I'm interested in changing the steering wheel too. Is the airbag from the MKIV plug and play on the EV?
  4. n00b zhendos777's Avatar
    Nov 23rd, 2007
    2003 VW Eurovan
    07-20-2012 03:24 AM #4
    I got R32 Steering wheel in my T4. You just have to buy adapter from your local dealership.
  5. Member kafercup's Avatar
    Sep 17th, 2000
    San Ramon, CA
    07-21-2012 02:52 AM #5
    Do you have the part number for the adapter? Also, does the air bag still connect properly?
    Sent from my DROID3 using Tapatalk 2
  6. Semi-n00b
    Nov 19th, 2007
    Aurora, IL
    07-21-2012 09:19 PM #6
    I have a steering wheel from a 2002 New Beetle with airbag advertised in the classified section if youre interested.
    2002 Jetta GLS TDI
    2002 Cabrio GLS
    1994 Porsche 968
    1995 Porsche 911
  7. Member joegull's Avatar
    Apr 19th, 2003
    San Mateo, California
    2012 Golf R
    09-02-2012 10:31 PM #7
    [QUOTE=kafercup;78295099]Do you have the part number for the adapter? Also, does the air bag still connect properly?
    Any luck on that part #?
