Results 1 to 12 of 12
Thread: 96 Jetta 2.0L died
  1. 03-10-2012 05:17 PM #1
    My roommates Jetta died last week while he was driving around and cranks but won't start. Took to shop and have ruled out fuel pump and replaced several parts of the vacuum system. They don't have a computer that scan the car properly. I am hoping to A, maybe get some suggestions I can try on his car and B, maybe find someone willing to lend me a Vag cable. Thank you
    Sent from my LG-C800 using Tapatalk
  2. Member RRADO GIRLIE's Avatar
    Feb 1st, 2009
    Chandler Az
    1992 corrado vr6, 2007 2.0T Passat, 1990 suzuki samurai w/toy conversion 2.0 aba soon.
    03-10-2012 08:01 PM #2
    Try the specific thread to the car as well. mk3 Jetta thread the guys could be a lot more helpful in ideas
    Burt Reynolds <3 Yes I have trans Am snowflakes on my corrado. NO you cant have them
  3. Member VWnutAZ's Avatar
    Apr 6th, 2005
    Phoenix, AZ
    1996 Golf SYNCRO,2005 Prsche Bxster S, 2004 R32, 1996 R CabrioVR6, 1998 Jazz Blue VR6 Syncro project
    03-10-2012 08:19 PM #3
    try the crank position sensor.....
  4. Member boraIV's Avatar
    Jan 8th, 2001
    six.oh.two.
    '13 Cayenne Diesel, '08 Passat Variant 2.0T Stg 2, '81 ABA Caddy
    03-10-2012 11:01 PM #4
    Quote Originally Posted by VWnutAZ View Post
    this
  5. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    98 GTI VR6 S/C, 98 GTI VR6, 02 2.0L 5 speed jetta wagon, Haro Mirra 540 Air
    03-10-2012 11:55 PM #5
    try to diagnose if it is getting air fuel and spark
  6. 03-13-2012 03:52 AM #6
    We finally found a universal scanner that would work and it only popped one code P1582, which it said was Idle Adaptation at limit. NO clue what that means
    Sep 11th, 2009
    PHX
    03-13-2012 09:54 AM #7
    That wont prevent the car from running.. - You verified fuel supply? Do you have spark?
  8. 03-13-2012 11:30 AM #8
    Should've gave us a shout before your friend took it to that so-called shop. part changers aka hacks just waste the customer's time and money. To get back onto the subject, I would start where Jason suggested. check air, fuel, and spark as thats only what an engine needs to run. Then its a matter of finding what component is causing the issue. ABA's are pretty simple, as its really only like 4 sensors that are inputs to the ecu to control all that.
  9. Member DubsesdA3's Avatar
    Mar 13th, 2005
    PHX, unfortunately
    '98 K2
    03-13-2012 09:29 PM #9
    Any chance he'd sell it in the current non-running condition? I'd be all in.
    • FS: 2 Early Westy Grills for MK1
    DIYAUTOFTW
  10. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    03-14-2012 10:50 PM #10
    Timing belt.
    Check it.
    it should throw codes but you never know.
  11. 03-22-2012 07:23 PM #11
    If he decided to sell it i will be sure to have him let you guys know.
  12. 04-10-2012 03:52 AM #12
    For anyone interested, he is wanting to sell. It is a 96 Jetta Trek Edition 2.0L 5-Speed Manual. Would have to double check on the mileage. Body has some minor damage, tune up done kinda recent he said, clutch is less than a year old. I can get pics for any interested. He is looking to get $800 for it
