I didnt know the maestro could change the hard code due to not using the stock lpfp
Or do antilag/boost by gear/or delete bs sensors that cause issues for no reason. If you honestly think the maestro is the best thing then you got another thing coming. The maestro is nothing compared to hondata and hondata is nothing compared to motec. Fk it takes 15-20 minutes to read and write the files and you need to do it 10+ times for a dyno tune.
If you knew the capabilities of this motor and how much these "tunes" are holding us back then you would understand. Hell John made more power then Jeff did and didnt use meth or a race file. Just think he destroyed well built cars numbers with just a tune a pump and a fpr. He still has plenty of room to go as well.
This is the second post you tried to correct me with less experience then what i have. I was the first outside of Chris and Arnold to have the maestro on a med9 which was 18 or so months ago. I very well know how the program works. Ive had giac revo tapp and maestro, and all were fine but definitely not race tunes. I would not use them on a car looking to make serious power. The maestro for the med7 is way more advanced then the med9 version and there isnt anyone making the power im going for or run the times im looking to run.
Dont get me wrong, if someone did not go so extreme as i did then it could work in the 500 range but after that your going to have to mickey mouse different computers to get it to the same quality of a sem tune. And if you wanted to get a drag quality tune then you would need other electrical components to make the car efficient.
If you have a personal problem with me please pm me like you did before and we can work it out again. Maybe you didnt elaborate as much as you should have but believe me i know these engines and computers very well.
