Results 1 to 6 of 6
Thread: Rear strut mount question.
  1. Member ZuluB602's Avatar
    Aug 31st, 2010
    Utah
    GLI 06 manual deep black, A4 02 manual denim blue, Golf MKIV 2.0
    03-11-2012 01:07 AM #1
    I have a 2006 GLI and I'm planing on changing my suspension (lower it). and I want to replace my rear shock mounts too, I bought some rear shock mounts from ECStuning.com but they sent me the round ones but my car has the oval shape ones, my question is : Are these mounts interchangeable? Will these rear round mounts fit on my car with the oval ones?
    Thanks for the help on this topic.
    this is what I have: (oval mounts)
    GLI 06 2.0T FSI deep black pearl
    BSH True seal intake | K&N DryCharger air filter wrap | BFI Dogbone mount | LED lights | Hoen Xenonmatch fogs | Philips HID ultinon 6000K bulbs | Eibach Sport-System suspension | ATE Super blue | NewSouth Boost gauge/Pod | SunTek 20% Window tint | BORBET TS 18" wheels | Yokohama Advan Neova 235/40R18 tires | Vredestein 225/45R17
  2. Member ZuluB602's Avatar
    Aug 31st, 2010
    Utah
    03-12-2012 07:57 PM #2
    anyone??
  3. 03-13-2012 04:26 PM #3
    Those don't look oval. Pics of the ECS mounts?
  4. Member ZuluB602's Avatar
    Aug 31st, 2010
    Utah
    03-13-2012 10:10 PM #4
    this is the round one> I took this picture from a GTI MKVI
  5. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    03-13-2012 11:02 PM #5
    they might have sent mkvi ones. mine were oval.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  6. Member ZuluB602's Avatar
    Aug 31st, 2010
    Utah
    03-14-2012 09:42 AM #6
    Quote Originally Posted by Krieger View Post
    interesting, seems like only early 2006 audi A3, golf and jettas had those oval rear mounts, but I think we can always replace them with the round ones, the distance between the two mounting bolts is the same on both (124 mm). only problem is that im gonna have to buy the round bump stops too in order to fit the mounts (urotuning.com $14 each)
