VWVortex.com - Rough Idle, Misfire Codes, 2003 Passat 1.8T Auto
    Results 1 to 2 of 2
    Thread: Rough Idle, Misfire Codes, 2003 Passat 1.8T Auto
      Feb 4th, 2003
      Massachusetts
      2013 CC R-Line, 2008 Passat B6 2.0T
      03-11-2012 07:36 PM #1
      Hi,
      Today my wife complained of a rough idle when she started her car in the morning. Sure enough, it was rough uintil the engine warmed up and then it seemed fine. This has not happended before.
      Some history:
      Today 127K+ miles
      • Timing belt replaced 6/10 103K miles
      • coil packs replaced under warranty 03/11 114K miles
      • engine coolant temperature sensor replaced 03/11 114K miles
      Full scan below:
      VCDS Version: Release 11.11.2
      Data version: 20120126
      Sunday,11,March,2012,18:27:58:24571
      Chassis Type: 3B - VW Passat B5
      Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
      VIN: WVWMD63B43P198650 Mileage: 205630km/127772miles
      Address 01: Engine Labels: 06B-906-018-AWM.lbl
      Part No SW: 4B0 906 018 DA HW: 8E0 909 018 A
      Component: 1.8L R4/5VT G 0004
      Coding: 0016551
      Shop #: WSC 00028 000 00000
      VCID: 63CF419EA14E99B
      2 Faults Found:
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 008 - - Intermittent
      16685 - Cylinder 1
      P0301 - 008 - Misfire Detected - Intermittent
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 01V-927-156.lbl
      Part No: 3B0 927 156 AH
      Component: AG5 01V 1.8l5VT USA 0810
      Coding: 0001104
      VCID: 6CDD2AA24C90D63
      No fault code found.
      Address 03: ABS Brakes Labels: 4B0-614-517.lbl
      Part No: 4B0 614 517 P
      Component: ABS/ESP front 2330
      Coding: 04277
      Shop #: WSC 01080
      VCID: 2E59E0AAEA0C643
      1 Fault Found:
      01119 - Gear Recognition Signal
      35-10 - - - Intermittent
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 1C0 909 605 C
      Component: 09 AIRBAG VW61 04 0001
      Coding: 12345
      Shop #: WSC 00028
      VCID: 244D0282B4C0DE3
      Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
      Part No: 3B0 920 927 B
      Component: KOMBI+WEGFAHRSP VDO V08
      Coding: 07235
      Shop #: WSC 00000
      WVWMD63B43P198650 VWZ7Z0B5975441
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 00028
      VCID: F0E5BED2B0B8B23
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 C
      Component: 08 Komfortgerát HLO 0003
      Coding: 00258
      Shop #: WSC 00028
      VCID: 3777C5CE1556A5B
      Subsystem 1 - Part No: 1C1959801
      Component: 08 Tõrsteuer.FS KLO 0004
      Subsystem 2 - Part No: 1C1959802
      Component: 08 Tõrsteuer.BF KLO 0004
      Subsystem 3 - Part No: 1C0959811
      Component: 08 Tõrsteuer.HL KLO 0008
      Subsystem 4 - Part No: 1C0959812
      Component: 08 Tõrsteuer.HR KLO 0004
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 3B7 035 180
      Component: Radio NP2 0012
      Coding: 00401
      Shop #: WSC 00028
      VCID: DDBBF766572A2FB
      1 Fault Found:
      00878 - Connection to Speaker Front Left
      44-10 - Short Circuit - Intermittent
      End ---------------------------------------------------------------------
    2. 03-11-2012 11:01 PM #2
      Check the
      :::::ALERT FORUM ACTION EMERGENCY MESSAGE:::::
      THIS POST MOVED/VACATED BY JACK TO PROTECT CONTENT FALLING INTO THE GAPING HOLE OF THE VORTEX
      IT SEEMS NO GOOD DEED GOES UNPUNISHED!
      http://www.youtube.com/watch?v=HaoySOGlZ_U
      Just email or PM John Acton@VMG as to why I have chosen to do this for a modification answer to these posts.....
      Ultimately this is his fault for how the account was handled.
      john@vortexmediagroup.com
      You could say I feel insulted and abused..........
