Results 1 to 9 of 9
Thread: timing belt then blow up????
  1. 03-11-2012 11:47 PM #1
    i just did a timing belt and head gasket on a 2.8l avant.
    it ran before i did this.
    i got it all back together today and cleared all the fault codes. none popped back up.
    i did a TBA and it went through well and it still idled funny and no throttle response after.
    i was holding the gas to the floor and it started to idle better. then there was a loud bang twice and then it just jumped up to red line and then shut off...
    any input please help.
    Quote Originally Posted by SoIAteAPancakeToday View Post
    it would whisper in your ear, "lrn2offsetbrah."
  2. 03-13-2012 05:24 PM #2
    bump i just had someone on the A4 B5 forum say i blew up the motor and i dont see how that couldnt happened. everything was oiled and this happened in under a minute it wasnt hot or anything. ugh please anyones input please.
  3. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    04-07-2012 11:01 PM #3
    cam timing off
    valve hit piston
    valve broke off
    engine locked up
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  4. Member
    Jul 19th, 2007
    Anacortes, wa
    2012 Jetta Tdi, 2007 Jetta 2.5
    04-17-2012 02:15 AM #4
    no good
    2012 Jetta Tdi
    H&R sport springs
    15% tint
    VW Technician
    VAGCOM equipped, willing to help with it if in pacific NW area. Hit me up.
  5. Member kfzmeister's Avatar
    Apr 15th, 2004
    Paxton, IL
    '04 Bugatti wagon, '85 V65 Sabre
    04-19-2012 11:48 AM #5
    I agree, things do not sound good. I'm currently repairing a 30V V6 that had the timing off a notch and it bent two intake valves (cyl1&4). Those pistons are dished and virtually no clearance.
    Good luck.
    Has Seb got a girlfriend? Could Mark pork her perhaps?
  6. 04-22-2012 12:56 AM #6
    so if valves are bent but not broken, replacing the valves will solve the problem?
    I mean, the piston looks good in my car, I was wondering if there could be some damage beyond what is visible in such case.
  7. Member kfzmeister's Avatar
    Apr 15th, 2004
    Paxton, IL
    04-25-2012 04:46 PM #7
    Typically replacing the valves is all it takes, providing pistons are o.k.. You have to have some proper equipment to do the job, like a spring compressor and a timing bar when you put it back together.
  8. 04-28-2012 04:04 AM #8
    so what exactly makes the difference between bent and broken valves? or is it just a matter of luck?
  9. Member tryin2vw's Avatar
    Dec 29th, 2006
    Greensboro, NC
    99 MK3 and 98 MK3 2.0, '01 B5.5 1.8T
    05-05-2012 08:57 PM #9
    Luck between bent and broken. In the original TB replacement, was the cam-bar/crank pin used to set the timing? Were the cams and chain tensioner installed properly in both heads? These are items that can cause rough idle when replacing heads.
