VWVortex.com - How to reset airbag light?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 36
    Thread: How to reset airbag light?
      Jan 29th, 2008
      Camas, WA
      1976 VW Rabbit, 1997 Jetta GLS
      03-12-2012 03:23 PM #1
      I recently had to replace the ignition switch on my wife's 1997 Jetta. When I took the steering wheel off, the airbag clock spring fell apart. I tried to reassemble it and it seemed to work OK for a few weeks. Then the airbag light came on last week. I bought and installed a new airbag clock spring, but the airbag light is still on.
      My normal Actron OBDII scanner did not show any error codes, and resetting the codes did not turn off the airbag light.
      So, I am wondering what the easiest/cheapest way to turn off the light is.
      From my searches it looks like I need vag-com and an interface, but I don't know which items to buy. The Ross-Tech site lists some very expensive products!
      I also want to retain the safety of the vehicle, thus no bulb pulling or resistor hacks.
      Thanks,
      Anthony
    2. 03-12-2012 03:37 PM #2
      Unplug the lights.
      You asked for the easiest and cheapest way. There it is.
    3. Member BlueDevilCabby's Avatar
      Jul 6th, 2006
      Grand Rapids, MI
      97 Cabrio / 95 Harley Jetta / 94 GTI
      03-12-2012 03:57 PM #3
      Quote Originally Posted by McDubin View Post
      Unplug the lights.
      x2. If you want to get rid of it, FIX IT. That's the only way you're going to get it to go off...
    4. Member
      Jan 29th, 2008
      Camas, WA
      03-12-2012 04:16 PM #4
      I did fix the air bag spring. I just need to reset the light.
    5. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      03-12-2012 05:05 PM #5
      You can find someone with VAG-COM to help. generic OBD2 readers only work for engine stuff, everything else (auto trans, ABS, airbag) is proprietary.
      If it's just that one light, i wouldn't bother actually buying VAG-COM, you can pay someone else to do it (or maybe even they'll do it for free). Ross-Tech's stuff is 2-300$ (depending on if you need a serial or USB interface). This might help.
      http://vagtoolfinder.com/
    6. Member 95jetta17's Avatar
      Jan 20th, 2008
      York, PA
      95 2.0 turbo, 97 vr6
      03-12-2012 06:04 PM #6
      vag-com
      OG suede
      I survived epic thread 2011 never forget 11/11/11
      Quote Originally Posted by vastxpunk View Post
      You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
    7. 03-12-2012 06:49 PM #7
      Even with the Vag-Com system, your probably not going to be able to clear the airbag light. It's most likely going to read high or low voltage signal for the airbag, and once you clear it, it comes back shortly after.
      A lot of MkIII's that I've come across have this same issue or code, and I've never heard or come across any way to physically get rid of the light other then unplugging the light.
      I believe t's just one of those things on MkIII's, but this doesn't mean that the airbag isn't functional. This is the impression I've always been under with my knowledge of the code, until literature or someone educates me otherwise
    8. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      03-12-2012 08:19 PM #8
      Ask someone with a VAG.COM setup. Should clear it quickly..
      I have a cheap-VW-Ebay scanner - it also works just as well.
      http://www.ebay.com/itm/V-CHECKER-V2...9d97de&vxp=mtr
    9. Semi-n00b
      Oct 2nd, 2011
      1998/vw/jettaGL/98 wolfsburg edition
      03-13-2012 12:56 AM #9
      After ALOT of driving my light went off... but then.. my exhaust broke and the vibration set it on again
    10. 03-13-2012 01:19 AM #10
      if the light doesnt clear, you may need to replace the clock spring. easy fix
    11. Member
      Jan 29th, 2008
      Camas, WA
      03-13-2012 09:45 AM #11
      For those who didn't read my first two posts. I ALREADY replaced the clock spring!
      After examining a number of options, I ordered a MaxScan VAG405:
      http://www.amazon.com/MaxScan-VAG405.../dp/B005WGR22Q
      http://www.auteltech.com/vag405.htm
      It "claims" it can read and reset many VW codes including the airbag light. I figure I can use it for reading other error codes in the future even if it doesn't work for the airbag light.
      I will report back once I receive it and give it a try.
      Anthony
    12. Member tylerlb's Avatar
      Jun 13th, 2004
      Ottawa, ON
      03-13-2012 10:16 AM #12
      Quote Originally Posted by baker3 View Post
      This is a loose ground and the light never really went off it just lost its poer source.
    13. Junior Member SkyVan315's Avatar
      Jul 3rd, 2011
      Downingtown, Pa
      2001 Audi S4
      03-13-2012 10:44 AM #13
      Just replace your airbag module bud.
    14. Member VrFiend's Avatar
      Sep 18th, 2008
      Iowa
      95 Passat GLX, 95 Jetta GLX
      03-13-2012 10:45 AM #14
      I used a cheap 15$ ebay cable and vcds lite to clear the airbag light on my 94 jetta
    15. 03-13-2012 11:07 AM #15
      mine had the same light , good to see some cheaper alternatives other then a 300 dollar vag
    16. Member LG6R's Avatar
      Oct 20th, 2003
      VW & MB
      03-13-2012 03:18 PM #16
      Quote Originally Posted by Accordman View Post
      HA!
    17. Member
      Oct 10th, 2008
      Hershey, PA
      99 Passat 1.8T
      04-29-2012 08:06 AM #17
      Another source of the the airbag light problem is a bad solder connection on the instrument cluster. If the diagnostic software doesn't show any airbag fault codes, but the light is on, it could be the cluster. Sometimes you can check this by rapping on the instrument cluster with your fist. If that causes the light to go on or off or flicker, you found your problem. If that's it, it's an easy fix. Pull the cluster. On the back there are two harness connectors. Where these connectors solder to the board is the problem area. Resolder all the connector pins for both connectors.
      The instrument cluster solder connection problem also can cause carzy temperature gage activity and trip computer problems on GLX cars.
    18. Member
      Oct 10th, 2008
      Hershey, PA
      99 Passat 1.8T
      04-29-2012 08:09 AM #18
      Quote Originally Posted by b4glx View Post
      If you do this you can optionally go online and buy a $99 license to make your VCDS package fully functional. It's a great deal. With the license you can do throttle body alignments and I/O testing. At least I think they still offer this option.
    19. Member
      Jan 29th, 2008
      Camas, WA
      04-29-2012 01:19 PM #19
      In my case, the light is on and I'm getting an error code about high resistance (don't remember the exact code at the moment). That makes it sound like a bad connection, but I've checked everything multiple times and can't find anything wrong. I installed a new clock spring, so I don't think that's the problem, but at this point I don't really know.
      > MaxScan VAG405
      As I mentioned in an earlier post, I ordered the VAG405. It worked great to read the codes ONCE. Then it quit working. I tried several things to make it work, but ended up sending it back.
      I was rushed for time, so I bought the VAGCOM cable from Amazon.com and downloaded the VCDS Lite software. I can read the airbag code, and perform the operation to clear the airbag codes, but the light comes right back on as soon as I start the car. Still getting the high resistance error.
      At this point I've tried about everything I can think to try. I have an evap emissions code I can't track down either, despite more than a year of searching. So, I'm ready to admit defeat and let a shop deal with it. Life's too short to pull out my remaining hair on these things.
      Anthony
    20. Member
      Oct 10th, 2008
      Hershey, PA
      99 Passat 1.8T
      04-29-2012 08:29 PM #20
      Quote Originally Posted by awatson View Post
      Anthony
      What was the code?
    21. Member
      Jan 29th, 2008
      Camas, WA
      04-29-2012 10:15 PM #21
      What was the code?
      It has been several weeks since I read the airbag codes, but I think it was 00588 - Airbag Igniter: Driver side (N95). Resistance too high.
      Anthony
    22. Member killercoconuts's Avatar
      Nov 24th, 2008
      Connecticut
      2010 Jetta 2.5L 1986 Scirocco ABA 1998 Golf ABA 2004 Harley Davidson Heritage Softail
      04-29-2012 10:37 PM #22
      I'd put money one the fact that you probably installed the clock spring wrong. they're very finicky about correct installation. they need to be wound so many ways one way, and so many ways the other to accommodate for steering wheel turns. But if you DID install it correctly, stop by your local stealership and have them hook it up to their VAS-5051 or 5052a(whatever model they happen to use) and they can clear it easy. When you break an airbag piece the airbag control module sets a hard code for the bag light. after the part has been replaced, the code status will change from static(hard code, can't be cleared) to intermittent. Once its intermittent it can be cleared.
      trust me, i worked at vw dealer in the shop and did airbag work. this will solve your issue.
      I like ride height alteration in either direction.
    23. Member
      Jan 29th, 2008
      Camas, WA
      04-30-2012 12:36 AM #23
      The new clock spring came with a note saying the spring was zip tied in the center position ready to install when the wheel was centered. Kind of a no brainer installation, but anything is possible.
      How long does it take before the error goes from static to intermittent? Does it do this automatically? Do you know if the VCDS software can clear the code once it's intermittent?
      Thanks,
      Anthony
    24. Member killercoconuts's Avatar
      Nov 24th, 2008
      Connecticut
      04-30-2012 07:37 AM #24
      Usually it sets to intermittent once its installed and the key is cycled. Ross tech should be able to clear it. Never personally used vcds though. Just the VW scan tool.
    25. n00b
      Apr 30th, 2012
      Glen Burnie, Maryland
      1998 Jetta GLX
      04-30-2012 12:38 PM #25
      How much did the clockspring cost you?
