VWVortex.com - Adjusting ignition timing
    Results 1 to 3 of 3
    Thread: Adjusting ignition timing
    1. Member Poody's Avatar
      Jun 13th, 2011
      Springfield, OR
      BMP 20th AE GTI
      03-13-2012 06:51 AM #1
      I think i have a good enough understanding of how WMI works and how it benefits my cars performance, but if I install a stage II kit, how is the spray controlled? I heard that the water/meth doesn't do ANYTHING unless you adjust ignition timing. Does this mean I will have to have my car retuned after installing the kit, or is this something that the ecu will handle on its own?
      Sorry if this is a nooby question
    2. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
      03-14-2012 06:42 PM #2
      it cools intake charge, and allows your car to advance timing as needed. You can unlock power you were losing, for sure... but most of the gains do indeed come after a tune.
      2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
    3. 04-08-2012 09:46 PM #3
      these cars lose alot of power when they get hot, and they are inconsistent in power delivery. With A water injection setup they are more consistent and lose less power due to intake temps. They pull less timing due to heat induced knock as well. If you have a high boost setup pulling several degrees of timing you will feel a bump in power just from the water. If you dont have any timing pull unless heat soaked you probably won't feel much power change, except that you will not heat soak as easily.
