Anyone?
#1
Hello Everyone,
I'm new to the forum and here to say hi and ask for your expert help.
Here is my first scan. A lot of errors! I'm seeing some engine faults as well which are scarring me...
My Car is an Audi A4 2009 2.0T Quattro Automatic (6speed) with 64150kms, with the warranty ending at 80,000km.. So I want to fix all the problems before then.
Im having some bad gas millage on my car. I'm getting about 500km on a full tank of 91Octane Shell Gas and I baby the car, 90% highway at 110km/h.
My car is stock.
History of my car
55,000km regular audi maintenance.
At 58,000km i failed the oil consumption test and they put new piston and rings.
At 62,000km I put in new spark plugs.
My Electronic brake gave me a few errors and the Dealer is replacing my EPB switch on Thursday.
Tuesday,13,March,2012,14:41:20:53411
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 14 15 16 17 19 1B 2E 36 3C 42 46 47 52 53
55 56 62 72 77
VIN: WAULF68K89N01XXXX Mileage: 64150km/39860miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H12 0001
Revision: E1H12---
Coding: 0104010A190F0160
Shop #: WSC 94827 999 53681
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F3141AF8C273B
2 Faults Found:
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [032] - De-Energized Performance Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
4735 - Fuel Pump
P3044 00 [096] - Short Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 63920 km
Date: 2012.03.03
Time: 14:20:35
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0020
Revision: --H04---
Coding: 001002
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 3669DF26895C5C3
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 152500
Shop #: WSC 02399 823 56573
VCID: 7BFF0E12FAFE41B
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 84
Mileage: 63566 km
Time Indication: 0
Date: 2012.02.23
Time: 03:21:33
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x0016
Hex Value: 0x0990
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 0D0100
VCID: 75EB182ADCDA17B
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0107.07.080085
Coding: 64002000
VCID: 72E12336ADB4003
1 Fault Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 63979 km
Time Indication: 0
Date: 2012.03.04
Time: 16:26:39
Freeze Frame:
Voltage: 13.20 V
Temperature: 20.0°C
Temperature: -1.0°C
Count: 11371
Count: 11703
Bin. Bits: 01000000
Bin. Bits: 00001111
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000172165
Coding: 26001096463CAF311F00080300003D0D0F1CD3480001016100 0000
Shop #: WSC 94827 999 10147
VCID: 3065E93E6338723
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010708 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024B2D
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
1 Fault Found:
03207 - Charisma Switch Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 63738 km
Time Indication: 0
Date: 2012.02.27
Time: 16:05:00
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 17060800540003
Coding: 050181
Shop #: WSC 94708 999 82916
VCID: F0E5A93E23B8B23
1 Fault Found:
03264 - Functionalty Shut Off
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 64102 km
Time Indication: 0
Date: 2012.03.10
Time: 14:32:34
Freeze Frame:
Error Code: 9
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H26 0410
Serial number: 0039GD128TWR
Coding: 30453635423030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3D7BC00AAC6A8FB
Crash sensor for side airbag; driver side:
Serial number: 6334MSME3D532F21H
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME38732B68M
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME77184325E
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME757A3017I
Crash sensor for front airbag; driver side:
Serial number: 63732SME7244103BV
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7D2E30196
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HG9000GY
Coding: 000016
VCID: 3E79C706A96C943
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 HW: 8K0 920 900
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 98R33JC78
Coding: 8B0609003A000008020000
VCID: E7D7C262167675B
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 J HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0091
Revision: HB102039 Serial number: 3900H083188096
Coding: 000303
VCID: 4895A1DEFBA8DA3
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 B HW: 8K0 907 144 B
Component: DYNAMIKLENK. H05 0490
Revision: 50000003 Serial number: --------------
Coding: 0C0000
VCID: 2E59F746790C643
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H06 0290
Revision: 00000000
Coding: 020302
VCID: 3973D41AB042B3B
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001103067
Coding: 00581B00000000000000
VCID: F7F7922246D6E5B
1 Fault Found:
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 64111 km
Time Indication: 0
Date: 2012.03.11
Time: 15:00:53
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0040
Revision: 00H01000 Serial number: --------------
Coding: 0000001
VCID: 3669DF26415C5C3
Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0040
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007402591
Coding: 011C13204E00410001
VCID: 3F87BA02AE669DB
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112743714
Coding: 0106023A007A440500B001
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 19
Reset counter: 110
Mileage: 64004 km
Time Indication: 0
Date: 2012.03.04
Time: 20:26:34
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010102
VCID: 6ED93746B98C243
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007431534
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000165972
Shop #: WSC 00000 000 00000
VCID: 3163EC3A68327BB
2 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 7
Reset counter: 44
Mileage: 63566 km
Time Indication: 0
Date: 2012.02.23
Time: 03:17:07
Freeze Frame:
Voltage: 12.20 V
Count: 38
Speed: 0.0 km/h
Hex Value: 0x0160
Hex Value: 0x0008
Hex Value: 0x0101
02442 - Function Lamp in Control Head
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Mileage: 63738 km
Time Indication: 0
Date: 2012.02.27
Time: 16:06:41
Freeze Frame:
Voltage: 11.90 V
Count: 72
Speed: 0.0 km/h
Hex Value: 0x0170
Hex Value: 0x0008
Hex Value: 0x0101
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000020
VCID: 3065E93EA338723
Part No: 8K0 941 329
Component: AFS-Modul links H01 S001
Component: AFS-Modul rechtsH01 S001
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1031016
Coding: 240200020101870003D9270800
VCID: 4085B9FED398E23
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 115
Mileage: 62388 km
Time Indication: 0
Date: 2012.02.04
Time: 18:26:38
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 64111 km
Time Indication: 0
Date: 2012.03.11
Time: 15:00:54
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007407583
Coding: 010C13204000210001
VCID: FF077A026EE6DDB
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007426782
VCID: FEF9870669ECD43
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 A HW: 8T0 862 336 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005006293
Coding: 0010370
Shop #: WSC 94827 999 179274
VCID: 3973D41A7042B3B
End ---------------------------------------------------------------------
#3
I'm not an expert, but I'm wondering if some of those are transitional. Did you try to clear the codes to see what came back?
John
I'd stop drinking beer, but I'm no quitter.
#4
I did a clear codes at 62,000km when they put in new spark plugs. That's why it is clean before that date.
Below are the errors that were there before the clear.
1)
2)
4735 - Fuel Pump
3)
#5
IGNITION SWITCH! or MODULE for it.
Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
#6
At the dealership. I'll let you know what they change.
Currently, PBD switch is going to be changed.
#7
Doubt that... On the B8 models the switches do fail quite often but they usually show totally different symptoms. Start with some more basic fault finding and unless you see a true indicator for these codes having a common cause - handle them if they are separate issues.
#8
Cool Sebastian, so whats your idea vs " ha ha ha haus, I doubt it?"
Apparently your back and want the helm.
All yours!
Oh, modified, so now they FAIL! At least your still Cool
#9
Update:
Dealer called me they are replacing the EPB switch and the Alternator.
They are still looking for the other problems now.
#10
Sure,..... a sporadic charging condition is also possible for sure.
If this is the case, ask them if the B+ is getting hot back the fuse box and battery.
Inspect the battery for overcharge condition of acid sweat traces and vent caps.
Also re verify tension of battery terminals if this is the case of getting hot.
If any acid is leaking use baking soda to stop the reaction.
#11
Before I brought it in, I took a quick look at the battery. It looked good but I'll tell them to check it out. Thank you.
I also wrote down some readings in the measuring blocks. While the car was on.
Battery Voltage = 12.4 V, Battery Current = 0.0A, Battery Temp = 3C
Battery State of charge (SOC) = 59%, Battery State (shown in MMI) = 70%, Battery Aging (derived fr load) = 88% , Battery Aging (derived fr output) = 122%.
Internal Battery Resistance actual) = 5mOhm, Internal Battery Resistance (stan) = 3.2mOhm, Battery Capacity = 21Ah, Quiescent Voltage = 12.4V
#12
Update: Dealer called me they changed the alternator and the EPB switch.
They did a scan on the car and they saw only the suspension fault but did not see the two engine faults. They told me we don't know what tool you are using but we can not see those faults. If they are not shown on our system we can not move further.
Any ideas why the Audi's scan can not see those errors?
#13
Please see the section under "aggressive mode"
http://www.ross-tech.com/vcds/tour/dtc_screen.html
VCDS Diagnostic System For VW/AUDI/SEAT/Skoda/Bentley
www.Ross-Tech.com
#14
I went to start the car and the cluster flickered again. I showed the tech and he said it's probably the ignition switch, the garage was closed. So we will see on Monday.
I checked the documentation from the dealer and guess what... They did see the error.
EXACTLY like VCDS I got!! Ross-Tech Cable ROCKS!!
They also did a battery test. Looks like it wasn't getting a charge before.
Looking at the notes it says here
Preformed generator output test off load 12.84V and 12.55V on load. Specific 13.5. Output to low, changing generator. That's probably why they changed the alternator.
#15
They said they have replaced the main relay and that is what was causing all the other errors.
What about the fuel pump error?
4735 - Fuel Pump
Should I erase everything and see if it comes up again when I get the car?
#16
#17
Spoke to soon...
While driving today the Radio turned OFF and ON (The Screen and Music went off and on) for a second.
The cluster once in a while flickers randomly.
Any ideas?
#18
My Camera can't capture the flicker on the cluster display but i noticed the door lights also flicker. It's hard to see but to my eyes its as if someone is playing with the brightness lower and higher very quickly.
Here's the video
http://www.youtube.com/watch?v=LRyFKACVq1o
#19
!!!! AAHHHHHHHHHHHHHHH
Today I drive the car, all day put about 100km. I park for 30min to get a coffee, come back and the car is DEAD. Won't start. No Power at all, no lights nothing.
I call CAA, they come to jump the car, car turned on. Everything reset (2008 reading on the mmi), car would crank but won't start.
The Alarm started to ring after it failed to turn on.
He took off the jump battery and the car started fine...
W T F!!!
I dropped off the car at the dealership again...
A short?
#20
Please consider post #5 even though Sebastian doubts it.
#21
I asked the dealership and they told me they replaced the main relay which is the iginition switch/module. Part# AUD 4H0951253A.
Is that it? or is it something else?
#22
Ahhhh No, that is the blower motor relay.
More like this for the actual switch unit.
8K0-909-131C or D depending on chassis.
& then of course the newer part # could be tried 8K0-907-064CS vs AG.. In VCDS 05
Or
Supply controller 8K0-907-063D
Revision: 00002001
Coding: 0D0100
#24
Doubt it. If that wire is corroded what others are?
Is the car a flood.
If the CAN was down you would have errors for messages lost usually.
It is possible though.
If this is the case, I would want to know for sure where the water leaked in, on such a new car.
#25
Thanks for the heads up. I will talk to the mechanic and ask him to show me when I pick up the car today. I'll take pics and post them.
The car has never been flooded. I live in Montreal Canada. We don't get floods. But what we do get is lots of salt thrown on the road. How did the salt and water get there is the question and what other wires corroded...
#26
Problem is still there...
Here is what the dealer did. The mechanic wasn't there but here are the notes.
Here is the of the problem
http://youtu.be/HKP27s8pxLA
#27
Ever since I've gotten the car back Thursday I've erased all the errors and driven it 200kms.
No errors in VCDS.
I'm having two issues.
1) Power Flickering in the LCD and all the electrical bulbs.
2) The Radio Screen and music Turn off and then back on after a second.
Here is an example
i) http://www.youtube.com/watch?v=0tVGlUQg6oE
ii) http://www.youtube.com/watch?v=q07uWZ2mcOc
After I leave the car off all night then use it, it usually happens within the first minute. It also happens randomly.
#28
Connectivity issue I think.
Have you run an alternate ground strap from battery to body?
I would.
#29
Car is at the dealership. I just passed by today to check up on them, they have NO CLUE. They are waiting for a response from Audi's Tech line to proceed.
They gave me an A4 2.0T 2012, I took it for a long drive. 350km and I'm not even half tank!!! My A4 2009 2.0T i'm EMPTY by 450km. So I called in and told them to check that out as well, that can't be right.
I'll keep you posted on what they do. Right now they are at a loss. No more errors and new alternator. Still under warranty for another year...
#30
YOU ARE AMAZING!!!!
Just now, the dealership called me and they said they found the problem. It was the Ignition Module!!! Woaw!!! How you figured it out without seeing the car and they couldn't for 2 weeks.
You are the man! Thank you Jack.
I'll get the car tomorrow and see if the problem persists.
#31
Please post a scan with the fixes done, would be interesting to see what they actually did.![]()
#32
BAH ABAH ABHA AHHHHHHHHHHH ! LOL!
"I must vvvvvvvvvverify if he is rrrrrright" Vvvvvwhere is the new scan?
My stubborn German intellect is getting einst besssst of me again.
That dam American.
Everyone has seen the angry German kid on Youtube.
I think we are back to the Wizard.
http://www.youtube.com/watch?v=FHFVi...feature=relmfu
Cool, glad it worked out.
#33
Thank you everyone for your help!
Going to get the car tomorrow, I'll post what they did and check that the issues are gone. Hopefully!
Maybe you can help me out with 3 other issues with my car.
1) When it is cold, the transmission seems to have trouble with 3rd gear. It feels like a jerk going into 3rd and it feels like it is slipping when it comes out of 3rd into 4th.
2) Gas consumption. I'm very light on the gas pedal and I barely reach 450km on a full tank.
3) Noise from driver. When I'm going 90km/h + I hear a wind noise from the driver side.
#34
Try recalibrating the DSG basics or request a new trans due to the sporadic error you had which caused potential mechanical damage.
Pump tires up and tune up the heap.
Adjust the doors tighter to hold a better seal. Use plasta gage to determine low spots, or foam glass cleaner with maybe compressed air and look fast at areas of lost surface area during visual inspection.
Good luck!
Or
Ask the WIZARD!
#35
