VWVortex.com - Which MK6 1156 LED DRL's should I purchase?
    Page 3 of 15 FirstFirst 123456713 ... LastLast
    Results 51 to 75 of 372
    Thread: Which MK6 1156 LED DRL's should I purchase?
    1. Member Apk_Joe's Avatar
      May 14th, 2009
      Melbourne, FL
      2012 VW Jetta 2.5 SE
      08-11-2012 02:12 AM #51
      Quote Originally Posted by Fignewton View Post
      I had the 18 SMD LED's that are most popular
      http://www.ebay.com/itm/170757945557...#ht_3017wt_946
      No codes. There were ok, but not as bright as stock. The looked cool, but not really bright enough for DRL's more like Dusk/DawnRL's.
      I just splurged and put these in tonight. They are the 12 Watt Eagle EYE SMT Tower.
      http://autolumination.com/1156_1157.htm
      They are brighter than stock and if I had to put a number on it, 3 or 4 times as bright as the 18 SMD LED's that I had.
      Will have to watch for heat issues. No codes yet.
      One thing I found is that it's damn hard to convey what these actually look like in a photograph.
      The Eagle eyes are bluer than other LED, but not ricey. IMO.
      Another description would be that if I get down on level with the lights, while the glow is consistent throughout the reflector, that forward facing led will spot my eyes.
      I'm going to try to get a pic in full daylight to really show how bright they are.
      when you order are you getting a set of 4 bulbs for the 29$ ?
      Aug 10th, 2003
      cincinnati
      2009 volkswagen jetta tdi
      08-11-2012 06:39 PM #52
      Has anyone tried the autolumination cree 5w bulbs ?
      Wide angle or spotlight , what do you recommend ?
    3. Member grcarlo's Avatar
      Feb 25th, 2010
      2012 VW GLI
      08-11-2012 09:18 PM #53
      Glad to hear some of these LED's are working without throwing any codes, I drive a GLI and I know these to be more sensitive to LED's for whatever reason. I am curious if anybody knows why the DRL's work fine with LED's but they wont work for the license plate?? And is everyone running these without any mods with the vagcom?
    4. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 04:18 PM #54
      Has anyone tried these bulbs from autolumination ?
    5. Member itskohler's Avatar
      Jan 7th, 2011
      Jacksonville, FL/Dallas, TX
      2012 Jetta, 2008 Jetta RIP
      08-12-2012 04:48 PM #55
      No, I don't buy cheap.
    6. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 05:27 PM #56
      Quote Originally Posted by itskohler View Post
      Not cheap they are 30.00 each. 10W Cree led
    7. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 05:40 PM #57
      That half of what I am looking to pay.
      Aug 10th, 2003
      cincinnati
      08-12-2012 06:39 PM #58
      Found these http://www.xtralights.com/super-inte...whitepair.aspx
      37.00 shipped for the pair coupon code hl10
      540 lumens, which is ridiculously bright
    9. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 06:52 PM #59
      Way too bright.
    10. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 07:34 PM #60
      Way too bright.
      Thought bright was the point of replacing the drl with a led ?
    11. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 07:57 PM #61
      Quote Originally Posted by letsmotor View Post
      Not for me, its more about getting a true white out of it.
      Aug 10th, 2003
      cincinnati
      08-12-2012 08:05 PM #62
      Way too bright.
    13. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 08:06 PM #63
    14. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 08:40 PM #64
      Sorry tapa talk messed up, This is a true white bulb it just happens to be brighter than most other led bulbs. All the other ones I've seen have been around 120 lumens at best. Not very bright during the day when the drl are used.
    15. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 08:59 PM #65
      120 is perfect to me. I want the DRls to glow, not project.
    16. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 10:38 PM #66
      All in how the bulb is set up to project the beam. Whether its a wide or spotlight focus. This one looks closest to the eagle eye tower by autolumination at almost half the cost. Most people have had great results with this style bulb from what I've read, just didn't want to spend 60.00 + for two led bulbs. Will post up pictures once I get them installed
    17. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 10:41 PM #67
      Do up a DIY while you're at it.
    18. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 11:35 PM #68
      DIY on how to install the drl bulbs? Just takes some finesse, they come right out 2 minutes tops to install.
    19. Member itskohler's Avatar
      Jan 7th, 2011
      08-12-2012 11:45 PM #69
      I guaranty someone will ask how you did it...
    20. Member
      Aug 10th, 2003
      cincinnati
      08-12-2012 11:46 PM #70
      Haha, Will post step by step w/pictures.
    21. Member
      Aug 10th, 2003
      cincinnati
      08-16-2012 12:25 PM #71
      came in today
    22. Member
      Aug 10th, 2003
      cincinnati
      08-16-2012 01:09 PM #72
      step one unscrew cap
      step two turn counter clockwise to remove DRL
      step three remove old bulb and install new LED ( small hands or long fingers work best to inscrew and take the socket out)
      and your done
    23. Member
      Aug 10th, 2003
      cincinnati
      08-16-2012 01:12 PM #73
      And with them off for comparison
    24. Member
      Aug 10th, 2003
      cincinnati
      08-16-2012 01:32 PM #74
      This was during the day 12:00 with clear sky and sun beaming directly into the housing.
    25. 08-16-2012 01:40 PM #75
      Nice...!!!
      Were they what you expected?
      They look clean... but it seems a little greenish, or maybe that's just the way it in the sunlight.
      Can you let me know if they flicker or code on you? Maybe some pics during later in the day to see the true color of how it lights up during the dawn? lol...
