Results 1 to 5 of 5
Thread: How to take apart rear hatch door covers?
    Mar 4th, 2010
    Winnipeg
    2013 .:R RB
    03-14-2012 10:36 PM #1
    Hey guys, the plastic all around my rear hatch door is starting to come loose and apart and its rattling like crazy.
    I was taking a look but could not quite figure out how the two plastic pieces covering the rear hatch come apart. Has anyone done it? Does anyone know how or has made a guide by chance?
    Thank you!
    2013 R RB - HPA Comp Controller - HPA Red 75A Motor Mount - HPA Short Shifter - 42DD Shifter Bushings - TyrolSport Solid Shifter Bracket Bushings - Carbotech Bobcat 1521 (Daily) - Carbotech XP12/XP8 (Track) - Unibrace UB - Euro Springs
  2. Member Smrtypants44's Avatar
    Jul 30th, 2010
    Norman, OK
    2010 UG 2Dr GTI "Gus"
    03-14-2012 11:44 PM #2
    Look for a DIY on the rearview camera install, they have to take apart the inside of the hatch for that.
    2010 GTI 6MT Autobahn. Mods: H&R Supersport Springs w/H&R Dampeners, APR Stage 1+2 Intake, GIAC Stage 2, BB Turboback Exhaust, Autotech Lower Torque Mount Insert, OEM R20 LED Fogs w/Rear Fog, RLS retrofit, Ebay door sills, Newsouth Boost Gauge, S3 Short Shift w/42DD Solid Shifter Bushings, 19" B8 S4 wheels w/Kuhmo Ecsta LE, Euro Front Lip, Euro Underseat Drawers, Euro Dash Cubby, Euro Door Lights
  3. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    03-15-2012 01:26 AM #3
    I'm feeling helpful tonight
    here's what a 30 sec google search yielded
    Quote Originally Posted by chittychittybangbang
    The rear lid trim panel needs to be removed, remove the two screws hidden in the handles, and them using a trim tool pull off the panel, it's held on with several metal clips is requires a hard pull to remove. Remove the two panels for the rear lights to help see where the metal clips are and to help pull off the panel.
    The red circles show the metal clips, and the green ones show the two screws.
    It's really easy, just take your time and pull firmly
  4. Semi-n00b
    Oct 23rd, 2011
    Altus, OK
    2012 GTI Autobahn United Grey Metallic, 2011 Ford Edge Limited
    03-15-2012 09:18 AM #4
    Yeah, once you remove the two screws from the grab handle areas, you just have to have faith and pull like hell. work one side and then the other. Don't be surprised if one or two of the retaining clips don't pop out, you'll need to remove those with needle nose pliers.
    Mar 4th, 2010
    Winnipeg
    2013 .:R RB
    03-15-2012 11:43 AM #5
    All you sirs are gods!
    Much appreciated!
