Results 1 to 24 of 24
Thread: FS: 2 020 Transmissions: 16v 2Y & 8v AUG Unknown Condition In E. PA
  1. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    03-15-2012 12:16 PM #1
    2Y SOLD! AUG No Longer Available.
    I have one 2Y 16v trans, from a Scirocco, and one Mk2 8v AUG trans available. Both transmissions are in unknown condition. I was told 2nd and 3rd might grind in the 2Y. The AUG feels like it has some differential play. Not sure of any other damage to the AUG. Trans casings are good on both.
    Asking $50 each, picked up in Zionsville, PA 18092. Prefer not shipping, but will at buyers expense.
    I will post pictures upon request.
  2. Member roccodingo's Avatar
    Apr 25th, 2004
    Perth, Australia
    4 x Scirocco 1, 3 x Golf 1, 1 x cabrio 1
    03-19-2012 09:15 AM #2
    Hi Zack,
    PM sent
    cheers,
    Grant
    If it aint a Mk1 then it's a donor....
    Brownrocco resto thread....http://www.vwwatercooled.org.au/f55/...esto-2339.html
    Cabrio repair thread......http://www.vwwatercooled.org.au/f55/...irs-21212.html
  3. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    03-19-2012 10:08 AM #3
    Quote Originally Posted by roccodingo View Post
    Hi Zack,
    PM sent
    cheers,
    Grant
    Thanks Grant, PM replied!
  4. Member roccodingo's Avatar
    Apr 25th, 2004
    Perth, Australia
    03-23-2012 10:45 AM #4
    Paypal sent for 2Y tranny.
    thanks Zach.
    Grant
  5. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    03-23-2012 10:52 AM #5
    thanks Zach.
    Grant
    Thanks Grant!
  6. Member Broke's Avatar
    Aug 13th, 2001
    Columbus, Ohio
    86 GTI 2.0L, 88 Scirocco 16V, 2010 F150 STX
    03-29-2012 02:37 PM #6
    Quote Originally Posted by PunchTheFish View Post
    2Y SOLD!
    Ruddy top notch job packing that AGB, I was well impressed.
    It made it here and felt just as solid as a rock, no trans movement inside the packaging, and that is key.
    Nice heavy corrugate for the outer box, you filled the gaps with stacks of corrugate and all... nice one.
    Not only did you properly bag it for leakage, you double bagged it, and in opposite directions of each other. I noticed
    Anyway, bump for your AUG sale... if you were closer to Columbus, OH I'd snatch it up but at $4/gal. in a F150, I can't do it
    020 trans info pages - www.BrokeVW.com
    NEW 0.7619 5th gears for the 020
    NEW 020 reverse gears
    '86 GTI 8V 2.0L -'88 Scirocco 16V - '10 F150 4x4
  7. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    04-02-2012 02:00 PM #7
    Quote Originally Posted by Broke View Post
    That's great, thank you very much for the compliment! I really appreciate it!
  8. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    05-05-2012 12:38 PM #8
    TTT
    I'm moving, and have a massive inventory of parts I don't want to bring with!
    Mostly Mk1, Mk2, Mk3, Scirocco, B3/B4 Passat, and Porsche 944. Some Mk4, Corrado, and Audi 80/90/4000/5000.
    VERY Short List of What I Have (Many other parts available): http://forums.vwvortex.com/search.ph...d=26881519&pp=
  9. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    05-16-2012 11:34 AM #9
    TTT
  10. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    05-19-2012 10:54 AM #10
    What did the shipped transmission weigh?
    USPS Parcel Post rates: Reasonable - 24x20x20, High: 24x24x24. How big of a box?
    The greedy local self service yard [EDIT: I thought] just increased the transmission price by 150% is why asking.
  11. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    05-19-2012 01:03 PM #11
    Quote Originally Posted by MacGruber View Post
    The greedy local self service yard just increased the transmission price by 150% is why asking.
    Packaged, I believe it weighed 75 lbs. I think it's too heavy to ship with USPS, so I used FedEx Ground. Dimensions were something like 20" x 20" x 18".
  12. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    05-21-2012 10:09 PM #12
    TTT
  13. Member Broke's Avatar
    Aug 13th, 2001
    Columbus, Ohio
    05-24-2012 09:07 PM #13
    75 pounds on the label.
    Box is 14x18x18
    USPS stops at 70lbs, you can't ship a trans USPS, it has to be FedEx or UPS.
  14. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    05-24-2012 09:39 PM #14
    I was wrong about the price increase, the staff now quotes the total price including the core and the 12% in taxes and state fees.
    The transmission for sale, what exactly is the "differential play"?
  15. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    05-25-2012 10:01 AM #15
    Box is 14x18x18
    Excellent, thank you!
    The axle flanges felt wobbly, when turning them. They didn't seem tight, like they should be. Diff bearings maybe?
  16. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    05-26-2012 12:36 AM #16
    I had problems with the flanges after driving with shot motor mounts. And then the driver side output bearing.
    At the threads in the shaft end, try using a long bolt like a starter bolt to check if the shaft moves at all.
    Whoever buys it would probably replace the drive flange seals, right?
  17. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    05-29-2012 12:30 PM #17
    Ahhh yes, good thinking. I'll check for play, and get back to you. Yes, I would imagine the drive flange seals would need to be replaced.
    Edit: Found a good deal of side to side play in the axle flanges, but the diff does not move the entire amount the flanges do. Also found the shaft ends are not threaded, like I'm used to seeing. There is a small hole at the end of each, but it's not threaded.
  18. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    05-31-2012 02:41 PM #18
    That little hole I believe is actually threaded. Used to hold the drive flange compressing the large spring behind it while prying out the retaining clip. Not that much force needed.
    The older drive flanges could end up with a wobble due to spline clearance - no need for larger threads for a tool to press them on. I have replaced mine at least once.
    If the wobble is just from worn drive flanges, that saves 3 pounds of shipping then.
  19. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    06-01-2012 09:02 AM #19
    Oh that could be, I didn't actually check if it was; just noticed it was completely different than the type I was used to. The drive flanges appear to be good. You can actually see the whole diff moving, when moving the flanges.
  20. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    06-01-2012 02:52 PM #20
    My Bentley shows the larger 10mm tap for the VW flange installer. This shows a 1988 16v 9A flange being pulled - actually the large spring behind the flange being compressed so the circlip can be removed.(from bronson75thread)
    This shows the Quaife LSD Differential VW Golf II 8v Fits type 020 gearbox with 109mm ring gear QDF1R ecstuning:
  21. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    06-01-2012 03:22 PM #21
    Now I am not sure if the very small center hole is tapped or not, after reading this from a subdriven post by Broke http://forums.subdriven.com/showthre...diff-or-80-kit:
    Quote Originally Posted by Shaggy View Post
    Is there a way of telling whether an 020 4k transmission has an actual diff as opposed to a 80% limited slip kit without having to tear into it?
    If you remove one axle and look inside the flange, you can see if it has an 80% kit installed. Look for a center cap seal held in with an allen head bolt.
    A 40% can't can't be seen without taking the axle flange off.
    A Quaife can be spotted once the center cap is removed by looking for the non-threaded end of the stub axle. The Peloquin LSD and stock VW diff uses a stub axle with a M10x1.50 threaded hole in the end of it, the Quaife doesn't.
    Other than that, if the trans is installed, you can put one wheel on pavement and one on grass and nail it, if the grassy tire sits and spins it doesn't have a LSD.
    In the air, a LSD will act like an open stock diff, the flanges can be spun opposite directions as there will be no preload to make the diff lock up.
    At the same time some stock VW diffs are tight, some loose, differences in axles and dragging brakes and so on can skew the results, but some will spin both wheels the same direction when spinning one wheel by hand, some spin the other wheel the other direction, etc...
    The grass/pavement test tells you if one wheel slips or not.... but to find out exactly what it inside you pretty much have to start taking things apart.
    Oh, the Wavetrac also uses threaded stub axles...
  22. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    06-02-2012 12:28 PM #22
    Wow, thank you very much for that info. Appears this AUG actually has the Quaife installed!
  23. Member
    Aug 20th, 2010
    Illinois, USA
    1987 Scirocco DLX
    06-10-2012 10:46 PM #23
    Are you selling the AUG transmission with worn output bearings and a Quaife differential for $50 with shipping available?
    As far as I know the only bad effect of the bearing play is the oil seal will leak so its always 1/4" low.
  24. Member PunchTheFish's Avatar
    Sep 8th, 2007
    Emmaus, PA
    06-11-2012 08:56 AM #24
    Sorry, I should have updated this thread. I have disassembled the AUG, and have sold the diff. I appreciate the info you (and others) gave regarding the diff
