#1
i have put a lot of time into it, but nothing to be boasting about.
The engine has:
034 lightweight lifters
complete Headgasket set replaced
new headbolts
034 stainless steel intake manifold bolts
new IM spacer washers
had the valves reseated and new valve guides
good used fuel injectors
uncracked exaust manifold
New plugs and wires
new distributer/cap
painted valve cover
new timing belt job
freshly painted timing belt covers
Bad:
(this part isnt really bad as you could just get the right parts, but i didnt have them at the time.)water return line had to be modified to work as i was missing a fitting for the turbo
K24 Turbo has Shaft play-1mm-ish forward and backwards-1mm-ish side to side-needs a rebuild or parts swapped out from an ugly ass turbo to a nice looking shell!
turbo is polished on the outside and inside on the shiny part-loss of word
Needs:
new alternator
oil pan gasket
comes with:
new K&N oil filter
prepped for sandblasting or powdercoating valve cover
im thinking ill start at what i think is a medium high price- $$$500 obo picked up. Shipping MIGHT be possible. It was a pain in the DI CK to ship the last engine, and the shipping yard was 35 miles away.
i do not have a truck so bring one. I might have some other parts to go with the engine, but ill have to look again.
Plop this bad boy into a VW Quantum to make it TURBO BETTAH!!! or use it as a project engine. Its a great engine, bullet proof and can last for Hundreds of thousands of miles!!! WOuld be a sweet engine to put on VEMS and run on a dune buggy.
stock HP puts this engine at 167 with stock intercooler and K24 turbo
will include ECU and COMPLETE Wiring harness for 250 more-FIRM
my name is stephen
