Results 1 to 21 of 21
Thread: Looking for exterior siding advice.
    Feb 21st, 2002
    Grayson, GA
    87 Gti VRT, 04 E500 Wagon, 04 E55
    03-16-2012 06:21 PM #1
    I am going over a few Siding ideas and need help on deciding which is right for my home. I bought a foreclosure in December and renovated the entire first floor. I have a carpenter bee problem on the exterior and the rotted wood has alot of the bees all over the place since it warmed up. I will match the detached garage with the house. House is built in the late 70's and has flagstone brick on the bottom half of house in the front. My choices I guess are vinyl, aluminum, cedar shingle, seamless steel or clapboard, thanks in advance for your help.
    Rear View of House, can't find a front picture, terrible I know
    Quote Originally Posted by cabzilla View Post
    Throw corrado in trash. Profit.
  2. Senior Member spockcat's Avatar
    Jun 4th, 2003
    07 Z4MC, 11 328i Touring
    03-16-2012 07:08 PM #2
    Quote Originally Posted by v.vdubb View Post
    Not saying it would look good on the house but you didn't mention stucco. Post some good pics of the house and I'm sure there will be plenty of comments.
    After our house fire we switched from vertical cedar siding to board and batten look vinyl siding from Crane. It has a layer of foam insulation backing. We feel the house is more quiet inside and better insulated.
  3. Member Cabby-Blitz's Avatar
    Sep 2nd, 2002
    '03 SVT Lightning
    03-16-2012 11:10 PM #3
    I dislike vinyl and aluminum siding on all houses. I prefer and have used fibercement siding from Certainteed or JamesHardie. Looks good and very durable. You can even get them prepainted from the factory. Not sure how it would look on your more traditional house though. You will want to make sure and not go to far outside the box on what is traditionally used on your house style.
  4. Member
    Feb 21st, 2002
    Grayson, GA
    03-17-2012 11:41 AM #4
    Carpenter bee damage
  5. Senior Member spockcat's Avatar
    Jun 4th, 2003
    03-17-2012 03:07 PM #5
    Looks like a board and batten over stone on the lower half. Kind of a barn-like look going for it. It is quite dark now. How is the roof on the house? I wonder if a change to a lighter color would be help it along with a lighter color on the body of the house (obviously not the stone).
  6. Member GeoffD's Avatar
    Aug 13th, 2001
    03-17-2012 05:46 PM #6
    I think white stucco English Tudor would look really nice on that house. You can use 4x8 fiber-cement stucco panels and save a lot of labor. Impervious to insects.
  7. Member Mk1Racer's Avatar
    Apr 16th, 1999
    NJ
    '99 B5 wagon (RIP), '01 B5.5 wagon, '81 Scirocco, '04 FXDWG
    03-18-2012 09:47 AM #7
    I like that Tudor look, but I'm not sure you have enough space on the house to make it work. If you want to go w/ a clapboard look, I would suggest Hardi-Plank. It comes in several different exposures, can be ordered primed, in one of several stock colors, or custom painted (more expensive and longer lead time). I believe the factory colors carry a lifetime warrant on the finish. Great looking product, impervious to rot and insects, and costs < 1/2 of what cedar clapboard costs.
  8. Moderator silverspeedbuggy's Avatar
    Aug 8th, 2001
    Cleveland Heights OH
    2006 GLI and 1987 Scirocco 16V
    03-19-2012 10:02 AM #8
    If it were me, I'd also get a quote on replacing/repairing the existing siding. I realize it's your house and you can do whatever you want to it, but I think the house is very charming as-is. Covering that siding with plastic or aluminum (or even shake shingles) would reduce the appeal of the home.
    That's just me though.
    Feb 21st, 2002
    Grayson, GA
    03-19-2012 10:31 AM #9
    Quote Originally Posted by silverspeedbuggy View Post
    I was going to do this but those carpenter bees are ruthless, is there a special paint I can use or something to deter them?
  10. 03-19-2012 04:35 PM #10
    x2, i would get all the holes repaired (im sure some rock hard putty would work) and then paint it a brighter lighter color.
    as far as the carpenter bee's a quick google search yielded this.
    http://www.logfinish.com/store/carpe...esolutions.php
    http://www.carpenterbees.com/stain/a...-to-paint.html
    remember wood has been used as siding for eons, vinyl is fairly new and some looks bad very quick. Also i would not change from the vertical grain you have now even if you do get new siding. Lastly FWIW your house probably developed the bee problem from lack of maintinance, make sure its all maintained, and they are fully gone, then do a quality paint job.
  11. Member barry2952's Avatar
    Jun 13th, 2007
    Farmington Hills, MI
    03-19-2012 07:04 PM #11
    Exterminate them and plug the holes. The board and batten look is right for that house.
    However, I don't know that trapping that much biological material behind the wall is such a good idea. You could strip the siding, spray the wall cavities with foam, reinstall as much salvaged lumber as possible and buy new to finish.
    Garmin Is My Pilot.
    Feb 21st, 2002
    Grayson, GA
    03-20-2012 09:02 PM #12
    Most likely what I am going to do, I like the HardiePlank siding but don't know if it would fit this style house. I love the outside apperance, just need to fix some pieces and do a respray. Thanks for all the input guys.
  13. Member barry2952's Avatar
    Jun 13th, 2007
    03-21-2012 12:34 PM #13
    The beauty of board and batten is that you can remove two battens to gain access to the board. You can make removal of the board and battens much easier by drilling the heads off of the nails. The board will come off with little resistance once the heads are gone.
    Read this:
    http://mike-thomson.com/blog/?p=406
    Garmin Is My Pilot.
  14. Member
    Sep 24th, 2003
    Hagerstown, MD
    1999 passat 1.8t, 2001 EV GLS
    03-21-2012 01:22 PM #14
    Check the Hardie website, they have a vertical siding that can be used with their "hardietrim" to make a board & batten. I have a friend who used it on her whole barn. You can get smooth or wood textured. http://www.jameshardie.com/homeowner...panelSiding.py
    just wanted to share what i found. I'm looking at siding replacement in the next 5 years and have been tempted to go with prefinished Hardie, so i noticed the vertical as one of the options.
  15. Member
    Mar 20th, 2002
    Athens, Georgia
    11 Tundra
    03-22-2012 01:14 AM #15
    Quote Originally Posted by 99blackmagic View Post
    I actually have this on my house. You can see it on the left side of this picture:
  16. Member Mk1Racer's Avatar
    Apr 16th, 1999
    NJ
    03-22-2012 11:54 AM #16
    I didn't look at the website, but this doesn't surprise me. They also make a shake product. It's just way more expensive than the plank siding.
  17. 03-29-2012 02:16 PM #17
    I think the siding looks great, as long as you make allowances for the carpenter bees issue.
  18. Member barry2952's Avatar
    Jun 13th, 2007
    03-29-2012 02:19 PM #18
    Interesting first post, Sam. You wouldn't happen to be affiliated with that company, would you?
    There's a word for that.............
    Garmin Is My Pilot.
  19. Member Merc-MarkO's Avatar
    Nov 21st, 2001
    Great State of Oregon
    a '98 [on life support] and a '07
    04-02-2012 10:10 PM #19
    Seeing threads like this and having had issues with the siding on my own house really makes we wish I could have a concrete block built house with pebble dash 'siding'. My parents house is 40yrs old with 0 issues.
    Where is Kyron ??? http://www.bringkyronhome.org/
    Support our troops, bless the fallen.
    Quote Originally Posted by genjy View Post
    Yes, there is a high chance that the tractor trailer was the one going 160MPH, not the Porsche GT2 RS.
  20. Member Karmanniac's Avatar
    Mar 22nd, 2002
    Newark, DE
    2003 1.8 Tango
    04-09-2012 08:09 PM #20
    F**king cedar siding on my parents' house, or rather, the idiots who installed it...spaced it out so they could save as many planks at possible, then when it dried out it left gaps in the laps. Oh, and for the woodpecker that cut a hole in it 30' up in the air? F you too.
    -= DelDubs =-
  21. Member barry2952's Avatar
    Jun 13th, 2007
    04-09-2012 08:34 PM #21
    Speaking of cedar siding, I used factory-painted rough-sawn cedar. No knots.
    We hear a noise in our attic. I put mouse poison up there and it goes untouched. It would be quiet for a day or two and then come back. It was driving our dog and cats nuts. Called critter control. he says we must have a red squirrel. He said if we had one we'd find a golfball-sized whole somewhere in the overhang. I was adamant that I left no gaps and used only clear lumber. As we walked around the house he spotted this. That little bastard had chewed a hole right through my cedar.
    The critter control guy showed me a red squirrel he had trapped alive. Very nasty critters. Very territorial. I was told that if you had other critters in your attic you had them no more. Look at those claws.
    He set two traps, but cautioned me that if the little bugger were trapped outdoors, and it rained, he was so high strung that he would have a heart attack and die.
    Sure enough, it rained that night. I went out and saw his lifeless arm hanging through the trap, blowing in the breeze.
    Garmin Is My Pilot.
