Results 1 to 29 of 29
Thread: SM Arnold Speedy Surface Prep Towel Opinions!
  1. Member .:R Driven's Avatar
    Dec 6th, 2011
    DC-MD-VA
    AE1323 GTI|.:R DRIVEN GOLF
    03-17-2012 12:09 AM #1
    What do you professional detailers think of this new product
    http://www.autodetailingsolutions.ne...l-ssp-589.html
    Edit* Link fixed
    Speedy removal of bonded surface contaminants!
    Leaves surface as smooth as glass.
    Easy to use with less effort - saves time.
    Long lasting, simply rinse and ring out - saves money!
    Speedy Surface Prep Towel works fast and achieves professional results with the advanced polymerized rubber technology, the next generation of surface preparation. Speedy Surface Prep Towel quickly, easily and safely removes paint over-spray, rail dust, brake dust, industrial pollution and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic. Speedy Surface Prep Towel works great with your favorite showroom prep or clay lubricant product. The Speedy Surface Prep Towel is easily cleaned by simply rinsing off the accumulated contaminants with water. If you drop the Speedy Surface Prep Towel on the ground, no worries, just rinse the towel with water and you're ready to keep using it. Plus, the Speedy Surface Prep Towel does not require constant shaping and reshaping. Measures 12" x 12" Aggressive - Recommended for professional use.
    REVO|GOLF R N86710
  2. 03-17-2012 08:46 AM #2
    It's pretty new to the market but there are some positive reviews of it on Autopia. I have one on the way so we'll see. Check out the Auto Scrub as well, looks equally impressive.
  3. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    03-17-2012 10:35 AM #3
    OP your link doesn't work ..
    If it wasn't $60 it might be worth a try ... works out to +$1 per use.
    Is the Lanes spray a must too or will any detail spray work?
    I don't hold a lot of faith in the Autopia reviews any more .. too many band wagon jumpers there.
  4. 03-17-2012 12:57 PM #4
    Quote Originally Posted by Jesstzn View Post
    Definitely have to consider the source when it comes to the reviews!
    I'm sure any detail spray like Last Touch, etc will work fine. This product just looks like a different form of the Magna sponge.
    How did you come up with the 60 uses number?
  5. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    03-17-2012 01:37 PM #5
    Quote Originally Posted by MikeBlaze View Post
    It was on thier site .. gave them the benifit of the doubt ... usually if someone claims a number its pretty optimistic ...
    Actually it was 50 uses .. thus the +$1 per use
    LENGTH OF USE – You can use the Speedy Surface Prep Towel on a MINIMUM of 50 vehicles per towel.
  6. 03-17-2012 01:50 PM #6
    Gotcha..didn't see that.
  7. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    03-17-2012 01:57 PM #7
    Another thing that turned me off of thier products .. I looked at the Touch Up Shine the recommend and they say this
    Your car is dusty and no time to spare. You have two options. You can pull out your traditional water hose, bucket of soap and shop towels just to give your car a sloppy streaky wash or you can receive professional results in half the time with one easy step.
    When you degrade something else to sell your own it stinks.
  8. 04-05-2012 04:32 PM #8
    From all that I have heard it seems to be a great product. I for one will buy one as claying can be a PITA at times. Having to reknead constantly just makes my hands sore and tired. From several reviews already it has been shown that this towel is more efficient at picking up contaminants than clay. Plus, if you drop your $25 clay bar on the ground you have to throw it out, with this you just rinse it.
  9. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-05-2012 05:18 PM #9
    Quote Originally Posted by VW 91 View Post
    Got any links to what you have heard?
  10. 04-05-2012 06:27 PM #10
    http://www.m3post.com/forums/showthread.php?t=665169
    http://www.live2detail.com/showthread.php?t=3267
    Taken from Autopia:
    "I used it on a black maserati the other day that I followed up with menzerna powerfinish. "toweling" the car, my helper was done in only 30 minutes. All the other cars he has done, its been over an hour of claying (some worse than others).
    I tried it out and it cleaned up the windows and the paint in a snap, better than claying! I then moved onto the trunk lid of the maserati and while it did slightly scuff the paint, it was nothing worse than a claybar, and just as easy to remove the instilled defects"
    As far as band wagon jumpers and Autopia, every forum has them. IMO Autopia has the LEAST amount of these type of people. You want band wagoners, head over to Autogeekonline.
  11. Member .:R Driven's Avatar
    Dec 6th, 2011
    DC-MD-VA
    04-05-2012 06:48 PM #11
    I did plan on trying it once my Golf R was delivered. I picked up the car on Tuesday so it's time to order.
    Using Tapatalk
    REVO|GOLF R N86710
  12. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-05-2012 06:49 PM #12
    Taken from Autopia:
    Good info ... ty .. as for the jumpers ... I seldom go there for that reason and the Accumulator .. he has used everything on everything .. 40 times.
  13. Member DieselDubber's Avatar
    Feb 11th, 2011
    Stockton, CA
    2003 Jetta TDI
    04-06-2012 06:51 PM #13
    What I was wondering about this product wa where do the contaminats go? With clay you can fold them into the clay and prevent marring but not on the towel....
  14. 04-06-2012 09:47 PM #14
  15. 04-07-2012 09:33 AM #15
    I got mine a few days ago and have used it on a handful of cars so far. Like most any clay there is a chance for marring the paint with this towel. IMO it is on the more aggressive side but works MUCH easier then any clay bar. The large surface area is probably the biggest plus. As a result it is a huge time saver over clay. I've been using it with Meg's Last Touch w/o issue. I think that after the first use or so it has softened some, we'll see how that carries on. All in all I much prefer it to clay.
  16. 04-13-2012 11:56 AM #16
    Just to update this...I've used the towel on a dozen or so more vehicles. It has definitely softened from the initial use but not to the point that I would want to go straight to wax. I wouldn't go to straight from clay to wax either, ymmv. There are no appreciable signs of wear on the towel aside from the crease where I fold it. So so far a much better option to clay IMO. I'll try to remember to update again after a month or a few dozen more cars.
  17. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-13-2012 11:58 AM #17
    Is it working out as a total substitute for clay?
  18. 04-13-2012 04:24 PM #18
    Sure is. Aside from a very mild clay bar this towel will replace any med to aggressive clay.
  19. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-13-2012 06:57 PM #19
    When you say replaces medium to aggressive .. will it also possibly mar like med. to aggressive clay may?
  20. 04-14-2012 01:16 PM #20
    The first couple of uses I would say looked equal to using Meg's red clay. After that, probably equivalent to a medium clay. I haven't tried it on a clean piece of paint yet to see what marring is left behind...I'll do that soon.
  21. Member .:R Driven's Avatar
    Dec 6th, 2011
    DC-MD-VA
    05-11-2012 02:23 PM #21
    Anyone else try this prep towel ?
    REVO|GOLF R N86710
  22. 05-14-2012 03:00 PM #22
    I've used this towel at on at least a couple dozen more cars since my last post. Marring is next to nothing and it's still in great shape. I don't think i'll use a clay bar again.
  23. Member .:R Driven's Avatar
    Dec 6th, 2011
    DC-MD-VA
    05-15-2012 01:38 AM #23
    Do you think they'll come out with a less aggressive version?
    REVO|GOLF R N86710
  24. 05-15-2012 09:02 AM #24
    Quote Originally Posted by .:R Driven View Post
    I believe it is testing already. There was talk of it on Autopia.
  25. 06-11-2012 08:23 AM #25
    “Nanoskin Surface Prep Towel” http://www.autopia.org/forum/autopia...rep-towel.html
    I understand the mfg are working on a 'milder' less abrasive version. I've found that if you use it on glass initially it helps to prime it.
    The number of times a towel can be used would be dependent upon how much contamination has been removed previously.
    IMO this will replace detailer's clay
    ~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ Blog -TOGWT
  26. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    06-11-2012 09:32 AM #26
    Quote Originally Posted by TOGWT View Post
    In your post over there you listed "pros" .. are there no "cons"? Have you physically used the towel yourself?
  27. Member 2001 VR6's Avatar
    Aug 16th, 2000
    Portland OR
    2001 VR6 Jetta
    06-14-2012 02:38 PM #27
    I have used it, even in hot sun on a black car, temperature readings in the 140. no issues.
    It has replaced clay for me. Just after the first time you use it, you will know.
    Dekany Paint Restoration Portland OR
  28. Member 2001 VR6's Avatar
    Aug 16th, 2000
    Portland OR
    2001 VR6 Jetta
    06-14-2012 02:49 PM #28
    No, it doesn't, but I guess you can make it mar.
    However, one should polish after claying anyway so even if it did, it wouldn't be an issue. Ease of use and durability kills any clay bar.
    remember the last time you clayed in cold temperatures?
  29. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    06-14-2012 03:32 PM #29
    Ty for the reply .. I was more wondering if TOGWT has actually used it.
