VWVortex.com - FS: 1992 SLC with full RECARO interior and lots of new parts. $3,000
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: FS: 1992 SLC with full RECARO interior and lots of new parts. $3,000
    1. Member rochavr6's Avatar
      Jan 19th, 2010
      Las Cruces, NM
      92 Corrado SLC - 93 Canadian Spec Corrado VR6 (sold) - 04 Saab 9-3 ARC
      03-17-2012 02:39 AM #1
      ∙1992 VW Corrado SLC
      ∙Full Recaro Interior Seats work perfectly fine, one switch missing
      ∙Manual Transmission
      ∙Clean Title
      ∙Non-ABS swap
      ∙Lots of NEW parts Well over $2,000 on new OEM and aftermarket parts with less than 2 miles on them and receipts to prove it from MJM Autohaus, 1stVWParts, GermanAutoParts, Neuspeed, ECS Tuning, European Performance Produdcts, and local VW Dealership
      ∙157,XXX miles
      ∙No Rust
      ∙$3,000 Nothing less
      first time it saw the sunlight after sitting for 4 years in the garage. That humming noise comes from the alternator's bearing (which has been replaced) and the lifters were a bit noisy but are back to normal again.
      Hello guys, I'd like to start by giving you a little bit of background about the car. I bought the car at a dealership in El Paso, Texas back in 2003 with around 110k miles. I fell in love with it and paid $4,500. It was my daily driver from 2003 to 2006. In 2005 I had a problem with the car shutting off, after spending around $1200 in new parts (distirbutor, computer, sensors and ignition coil) I finally figured out the problem, the culprit was the ECU relay. In March of 2006 I had a small mishap when I hit a curb at around 30mph, bending the passenger side control arm and CV axle and damaging the bracket that holds the transmission to the mount. I started taking apart the damaged parts in order for the car to be on the streets again but I had a job offer from my uncle in Denver moving there on June of 2006 and leaving the Corrado inside my garage (storage shed) at my mom's house in Las Cruces NM. The car was parked from 6/2006 to 5/2010 when I began doing work on it again. My mom would start the car every once in a while so that the fuel system and engine would still work when I moved back. I started buying all new parts listed below on May of 2010 to start the "restoration". The car has been on restoration since May of 2010 until now and that's why all of the new parts haven't even seen the roads yet.
      The RECARO interior and the euro goodies are out of a 1993 Canadian VR6 that I bought from a friend of mine 2 months ago. The parts listed below that have price on them don't even have more than 2 miles on them. I have receipts for everything listed below.
      Engine
      Oil Pan Gasket: $59.95
      Valve Cover Gasket: $14.95
      Fuel Filter: $12.53
      Distributor: $350.00
      Engine Speed Sensor: $160.00
      Cooling
      Auxiliary Fan Switch: $13.86
      Radiator Auxiliary Cooling Fan: $87.38
      Upper Radiator Hose Flange: $44.95
      Thermostat Housing Kit: $69.95
      Radiator: $199.95
      Radiator Fan Belt: $9.95
      Exterior
      OEM driver's side handle: $132.00
      OEM European Plate Tub: $85.00
      Stubby Antenna
      G60 Bumpers
      90mm Front Lip (cracked)
      Interior
      Full RECARO Interior
      Euro Manual Seat Belts
      Euro OEM Steering Wheel
      Ignition Switch: $47.47
      Brakes
      NON-ABS SWAP
      Non-ABS Bracket: $58.19
      Brake Booster Protective Plate: $36.30
      Neuspeed Front Slotted/Drilled Rotors: $170.90
      OEM Rear Rotors: $90.00
      Hawk Brake Pads (rear): $59.95
      Hawk Brake Pads (front): $75.68
      Steering
      Steering Rack Boots (2): $8.50
      Tie Rod (right): $39.95
      Tie Rod (left): $39.95
      Suspension
      Sway Bar End Links (2) $34.95
      Neuspeed Sway Bar: $229.95
      Ball Joints with Hardware: $39.95
      Control Arms (with TT/R32 bushings): $199.95
      Drivetrain
      Front wheel Bearing Kit (2): $54.95
      Rear Wheel Bearing Kit (2): $39.90
      Front Wheel Hubs (2) $109.90
      CV Axle (right side): $59.99
      CV Axle (left side): $59.99
      Replaced Rear Beam
      Lighting
      E-codes
      E-Code Relayed Harness: $137.49
      VR6 E-Code Lens Right: $71.28
      VR6 E-code Lens Left: $74.75
      Smoked/Red Tails
      French Style Light Bulb Caps
      Wheels / Tires
      17x7.5 Audi TT 6 Spoke Wheels
      Falken ZE-502 205/40r17 $288.00
      The Bad
      Driver's side fender has to be painted.
      Bodywork in the rear has to be finished Nothing bad with it, just decided to shave the emblem and the two joints on each side.
      Hood has a quarter sized spot that needs to be fixed Not rusted.
      No Air Conditioner. Hoses, compressor, condensor, and belt will come with car
      Needs driver's side regulator. Motor is good
      This first picture shows the car how it currently sits, I have the front bumper already painted
      Sep 27th, 2004
      cherry hill nj(philadelphia)
      every car ever
      03-17-2012 10:24 PM #2
      wow. dont know how big the vw/corrado scene is in nm but if you were in the northeast this wouldnt last a week you could easily catch 2000 for those headlights+interior alone.. awesome potential rado right there good luck, man i wouldnt sell if i were you.
    3. Member rochavr6's Avatar
      Jan 19th, 2010
      Las Cruces, NM
      03-18-2012 03:53 AM #3
      Quote Originally Posted by ekul012 View Post
      Thanks for the kind words. I wish I didn't have to sell it, I know I will be losing money here but if I don't get $3,000 for it, I won't let it go.
    4. Member hiimerik's Avatar
      Dec 5th, 2006
      CT
      mk3 rag top B5 avant
      03-18-2012 05:06 PM #4
      yeah if this thing was closer id buy it in a heartbeat
      IMS crew
    5. Junior Member
      Aug 12th, 2010
      Baltimore, MD
      1990 Corrado G60, 93 Corrado SLC
      03-18-2012 05:19 PM #5
      If you were on the east coast, this would be in my garage and not yours.
    6. Member 91JETTAboy's Avatar
      Mar 16th, 2008
      Perkasie PA
      91 jettaGL 8v 87 jettaGLI 16v 90 jetta vr6 85 golf 16v 97 passat vr6 92 gti 8v 95 gti vr6 02 b5 s4
      03-18-2012 08:40 PM #6
      wow such a good deal. goodluck
    7. Junior Member
      Oct 11th, 2009
      1.8t Mk3, 90 G60
      03-18-2012 10:55 PM #7
      FML! I was just in Abq for a month looking for a VW! Now I am in NJ =(
    8. Member CORRADO_JD_19's Avatar
      Sep 22nd, 2007
      Riverside CA.
      92 corrado
      03-19-2012 12:56 AM #8
      I used to live in burque and man I thought I was the only rado owner. Gl with sale
    9. Member rochavr6's Avatar
      Jan 19th, 2010
      Las Cruces, NM
      03-22-2012 10:32 PM #9
      Quote Originally Posted by CORRADO_JD_19 View Post
      If this one goes, there will be only one left in Las Cruces!
    10. 03-23-2012 12:50 AM #10
      Too bad this isnt on the east coast. Beautiful car with amazing interior at a very reasonable price. This is a perfect example of a good owner with some LEGIT history of the car. Not some shady operation that wants an arm and a leg liek we get in the tri state all the time.
    11. Member
      Feb 23rd, 2006
      San Francisco
      mk2, e30+e36 ///M, ap1, duc s2r
      03-23-2012 07:43 PM #11
      interested - loooks awesome. so are all the parts installed or ready to go in?
    12. n00b t16v's Avatar
      Nov 21st, 2011
      highland
      90 corrado 16v 92 corrado g60 93 corrado vr6 91 jetta gli
      04-16-2012 04:19 AM #13
      hay whats up give me your number asap i have cash in hand so e-mail me at wknight67@yahoo.com so i can call you and talk and pick up car thanks
    13. Member wolfievr6's Avatar
      Nov 20th, 2009
      Heber City, UT
      '01 TT 225, JB20TH, '92 CORRADO SLC, '84 GTi Turbo
      04-18-2012 02:36 AM #14
      PM sent
    14. Member vwcorrado1292's Avatar
      May 26th, 2009
      RI
      97 windsor GLX (RIP), 98 black GTI
      04-18-2012 09:58 AM #15
      still have those seat ? want to part with them if you still do ??
    15. 04-18-2012 09:50 PM #16
      If so please contact me at 7177173433805
      Thanks
      Ray
    16. Member wolfievr6's Avatar
      Nov 20th, 2009
      Heber City, UT
      04-19-2012 12:23 AM #17
      Interested, located in El Paso, TX. PM sent again
    17. 04-19-2012 04:49 AM #18
      wow, wish I had the cash.
    18. Member valet's Avatar
      Apr 21st, 2002
      Sacramento, CA
      00 s4, daily, 01 TT - fun car; 11 a4 - grocery getter; 93 f150 - parts hauler, 00 S4 - the project
      04-19-2012 05:02 AM #19
      best of luck to you OP - I would punch all the other posters of this thread in the face to have your recaro interior
      killer of threads
    19. 04-19-2012 05:03 AM #20
      Quote Originally Posted by valet View Post
      I would punch all of the ones asking him to part out...
    20. Member Nick W's Avatar
      Feb 28th, 2007
      Olympia, WA. PNW.
      '86 GLI, '99 Tacoma, '79 XS650
      04-19-2012 05:20 PM #21
      Wish this was closer to the Northwest...
      Der Slam Stücke
    21. 04-25-2012 09:49 AM #22
      Please get in touch with me. Im in Albuquerque and very interested!! Joel @ 505-515-1882
    22. Member 90Carat's Avatar
      Sep 20th, 2005
      Broomfield
      MKIV VR6 GTI and other German stuff
      04-27-2012 11:27 AM #23
      PM sent
    23. Member 240z's Avatar
      Aug 21st, 2009
      San Jose, CA
      1973 Datsun 240z, 1981 DMC-12 DeLorean, '13 Abarth
      04-30-2012 01:10 AM #24
      Sorry, not trying to thread hijack, but I just wanted to commend you on this FS thread. As someone who got burned pretty bad when I bought my Corrado (which I have since parted with) I really appreciate the straight forwardness and your more than fair asking price. I'm out of the Corrado game, probably will be a for a long time, but I wish I could pick something like this up.
      Seriously, this is how a car in this state (don't mean that in a bad way haha) should be sold.
    24. Junior Member
      May 15th, 2011
      Vancouver Canada
      04-30-2012 05:58 AM #25
      hi i am very interested in your car and will pick up asap please msg me back asap ....\
      thanks
