Page 1 of 2 1 2 LastLast
Results 1 to 35 of 49
Thread: Parting my 2001 TT 225's AMU engine and all gas engine related parts
  1. 03-17-2012 06:32 PM #1
    I'm swapping a TDI into my TT and the AMU 1.8T engine must go. Engine had 43k miles, timing belt was redone ~10k ago and was apparently off a hair and I bent ONE exhaust valve at high RPM. Piston is still good, head can be rebuilt with minimal parts. Except for one valve and one piston, all parts are like new. All prices are OBO and do not include shipping or any fees incurred.
    $800 - AMU short block with original cross hatch in cylinders, 43k miles. Ding in a piston, easy fix
    $250 - Disassembled head, needs one valve and maybe a seat recut, maybe not. All positions marked
    $100 - AMU camshafts, like new, each
    $200 - hydraulic tensioner, non-VVT
    $200 - AMU hydraulic lifters, like new
    $50 - valve cover
    GONE - bolt-down ignition coils, each
    $100 - water pump, metal impeller, like new
    $25 - timing belt tensioner and rollers, each
    $100 - Throttle body
    GONE - Diverter Valve
    GONE - fuel rail with pressure regulator
    GONE - crank position sensor
    $50 - cam position sensor
    $50 - knock sensor, each
    GONE - coolant temp sensor, green
    GONE - K04 turbocharger
    $50 - oil and coolant lines, each
    GONE - 225 intake manifold
    GONE - 225 injectors
    GONE - K04 exhaust manifold
    $1500 - FWD 6-speed gearbox (re-gearing my awd box with the guts of a euro FWD TDI box)
    GONE - Factory dual mass flywheel
    GONE - Clutch disc and pressure plate with normal heat spotting
    GONE - non-immobilizer ECU
    $200 - engine wiring harness (small connector)
    $200 - engine wiring harness (big connector)
    $200 - SAI pump
    $50 - kombivalve and hard line
    GONE - plastic hoses to feed SAI pump
    $150 - oil filter/cooler housing
    $150 - in-tank fuel pump
    $150 - EVAP equipment in RF fender
    GONE - Main engine cover
    $100 - Hybrid (steel bottom) oil pan
    GONE - OEM aluminum oil pan
    And lots of assorted valves, hoses, lines, cables, fittings, electronic bits, you name it - if it's not needed to run a diesel, it's good and it's available
    Nov 25th, 2010
    Chicago
    TT ATC
    03-18-2012 01:36 AM #2
    pm'ed on exhaust manifold
  3. 03-19-2012 07:11 AM #3
    Interested in some stuff here! Not trying to knock down your hustle but some of your prices are as much if not more than brand new!
    GL with the sale!
  4. Member speed51133!'s Avatar
    Aug 5th, 2002
    alexandria va/milwaukee wi
    02 audi tt 225 / mk3 jetta /audi 5000s turbo
    03-19-2012 04:58 PM #4
    can i rent your ecu for 1 day?
    i will pay the 200$ as a deposit.
    just charge me 1 day rental.
    will pay shipping and fedex it back asap.
    trying to troubleshoot a problem
  5. 03-19-2012 06:27 PM #5
    You have charge pipe
  6. 03-19-2012 10:08 PM #6
    Thank you for the heads up on my pricing. I know the "all prices are OBO" isn't worth much and the prices might discourage people from even inquiring, but with the exception of one valve, everything is in pretty good shape. 43k miles and garage kept, so unlike a brand new part, these parts are tried and true. Obviously, I don't want anywhere near the price of a new part, but these parts are the closest alternative to buying new. If you're interested in a specific part, PM me.
    Speed, that is an interesting proposition. My concern is that I don't have a working car to test it in, so if you've got a wiring issue that fries ECUs, I'll never know until someone buying my ECU asks me why I sold them a dead one. I'd be happy to help you troubleshoot your problem though - I've studied these wiring diagrams and others pretty extensively, and I've got a lot of history with troubleshooting really tricky problems. PM me or link me to your help thread and I'll see what I can do.
    Evo, I have charge pipe.
    Turbo manifold sold for a big discount, will update original post. Hentai, I'll ship it USPS Priority tomorrow. Truly sorry for the delay.
  7. 03-20-2012 09:57 AM #7
    How much for charge pipe shipped to 11520
  8. Member Audiguy84's Avatar
    Nov 14th, 2006
    messing with Texas
    01 Audi TT roadster, 02 Audi TT coupe
    03-20-2012 02:31 PM #8
    Your in the dfw area, right? I have to do some diagnosis on my car and then i'll get back to you.
  9. 03-20-2012 06:07 PM #9
    Evo, just want to make sure that we mean the same thing by "charge pipe", since there's so much plumbing in that engine. Do you happen to have a picture or a part number I can reference?
  10. 03-22-2012 11:13 AM #10
    A few more things gone, thread updated accordingly. Still waiting on responses. Private messages work better for me. Head and lifters are pending, I think.
  11. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    03-22-2012 07:30 PM #11
    diesel swap your my hero always thought about that
  12. 03-23-2012 11:42 AM #12
    Haha thank ya. It's coming together. Probably going big turbo, big nozzles, 11mm pump, may build block and port head, may run bigger camshaft, not sure yet. Should be interesting for sure.
  13. 03-27-2012 09:32 PM #13
    Are you going to do a write up on your diesel swap? I am interested in doing this as well and would love to follow your progress!
  14. 04-09-2012 01:02 AM #14
    Still tons of stuff left over. Would love to find new homes for the AMU 9:1 short block, the K04-022 turbo, like new camshafts and lifters, a rebuildable head, and TONS of plastic stuff that routinely fails on higher mileage cars. Make an offer, don't be shy.
  15. Member 20v GTI Guy's Avatar
    Aug 20th, 2001
    Jacksonville, FL
    02 TT Quattro gt3076r, 92 Corrado, 93 Corrado, 11 Jetta TDI, 07 Tundra
    04-11-2012 12:25 AM #15
    wherer are you located?
  16. 04-11-2012 03:12 PM #16
    All this time, I thought my location showed up on my posts. I am in Plano, TX - a suburb on the north edge of Dallas.
  17. 04-18-2012 02:43 PM #17
    Still tons of stuff left. Lots of tire kickers, nobody with money or actual desire to buy parts. What's the deal - everyone already spend their tax refunds?
  18. Member speed51133!'s Avatar
    Aug 5th, 2002
    04-18-2012 03:26 PM #18
    price for the charcoal canister and whatever is attached to it please
  19. 04-19-2012 02:18 PM #19
    Speed, I sent you a PM.
  20. Member 20v GTI Guy's Avatar
    Aug 20th, 2001
    Jacksonville, FL
    04-21-2012 02:02 AM #20
    Do you have a way to ship the block?
  21. 04-24-2012 03:56 AM #21
    Worst case, I can stick it on a pallet and ship. Probably wouldn't be too cheap.
    I have charcoal canister removed, along with all Evap equipment.
    Also, just found my SAI pump is bolted together and somehow an upgrade from factory.
    Also, the engine cover bracket that bolts to the front of the intake manifold is of the bolt-down style, not the 1/4 turn fastener style, and is more easily compatible with hardware upgrade/finish kits.
  22. 05-01-2012 09:56 AM #22
    Lots of bits left! Still no takers on block, head, valvetrain, and a lot of hoses and management bits.
  23. Member Tom333's Avatar
    Nov 2nd, 2010
    OC CA
    2010 VW CC R-Line, 2010 MB C300, 2002 Audi TTQ 225
    05-01-2012 03:52 PM #23
    need the T-piece rubber hose.
    shipped to 92870
    pls pm me ty!
  24. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-04-2012 12:52 AM #24
    im looking for a bare block (no pistons or rods or crank) w/ oilfilter housing and oilpan. $500 shipped, pm if interested
  25. 05-08-2012 10:50 AM #25
    If you are not dead-set on an AMU block, I have a buddy with a bare 06A block sitting in his garage. Are you open to going oversized pistons?
  26. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-08-2012 12:08 PM #26
    im going stroker, any 06a is fine but prefer amu
    2001 Audi TT Quattro 225 - 1400 watt kicker sound system, dynamatted, foamed frame, carpet jute adhesion, duralined trunk - APR stage 1, TIP, TFSI coils, WG spring mod, EVO9 DV, Tru-Boost, UEGO.
    Theres never an eternal gratification when it comes to making your car faster.
  27. Member Mantvis's Avatar
    Jan 1st, 2010
    Chicago, IL
    2001 Audi TT 225hp, 2003 Audi TT 180hp
    05-08-2012 02:51 PM #27
    Need all the parts to do auto to manual FWD swap.
    What would be the price?
    btw shipped to 60564
    2001 225Q (Function Car): APR Stage 3+, APR 3' Exhaust System, Brembo Brakes, Koni Suspension
    2003 180 (Form Car): Rokkor Coilovers,Custom Front Single Frame Bumper with A8 Grill Votex Sideskirts, Votex Rearlip, Axis Penta 19' Wheels, 2 Rockford Fosgate 15' Subwoofers
  28. 05-08-2012 06:34 PM #28
    I haven't ordered the FWD box from RyanP yet, but what I'd do is order the TDI gearbox, axles, starter, clutch hydraulics, wire bits, brackets, pedals, clutch, and flywheel from RyanP over in England and then disassemble the FWD TDI box and swap my TT's guts into it and the TDI guts into my AWD box, and then sell the whole swap kit. RyanP wants 1400GBP for the swap, so I'd need somewhere around that to cover my costs.
  29. 05-08-2012 06:35 PM #29
    by the way, Jedge, do you need a TDI crankshaft for your 2.1 build?
  30. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-08-2012 06:45 PM #30
    yes but not for awhile, i wont be able to have access to a crank straightener for some time, however i might try to go 10:1 compression because i hope to switch to E85 sometime down the road.
  31. 05-09-2012 11:10 AM #31
    Tom, sending that hose today. Thanks, and let me know if you need anything else!
  32. 05-12-2012 11:32 PM #32
    Took some crappy pictures to give an idea of what's left:
  33. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-13-2012 02:05 AM #33
    did you give up on shipping the AMU to 95765?
  34. Member Tom333's Avatar
    Nov 2nd, 2010
    OC CA
    05-13-2012 03:36 AM #34
    Thanks!
    Pm sent
  35. 05-14-2012 08:22 PM #35
    Sorry for delay, Jedge. I actually found a guy who wants the rods and pistons, so maybe I'll make the crank into a lamp like my other one and sell you the block. Depends on what he's willing to pay for the rods and pistons. What are they worth - any idea?
