Page 2 of 2 FirstFirst 1 2
Results 36 to 42 of 42
Thread: RacingBrake 330mm 4-piston caliper + rotor kit - installed - initial review / impressions
    Aug 8th, 2011
    PDX
    MKV R32
    04-30-2012 05:18 PM #36
    I'm not sure I like all the DIY fixes to get things right
    Unless I'm forgetting something, the only thing that was not "right" or that I had to DIY fix so far is the shape of the back plate on a set of non-RB pads. I'll contact RB about it and report back (maybe I got the wrong pads or maybe they are not aware and might be willing/able to modify their design or....???).
  2. Member Slave IV's Avatar
    Nov 15th, 2010
    B5 S4, MkV R32, W203 C240, W123 300D Turbo, W210 E320 4Matic
    04-30-2012 05:25 PM #37
    Cool.
    If your gas cap light comes on even if you think you tightened the cap, try pulling on the cap as you tighten it. Worked for me.
    Help us with suspension specs!
    Vag Evolution: MkI Rabbit -> MkII 16v GTI -> B5 S4/MkV .:R32
  3. Member nkgneto's Avatar
    Dec 4th, 2004
    West Burbs, IL
    04 VW R32 TRed, 05 Jetta Wagon Blk/Orange
    04-30-2012 05:33 PM #38
    Their pad design. They designed a caliper that uses the 06-08 STi or 300zx pads.
    So you can order pads from those cars and it will be a direct fit/no mod needed.
    Opti-Coat applications in the Chicago Area! * United Motorsport Flashing in the Chicago Area *
    Quote Originally Posted by webcrawlr View Post
    Luis has been the most responsive person I've dealt with in the VW world. There's a lot of big name shops that could learn a lot from his customer service skills.
    Quote Originally Posted by Polz View Post
    All of the above four points. Plus I have received great service from Jeff and from Luis at Automobile Day Spa.
  4. Member
    Aug 8th, 2011
    PDX
    MKV R32
    04-30-2012 05:51 PM #39
    Luis, is it supposed to be STi pads? Coz the website just says "wrx" so I think I got regular wrx pads (I'm not even sure if they are different but will look them up later). Must... stop... forum-ing and get... back....to........ work (need more $$$ for more modz )
    Aug 8th, 2011
    PDX
    MKV R32
    04-30-2012 06:42 PM #40
    Couldn't resist - had to look it up. The 06-08 WRX pads are same for standard / STi variants - or at least the EBC PNs are the same: DP41200R
    I sent an email to RB while I was at it. OK - back to work now....
  6. Member nkgneto's Avatar
    Dec 4th, 2004
    West Burbs, IL
    04-30-2012 06:53 PM #41
    Quote Originally Posted by motrrrpsycho View Post
    I emailed them also to double check. I was thinking the same thing ^ but wanted to be certain.
    Aug 8th, 2011
    PDX
    MKV R32
    04-30-2012 10:07 PM #42
    I got a reply from Warren noting that the RB pads comply to the standard FMSI shape D647 and he reference this pic:
    So... I guess even though the EBC PN DP41200R is the pad they list for both WRX and 300ZX, it does not fit the "standard" shape. Oh well. I guess if you buy this kit, this is just one thing to keep in mind - that you need pads that look like the above or need to be willing and able to dremel / hacksaw the front tab and front corners off a bit to make them fit. I found a site that has pics of the pads I got (though I did not buy from them - got through amazon for about 30 bucks less and free shipping).
