Results 1 to 6 of 6
Thread: 87 cabby stall right after starting
  1. Junior Member
    Jan 8th, 2012
    1987 VW Cabriolet 8V
    03-18-2012 06:57 PM #1
    It starts and then stalls out almost immediately after starting.
    it'll fire up on the second or third try usually, but sometimes
    will want to die unless I give it gas for a few seconds. So far
    I've put on some new ngk plugs, new ignition wires, distributor cap
    and rotor. Does this sound like an ignition or a fuel problem?
  2. Member iamdagerman's Avatar
    Feb 18th, 2006
    ga
    1 70 bug, 2 71 supers,89 Cabby, 72 Ghia (FS)
    03-18-2012 09:57 PM #2
    does the fuel pump prime when you turn key to acc?
  3. Member ToplessBunny85's Avatar
    Jan 6th, 2009
    Whitby
    The Laffnstalk
    03-18-2012 10:09 PM #3
    Sounds like a vacuum problem. I forgot to tighten up my intake hose after replacing my air filter once and the car did exactly that; started, then immediately stalled. If you have a propane torch handy, open the valve (but don't light it! ) and get someone to go over all the vacuum lines while you try to start the car. If it stays running, wherever your propane is aimed, that's your culprit.
    Doing it right is overrated.
    Quote Originally Posted by builtvw View Post
    girls + vw = hot....vw girl from canada...daaaaammmmn
    Volks R Us
  4. 03-18-2012 10:56 PM #4
    I always like to check ignition timing first. Then move on to vaccum.
  5. Junior Member
    Jan 8th, 2012
    03-19-2012 02:04 PM #5
    I will check this things right away. I'm rather novice with these cars. haha
    Funny that you mentioned that toplessbunny! I just changed my air filter maybe a week ago..
  6. Junior Member
    Jan 8th, 2012
    03-20-2012 01:54 AM #6
    So my cabriolet diesels occasionally after turning the car off. According to Bentley, this could be due to incorrect ignition timing. Fingers crossed I can knock these two issues with one stone. I've never tinkered with ignition timing before. Cabby-info's DIYs are a godsend though!
    my 87 Cabriolet is actually the first car I've worked on myself before. Gotta admit, every little thing I do to this car is sort of a rush. Good feeling. I'm 22, but I'm eager to learn and I love my car! Sorry, end of rant. Hah
