Results 1 to 2 of 2
Thread: fuel pump help
  1. 03-19-2012 09:36 PM #1
    hi i have a 92 cabriolet and the fuel pump has a loud noise and after a 30 min drive it sounds diferent and also it has a gasoline smell inside the car would that be my inside tank pump dying. and after i turn the car off and on it sounds normally again .
  2. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    03-19-2012 10:24 PM #2
    That is a good sign that your in-tank pump has failed and is straining your Primary Pump.
    How to change it:
    There there is a get rid of your Dual pumps and go single...which is a hell of a lot cheaper, but a tad noisier.
    http://reflectionsandshadows.com/sin...mp-conversion/
    My additions to make it even cheaper and my trick...
    http://www.the152.com/modules.php?na...ight=fuel+pump
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
