Results 1 to 33 of 33
Thread: FS: Built Corrado 16v turbo - OH
  1. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    03-19-2012 09:44 PM #1
    CAR IS SOLD
    ~12k miles on this build
    Everything is top quality - no expense spared
    Always Garaged
    Very reliable – drove to SOWO twice
    Handles amazingly
    Pulls hard and quickly
    Engine:
    - 1.8 Scirocco 16v Block
    - .5mm Overbored
    - O-Ringed block
    - JE Forged Pistons
    - 9:1 Compression Ratio
    - Shot Peened and Stress Relieved Rods
    - ARP rod and main bolts
    - Completely balanced rotating assembly
    - 1.8 Scirocco 16v head
    - Zero Decked
    - Hot Tanked
    - Mild porting
    - Autotech valve springs
    - 3 Angle Valve Job
    - ARP Head Studs
    - Autotech Adjustable Cam Sprocket
    - Perma-cool oil cooler
    - Chromed Bosch alternator
    - AC deleted
    - BBM solid front engine mount
    - VF poly trans mount
    - Custom O34 spark plug leads
    -Brand new Denso Iridium plugs
    - Custom modified Audi 5 cylinder intake manifold (professionally polished)
    - VR6 throttle body (professionally polished)
    - All wires run through frame rail with quick disconnect in fender area.
    Turbo Components:
    - ATP Manifold
    - Turbonetics T3/T4 Hybrid Turbo
    - Turbonetics Deltagate with Custom Tubes – 38mm
    - TurboXS Manual Boost Controller
    - Spearco air/water intercooler mounted on custom powder coated bracket
    - Custom made fiberglass intercooler reservoir mounted in spare tire well
    - Jabsco intercooler water pump
    - Perma-cool intercooler radiator
    - HKS Super Sequential Blow-off Valve
    - Zeitronix data-logging wide-band o2.
    - Custom 2.5" Downpipe - wrapped
    - Techtonics 2.5'' Cat Back Exhuast – dual resonators with Borla muffler
    - Deleted Cat
    -SS electronic 2.5” exhaust cut-out w/ wireless remote
    Fuel System:
    - Electromotive Tec2 full stand-alone
    - Custom polished Fuel Rail
    - Aeromotive Billet Adjustable FPR with Fuel Pressure gauge
    - Custom Braided Stainless Fuel Lines
    - 440cc RC engineering Fuel Injectors
    - Walbro 255lph high Flow Fuel Pump – in tank
    Drivetrain:
    - Low mileage 02A trans
    - ARP bolt kit
    - South Bend stage 3 clutch
    - Lightened factory flywheel
    - CV joints repacked with redline grease and new boots
    -B&M short throw shifter
    Suspension:
    - Koni coilovers
    - VR6 front upper strut mounts
    - H&R rear sway bar
    - Eurosport rear upper stress bar
    - Poly front control arm bushings
    - Poly rear strut mounts
    - Poly front sway bar bushings
    Brakes:
    - Slotted rotors front and rear
    - Mintex pads front and rear
    - Braided stainless brake lines
    -System converted to non-ABS
    - Girling calipers re-built
    -new Ebrake cables
    Exterior (8.5/10):
    - Front side markers shaved and bumper re-painted
    - Front core support re-painted
    - Euro chin spoiler
    - Badgeless VR6 grille
    - Euro headlights with relay kit – joey modded
    - Euro turn signal lenses
    -Cult Society Air ducts
    -Kamei grille spoiler
    - In-pro smoked M3 style tails
    - New side mirror glass
    -Rear wiper delete
    Interior (9.5/10):
    -Very clean red dot interior
    - Sparco steering wheel with hub
    - TT pedal covers
    - Votex shift knob
    -mk4 leather Ebrake handle
    - Autometer coolant temp, oil temp, and oil pressure gauges mounted in custom modified Audi 4000 gauge cluster
    - Greddy turbo timer
    - Alpine I-pod controlling CD deck
    - MB quart component speakers
    - Autopower roll bar – painted to match wheels
    - Custom carpet covered rear floor
    - Braille battery (brand new), maintainer, and AC converter mounted under false floor.
    -Passat glass moonroof
    -Military style battery cut-off switch
    -Gruvenparts hood release cable clip
    Wheels:
    -16x7.5” Mercedes C-class wheels completely refinished/polished/painted w/ new chrome caps
    -Motorsport-Tech custom adapters and hardware – 30mm F / 38mm R
    -195/40/16 Yokohama S-drives – 90%
    The Bad:
    - Very small rust spot on right rear fender and by hatch glass. I have a rust free hatch that I can include in the sale. The body is otherwise an 8.5/10. There are a couple very small dings. Hardly noticeable. The front bumper and hood have some normal marks due to tiny road debris.
    - The odometer doesn’t work. Never bothered me enough to get a replacement.
    - The compression is slightly lower on cylinder four. I did a compression test recently and came up with the following:
    #1 120psi
    #2 125
    #3 125
    #4 95
    This is Exactly the same readings as when I did the test 2 years ago. The PO did some troubleshooting before me. He dropped some oil in cylinder four and re-tested compression. When he did this the compression jumped up to nearly 140psi. I’m sure if you were to re-ring it, you would see even more power. The readings never got worse and the car pulls hard, so I never bothered with it yet.
    - Battery has a very slow drain. The battery cut off switch is there for when it sits for extended periods.
    -Sunroof tilts fine, but doesn’t slide without issues
    -Could use a better tune to realize the full potential of this set-up. Spoke with John Grossman of Grossman Tuning about this since he has the same Tec2 standalone on his Rabbit. Again, this is just being completely honest if someone wanted a perfect car. It runs great as is.
    Photobucket: http://s37.photobucket.com/albums/e7...orrado%2016vT/
    Windows Live: https://skydrive.live.com/redir.aspx...PpAspxi5SeE%24
    Corrado 16vT SOLD
    BMW 135i stage 2
    e30 350is sbf v8 <-------go kart
    e30 325i calypsorot Vert daily FOR SALE
    '61 Cadillac DeVille project
  2. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    03-20-2012 08:02 PM #2
    Sick car!
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  3. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    03-21-2012 04:08 PM #3
    thanks^
    and pm's replied to
    Corrado 16vT SOLD
    BMW 135i stage 2
  4. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    03-26-2012 03:42 PM #4
    pm replied bump
    Corrado 16vT SOLD
    BMW 135i stage 2
  5. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    04-04-2012 11:44 AM #5
    pm returned
    Corrado 16vT SOLD
    BMW 135i stage 2
  6. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    04-10-2012 11:19 AM #6
    Corrado 16vT SOLD
    BMW 135i stage 2
    Aug 12th, 2011
    Rust belt , Pennsyltucky
    Hemi Jeep , GMT400 Suburban , '87 Scirocco 16v(sold),'07 Rabbit(sold)
    04-11-2012 12:01 AM #7
    Nice ride , too rich for my wallet ,but well worth the $$.
    I have to tell you that's the best use of those wheels I have ever seen!
    beautiful car though. GLWS!
    Thredkilla supreme
  8. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    04-13-2012 09:59 AM #8
    Quote Originally Posted by DUBSfightinRUST View Post
    thank you sir, wheels took weeks to finish lol
    Corrado 16vT SOLD
    BMW 135i stage 2
  9. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    05-01-2012 11:16 AM #9
    MOST RECENT UPDATE Picking up a very low mileage 02a tranny soon!
    Corrado 16vT SOLD
    BMW 135i stage 2
  10. Member TurboGliMK4's Avatar
    Aug 26th, 2009
    08873 NJ
    MK6 CSG GTI : ) R.I.P 2004.5 BMP GLI
    05-01-2012 11:26 AM #10
    gorgeousss. free bump.
  11. 05-02-2012 02:15 PM #11
    Such a beautiful car, good luck with the sale dude
  12. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    05-08-2012 10:12 AM #12
    Quote Originally Posted by TurboGliMK4 View Post
    Quote Originally Posted by Turksdub View Post
    Thanks, now someone needs to buy it
    Corrado 16vT SOLD
    BMW 135i stage 2
  13. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    05-22-2012 09:29 AM #13
    Bump
    Corrado 16vT SOLD
    BMW 135i stage 2
  14. Member coatofarms's Avatar
    Dec 27th, 2006
    Valdosta, Ga
    1990 G60, 2007 GTI Cone Killer, 1989 E30 2dr
    05-23-2012 07:21 AM #14
    Saw this car at sowo last year, loved it!!! GLWS
    \\\DateNavis///
    DIY: O2M OEM+ Short Throw http://forums.vwvortex.com/showthrea...6#post79056376
  15. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    05-23-2012 09:41 PM #15
    Quote Originally Posted by coatofarms View Post
    thank u sir
    Corrado 16vT SOLD
    BMW 135i stage 2
  16. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    05-25-2012 03:51 PM #16
    picked the new tranny up last night
    Corrado 16vT SOLD
    BMW 135i stage 2
  17. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    05-29-2012 11:19 AM #17
    New tranny in! Fresh fluid and zero noises, smooth as butta
    Corrado 16vT SOLD
    BMW 135i stage 2
  18. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    06-07-2012 09:51 AM #18
    New pics in OP
    Corrado 16vT SOLD
    BMW 135i stage 2
  19. Member BmoreDubs's Avatar
    Aug 25th, 2009
    Baltimore/NYC
    90G60T, 83E24, B61.8T, 91Golf1.8, 95Jetta2.0, 89Golf1.8
    06-14-2012 10:47 PM #19
    Soo fresh & clean clean! Some1 buy something other then VR.. Long live 16v's!
    America... just a nation of two hundred million used car salesmen.
    -Hunter S. Thompson
    www.believebaltimore.com
  20. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    06-28-2012 03:54 PM #20
    Quote Originally Posted by BmoreDubs View Post
    yes sir!
    lots of recent interest but no moneys bump
    Corrado 16vT SOLD
    BMW 135i stage 2
  21. Junior Member kahoe5a4's Avatar
    Jan 11th, 2009
    91 VW Corrado
    07-05-2012 01:07 PM #21
    anyone who comments negatively on this is a retard.
  22. Member Enraged007's Avatar
    Apr 29th, 2009
    Hawaii
    1990 G60 Corrado
    07-05-2012 06:05 PM #22
    ^^ agreed JK! Very sick car, great job!
  23. Member .FUDD.'s Avatar
    Aug 14th, 2008
    noVA
    Aba Corrado, k4 GSXR 1000, Fit Van Homan
    07-06-2012 09:33 AM #23
    Wont help you consolidate, But I have to offer, Im in northern Ohio and have a 2004 Gsxr1000, and a 1999 wolfsburg jetta with tasteful Oem parts and vmaxx coilovers. Pm if interested
  24. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    07-06-2012 09:45 AM #24
    Quote Originally Posted by kahoe5a4 View Post
    Quote Originally Posted by Enraged007 View Post
    Quote Originally Posted by .FUDD. View Post
    thanks for the offer, but I need the space and that makes my problem worse lol. sell them and get back to me
    Corrado 16vT SOLD
    BMW 135i stage 2
  25. Member
    Sep 28th, 2010
    raleigh nc
    96 mk3 golf
    07-16-2012 09:21 PM #25
    are you interested in trade for black forest industries jetta coupe i own the car
  26. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    07-17-2012 12:58 PM #26
    Quote Originally Posted by desamk3 View Post
    love that car, but I'd rather have the cash. thanks for the offer
    Corrado 16vT SOLD
    BMW 135i stage 2
  27. Member vwgli_04's Avatar
    Sep 4th, 2007
    Cincinnati
    2004 VW Jetta GLI-BMP-SOLD, 2006 B6 Passat 2.0T, 1984 4-Door Rabbit, 74 Super Beetle
    07-19-2012 08:06 AM #27
    bump.
    513
    "Sorry my life is so much more bitchin’ than yours. I planned it that way."
  28. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    07-24-2012 05:21 PM #28
    Corrado 16vT SOLD
    BMW 135i stage 2
  29. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    08-01-2012 10:34 AM #29
    Lowered to $7800 now. If it doesn't sell soon, I'm going to consider parting it
    Corrado 16vT SOLD
    BMW 135i stage 2
  30. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    08-06-2012 04:33 PM #30
    7799
    Corrado 16vT SOLD
    BMW 135i stage 2
  31. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    08-10-2012 10:20 AM #31
    deposit taken
    Corrado 16vT SOLD
    BMW 135i stage 2
  32. 08-10-2012 02:05 PM #32
    u have working A/C
    I'll come and get it ..
  33. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    08-14-2012 12:45 PM #33
    CAR IS SOLD
    Corrado 16vT SOLD
    BMW 135i stage 2
