VWVortex.com - Hard Wire Smoke and Carbon Monoxide Detector
    Results 1 to 9 of 9
    Thread: Hard Wire Smoke and Carbon Monoxide Detector
    1. 03-20-2012 01:16 PM #1
      My house has about 12 hard wired smoke detectors. I just completed a inspection, where I am now required to add in four carbon monoxide detectors. Instead of doubling up the devices at some locations, can I just replace the smoke with the carbon/smoke units?
      Will this cause any issues with the wiring?
      Can anyone recommend any affordable options?
      May 27th, 2008
      Malvern, PA
      2015 GMC Sierra, 1998 TJ 5.3L/465/Atlas, 1996 F250
      03-20-2012 01:21 PM #2
      Yep.
      It should be a 3 wire system + ground.
      If it's newer construction, it'll be a black/white/red.
      Black is hot, white is neutral, red is the signal between them.
      First thing I would look for is the same brand as your smokes, they may be plug & play...
    3. 03-20-2012 01:23 PM #3
      It is 2 year old construction,and is white/black/red
    4. Member
      May 27th, 2008
      Malvern, PA
      03-20-2012 01:34 PM #4
      Quote Originally Posted by atchudy View Post
      Just make sure you turn of the breaker before doing any work on that circuit.
    5. Member barry2952's Avatar
      Jun 13th, 2007
      Farmington Hills, MI
      03-21-2012 01:41 PM #5
      I have 11 in my house, but I would not replace a smoke detector with a carbon monoxide detector as they have different functions.
      Since Carbon Monoxide mixes evenly in the air, unlike smoke, you can use plug-in models or tap into an un-switched outlet. I believe you should keep your CO detectors so that they don't interconnect. That way you might be able to tell where the CO might be coming from.
      I just replaced all of my smoke detectors. It's now recommended that you replace them all after 10 years. I replaced mine with a model that has a Lithium battery for back-up that should last 10 years. That's a hell of a lot better than trying to figure out which SD had the low battery.
    6. Member Shamrock's Avatar
      Aug 6th, 2004
      Harrisburg, PA
      03-21-2012 04:14 PM #6
      get a decent one, and they have different tones for different things I think. I do know that CO's have a LED # on them so only one should have changed from 0
    7. Senior Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      03-21-2012 04:26 PM #7
      We just replace the 9v batteries in our SDs once a year- my wife has it on her calendar. Ours are hard-wired btw.
    8. Member barry2952's Avatar
      Jun 13th, 2007
      03-22-2012 05:49 PM #8
      This thread reminded me to buy a plug-in CO detector today.
      Nov 10th, 2002
      NJ
      03-24-2012 07:07 PM #9
      I have combo units in my house. They work great, they tell you why each is going off. They also blink to tell you which one triggered the alarm so you know which one to waste your time pressing the button to shut the damn things up.
      Current: 2015 RPGM Chevy SS Sedan 6spd - 2000 Chevy K2500 - 2013 Honda Odyssey TE
      Past: 2011 JSW TDi 6spd @100k - 2006 Honda Accord Sedan V6 6spd @170k - 04 VW Passat W8 6spd Wagon @123k - 1996 Mazda Miata 5spd Base @257k - 2003 Jetta GLI 24v 6spd @74k - 1993 Jeep Grand Cherokee V8 @303k - 1991 Honda Accord LX 5spd @151k - 1993 Toyota Corolla 5spd Base @154k
