Results 1 to 21 of 21
Thread: Rear Hatch Rattle!?
    Jan 16th, 2011
    South FL
    2001 TT 225, 1998 GTi VR6
    03-21-2012 12:37 PM #1
    Noticed it today for the first time... distinct sound coming from the rear hatch.
    It sounds like it's actually the glass A constant rattle that increases with and decreases with the road vibrations. I touched the plastic panel on the hatch while driving(yes I can lol) and it affected the noise, so it's def there.
    Anyone have something similar? Solutions? I'd like to take that hatch panel off and see if the insulation is bad or something. Maybe wedge some foam in there to stop the noise?
    Im up for ideas. Thanks
    "Opinions on car forums are just like assh0les... everyone's got one"
  2. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    03-21-2012 01:00 PM #2
    little pieces of trash bags
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
    Jan 16th, 2011
    South FL
    03-21-2012 02:00 PM #3
    thanks Played
    So just stuff them in? Or would pulling out the panel be better?
    Anyone know how to get that panel off? Im at work and cant check the bentley(if it's in there?).
  4. Member PLAYED TT's Avatar
    Oct 17th, 2010
    03-21-2012 04:20 PM #4
    The parcel cover has one clip on each side. Unhook it and pull it towards the front of the car. I used vinyl electrical tape on the two tabs and cut up small pieces of trash bag to stick between the side clips
    Nov 10th, 2009
    San Antonio, TX
    2000 Audi 180Q Aviator Gray
    03-21-2012 06:04 PM #5
    If you dont ever want to get rid of it, you could probably use some gorilla glue. If you dont want the parcel cover at all, I'll take it
    Sex should be like a Civic; slow, obscene, and loud enough for the neighbors to hear.
  6. Member
    Jan 16th, 2011
    South FL
    03-22-2012 09:45 AM #6
    When you say Parcel, are your referring to the trunk shelf? bc that's not what Im talking about
    The rattle is coming from the actual hatch. I looked into after parking last night and it's def the hatch lid. The plastic molding that goes over the glass on the inside is loose on the passenger side. As the car moves, it vibrates and knocks on the actual glass. Which is also why it's so freaking loud
    I think I may just stuff some cotton or garbage bag snips as suggested.hoping that would take care of it without the need to remove the whole panel. Ill snap some pics when I do it
  7. Junior Member
    Nov 16th, 2011
    San Francisco, CA
    '02 TT 180qc
    03-22-2012 11:25 AM #7
    Thanks for the tip Played. I get this same noise and it drives me ****ing insane. Only remedy is windows down + volume up. Then you can't even hear yourself think
  8. Member PLAYED TT's Avatar
    Oct 17th, 2010
    03-22-2012 12:15 PM #8
    Yeah I thought you were talking about something different then
  9. Member Senater_Cache's Avatar
    Dec 27th, 2007
    MB FL
    396 TT QC
    03-22-2012 04:57 PM #9
    I have the same problem, well kinda, same area, horrendous noise.
    I have touched the plastic trim around the hatch's inside, and it may be something INSIDE the trim...
    Let me know how it goes with the "stuffing"
  10. 03-22-2012 06:10 PM #10
    I also have the same damn problem and the noise kills me!!!! I'm going to take your advice and see if the trash bag thing works. **crossing fingers**
  11. Member ttwsm's Avatar
    Feb 27th, 2011
    Minneapolis
    2005 TT 225Q
    03-22-2012 08:50 PM #11
    I think I may have *just started* getting that same noise in the past few weeks. Question for the others who have the noise - do you use the handle inside the hatch, on the passenger side, to close the hatch? I always do, but now I'm wondering if that eventually loosens things up. It feels like it's just attached by a plastic rivet to the panel - think maybe the stress gets transmitted straight to the part that's squeaking.
  12. Senior Member idwurks's Avatar
    Oct 25th, 2003
    Hill Valley Skyway
    Time Machine
    03-23-2012 11:42 AM #12
    It's the plastic interior trim which is around the glass. I think it just ages with UV exposure and years and becomes brittle. I've been thinking about replacing mine or wrapping it in leather or material.
    Has anyone successfully removed this without breaking it?
    Hella4 | GermanPlates | ADstudio Custom Banner Ads | Audi TT Bild | Need Retargeting or Display Advertising?
  13. Senior Member idwurks's Avatar
    Oct 25th, 2003
    Hill Valley Skyway
    Time Machine
    09-25-2012 11:43 AM #13
    Quote Originally Posted by Downtown-Turbo View Post
    I'm ripping the rear glass plastic trim off now before I go insane. I will update the thread with pics. I don't care if something breaks: Good excuse to buy a new trim panel and start getting rid of that grey plastic
    Be careful - the plastic can be old and brittle.
    Some good ideas are:
    SecondSkin Sound Dampening
    Felt
  14. Junior Member mikegtimx's Avatar
    Apr 5th, 2011
    chihuahua/Mexico
    2001 vw gti 1.8t 2000 TT Coupe
    09-25-2012 01:17 PM #14
    TG i thought i was alone on this one y have the same problem o that trim, most ot the time its because of bass vibrations even in a low volume waiting for some pics of some one fixing it
    2003 GTI 1.8T R
    2000 TT 180 Coupe
  15. Junior Member mikegtimx's Avatar
    Apr 5th, 2011
    chihuahua/Mexico
    10-02-2012 12:17 PM #15
    updates?
    2003 GTI 1.8T R
    2000 TT 180 Coupe
  16. 10-02-2012 09:37 PM #16
    I used to have that. First ripped out that stupid luggage cover, second screwed the rubber stoppers on the trunk lid out about 1/2 inch, never rattled since
    Audi TT ownership is like having a pet. It needs attention and if it doesn't get it, it will S%*@ all over your life.
  17. Senior Member idwurks's Avatar
    Oct 25th, 2003
    Hill Valley Skyway
    Time Machine
    10-03-2012 01:41 PM #17
    Quote Originally Posted by toy4two2 View Post
    Yah I need to lower mine, so the trunk sits tighter. What year is your car and how did you archieve that? It seems like a bit of a bitch to adjust.
  18. 10-03-2012 11:51 PM #18
    Quote Originally Posted by idwurks View Post
    nonsense. In my 2002 just grab the end of the rubber stoppers and spin like a bolt You'll see how easy they are to adjust.
  19. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    '78,81S,TTQ,S2 8V, race Corvette
    10-05-2012 06:46 PM #19
    Funny how this was the first 'DEFECT' to come up when I was doing searches 7 years ago before I bought my car and....sure enough... there it was.....maddening isn't it!
    UV and all that falderall really doesn't come into play here in that my car sits in a climate controled garage and has had about 20 hours of sun on the car....and super low miles.
    So what I did; Take a putty knife and GENTLY pry the panel away from the hatch about 1/8th inch.
    Then I slid 1/8" x 2"long by .75 wide, black neoprene foam (dense) under until JUST the edge of the foam was peaking out under the plastic trim panel. I repeated this procedure in 5 places two on each side and one near the back latch.
    KOO-EYE-ETT NOW!
    The feeling of immortality extends right up until the moment of impact.
    I cannot teach you how to be a Zen mechanic, grasshopper.
    The VW Scirocco, the worlds fastest ECONOMY car.
  20. 10-06-2012 03:17 PM #20
    In my experience the squeaking comes from the metal clips that hold that plastic window surrounding to the actual hatch. The little push clips are pushed into the metal slots where they make metal on metal contact (the squeaking sound). You can tell when you pull it down, because you can see the wear marks on clips where it's been rubbing/squeaking. My remedy was to wrap the little clips with some fabric before putting it back together. Work out fine
    04 225QC Black/F23/IE Rods/Gonzo StageIII/E85/Bosch EV14 750cc/LiquidTT/Podi/AEM dry flow/Forge WG/MadMAxDV/Forge hoses/Treadstone TR8/42 Catch can/42 DP/Magnaflow Cat back/Eibach coilovers/Neuspeed RSB /KMAC/Defcons & poly/25mm & 17mm/RS4 Reps/ Brembo Calipers/ Zimmerman rotors/Hawk pads/Braided lines/B&M shifter/Votex body/Suede/Carbon/shaved..
  21. Member ttwsm's Avatar
    Feb 27th, 2011
    Minneapolis
    2005 TT 225Q
    10-18-2012 08:48 PM #21
    Anyone with a 2005 - do they still adjust in this way? Mine sure don't want to turn. At all. I would like to adjust mine, but don't want to break anything...
