    Page 1 of 2 12 LastLast
    Results 1 to 35 of 41
    Thread: :: ModBargains :: EuroJet :: Stage II+ Power Kit :: Are You READY?
    1. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      1721 E. Lambert Rd #C, La Habra, CA 90631
      Audi A3, 996TT, 135i, 335i, 370z, G37, 540i, AE86, ETC.
      03-21-2012 07:11 PM #1
      Do you want to make the more hp out of your engine? Do you want up to 50+whp for your GTI? If you answer yes to any of the questions, I have a solution for you! ModBargains is proudly to present Eurojet Power upgrade kit Stage 2+ to the VW community.
      Call in right now for the best deal on the Eurojet Stage 2+ Kit !!! Give me a call at 714--582-3330 ext 8011 , and ask fo Eddie for the lowest pricing!!
      Eurojet V-Banded Turbo back Exhaust
      Benefit
      • Exhaust flow increased by 40%
      • High-grade T304 stainless steel finish
      • 3" diameter tubing
      • Reduced weight by 20% vs stock
      • 0,065" Thick walls reduces noise going to the cabin
      • Custom Eurojet ID tag
      • Three 02 sensor bungs
      • internal expansion joints and superior sounds absorbing material to creat 40%pass through, up from 30% in previous generation systems, and a clean European exhaust sound
      • Lifetime guarantee from material or manufacturer's defects
      Eurojet Cold Air Intake System
      Benefit
      • Noticeable performance gains
      • Mandrel-bent, powdercoated, aircraft-grade aluminum
      • Air filter designed with integrated velocity stack
      • Places air filter away from hot engine bay
      • CNC machined MAF flange
      • 5-ply silicone elbows made to OEM specs
      • Easy to install
      Eurojet Front Mount Intercooler
      Benefit
      • 23.5" x 2" x 16.5" Intercooler core size
      • Tested to perform beyond 600hp
      • TIG-welded end tanks
      • Compatible with OEM throttle body and turbo discharge sections
      • T5052 & 6061 Aluminum
      • Holds within 2-5 degrees of ambient temperatures
      Eurojet Front Mount Intercooler for MK5/MK6 GTI vs S3 Intercooler
      Typical S3 intercooler upgrades are designed for the power and boost level of the Audi S3 with the K04 turbo that's only rated for the 240 to 290hp range. Essentially, this means that the S3 intercooler is not an efficient upgrade for your MK5 or MK6 VW GTI since the S3 intercooler is meant to work at OEM levels with OEM software. With the Audi S3 heatsoak will start to be apparent around the 300hp level. However, the Eurojet Front Mount Intercooler was specifically designed and tested with the power you want to add to your MK5 or MK6 GTI in mind. The Eurojet intercooler has been tested at power levels that exceed 600hp without evidence of heatsoak. The endtank design of the Eurojet Front Mount Intercooler ensures that the whole intercooler core is being used efficiently.
      Concern? Questions? Or price quote? Feel free to contact Eddie at 714-582-3330 ext 8011 ! !
      Best Regards,
      Eddie@ModBargains.com
      Sales | Sales@ModBargains.com | (714) 582-3330
      We Specialize In: VW Parts | VW Wheels | ST Suspension | KW Suspension
      Hours: Monday - Friday 8:00am-6:00pm Saturday 8:00am-5:00pm (PST) ModBargains Blog
    2. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      03-22-2012 07:50 PM #2
      all pm's and emails replied
    3. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      03-26-2012 01:59 PM #3
      Happy Monday
    4. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      03-29-2012 03:01 PM #4
      Pm's replied
    5. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      04-03-2012 04:30 PM #5
      bump
    6. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      04-09-2012 12:36 PM #6
      Happy Monday
    7. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      04-16-2012 01:15 PM #7
      all pm's replied
    8. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      04-18-2012 01:28 PM #8
      Bump
    9. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      04-24-2012 02:38 PM #9
      happy tuesday
    10. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      04-30-2012 01:12 PM #10
      Happy Monday
      Check out our Blog !!
    11. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      05-04-2012 06:49 PM #11
      Tgif bump
    12. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      05-07-2012 01:34 PM #12
      It'ssssssss MONDAYYYYYYYYYYY
    13. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      05-17-2012 02:47 PM #13
      bump
    14. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      05-21-2012 01:24 PM #14
      PMs replied
      -Eddie
    15. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      05-26-2012 12:21 PM #15
      Call me now!!! Happy long weekenddd
    16. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      06-04-2012 08:52 PM #16
      bump
    17. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      06-15-2012 07:20 PM #17
      TGIF !! Lets celebrate Friday by buying new goodies for your vw
    18. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      06-19-2012 03:42 PM #18
      BUMP
    19. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      06-22-2012 08:01 PM #19
      TGIF , All pm's replied
    20. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      06-26-2012 08:59 PM #20
      Bump for Tuesday!
    21. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      06-30-2012 03:07 PM #21
      weekend bump
    22. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-02-2012 08:26 PM #22
      Monday Bump
    23. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-05-2012 06:22 PM #23
      all pm replied. Thank you
    24. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-10-2012 01:37 PM #24
      all items shipped out!! thanks
    25. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-13-2012 05:30 PM #25
      Happy Friday
    26. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-19-2012 01:22 PM #26
      Bump for Thursday!!
    27. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-21-2012 08:32 PM #27
      Questions? Feel free to give me a call 718-582-3330 ext 8011 or email me at Eddie@modbargains.com
      -Eddie
    28. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-25-2012 12:43 PM #28
      -Eddie
    29. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      07-30-2012 06:33 PM #29
      -Eddie
    30. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      08-06-2012 07:41 PM #30
      Bump for Monday
    31. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      08-24-2012 04:04 PM #31
      TGIF!! Feel free to email me if you guys have any questions! have a safe weekend!!
      -Eddie
    32. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      08-28-2012 08:14 PM #32
      -Eddie
    33. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      09-05-2012 01:33 PM #33
      Extended LABOR DAY SPECIAL!! PM ME FOR SPECIAL ! ENDING THIS FRIDAY !! HURRY DON"T MISS OUT
    34. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      09-21-2012 10:23 PM #34
      TGIF , All pm replied and We are open on Saturday, feel free to call me at 714-582-3330 ext 8011 ask for Eddie
    35. Banner Advertiser ModBargains.com's Avatar
      Jan 26th, 2012
      10-02-2012 02:27 PM #35
      Congratulations to all the Bears Fans!
      On October 2nd - October 5th the Entire State of Illinois Gets FREE SHIPPING
      If your State has Won this Weeks Monday Night Football Game Please
      Enter Coupon Code "FootBall1"
      Exceptions apply to certain large items such as body kits. Please call in for further details of discounts (714) 582-3330
    Tags for this Thread
