Results 1 to 4 of 4
Thread: engine starving for fuel at high RPM
  1. Junior Member roscoe crawford's Avatar
    May 8th, 2011
    nampa, idaho. usa
    1989 cabby,1993 passat
    03-21-2012 07:03 PM #1
    i have a 89 cabby 1.8 cis only mods is on throttle body from digi II and a cold air intake. when car is cool runs awesome when warm and accerlerate to 5000 rpm car will stutter and then catch up. fuel pump humms intermittingly new pre-pump. all injecters are new, motor has 1200 miles on her, its driving me crazy. any help would be awesome. thanks
    vwslamman
  2. Junior Member
    Feb 5th, 2012
    Snohomish, WA
    88 Mk2 GTI
    04-16-2012 11:24 PM #2
    Get a fuel enrichment box worked great for me techtonics or autotech 8 different settings
    Aug 14th, 2005
    Germany
    04-17-2012 12:56 PM #3
    Quote Originally Posted by roscoe crawford View Post
    Hope the switches on the throttle body were transfered over somehow. 89 should already have had the larger throttle body, no? Any how, you could be looking at a few things. Main pump going bad, fuel filter getting clogged, control pressure regulator going bad or even ignition problems but it would be just guessing at this point. With CIS the first thing one should do is a complete fuel pressure test as the system relies about 100% on the fuel pressure to function correctly.
    Quote Originally Posted by TCW View Post
    That device is for CIS-e and not CIS with Lambda control.
    Mar 31st, 2008
    PNW - Oregon
    04-18-2012 03:21 PM #4
    i would check that the fuel filter is not clogged before i go any further..
