I'm so excited to share that I've received a misfire message on my way back down from Atlanta this past weekend. I was passing on the highway when I got a flashing CEL that went to solid, I pulled up the code via my laptop since I had it with me and this is what I got. Since the car was running fine and I cleared the code and waited to see if it happened again. It did not come back immediately, however I discovered exactly how to trigger it. It would only happen at higher RPMs [around 5k rpms] and only if I held it there for about 10 seconds. So if I would accelerate and run up to 6k or so and shift it would not happen. If I held it there for the 10-15 seconds it would start flashing. If I let off the throttle it would flash for a few moments then turn off.
I've ALREADY replaced ALL SIX Coilpacks today with brand new units, and it has not solved my issue.
I'm now concerned with a bad injector. Maybe spark plugs? (Now ruled out) The plugs were replaced at 60k miles [I'm currently at 80k]. I feel like it was a mileage triggered bomb because I hit 80k on the way up to Atlanta this weekend, lol.
Edit (3/22/12): I've since swapped spark plugs from bank 1 to bank 2 and the problem persists on cylinders 4/5/6 only. I examined the ignition wires as best as I could for any damage/breaks/shorts to no avail.
This is the code I pulled from Saturday evening.
Code:
Address 01: Engine Labels: None
Part No SW: 022 906 032 KU HW: 022 906 032 GP
Component: R32-DQ-LEV2 G UM10
Revision: 1QH02--- Serial number: VWX7Z0G83NA8U9
Coding: 0000178
Shop #: WSC 13363 539 411206
VCID: 68F98BCF5B68FA3
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 129039 km
Time Indication: 0
Date: 2000.00.00
Time: 15:43:09
Freeze Frame:
RPM: 4886 /min
Load: 38.0 %
Speed: 121.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129039 km
Time Indication: 0
Date: 2000.00.00
Time: 15:43:09
Freeze Frame:
RPM: 4886 /min
Load: 38.0 %
Speed: 121.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 13.843 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129039 km
Time Indication: 0
Date: 2000.00.00
Time: 15:43:09
Freeze Frame:
RPM: 4886 /min
Load: 38.0 %
Speed: 121.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 002 - Misfire Detected
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 129040 km
Time Indication: 0
Date: 2000.00.00
Time: 15:43:30
Freeze Frame:
RPM: 4092 /min
Load: 85.8 %
Speed: 76.0 km/h
Temperature: 94.0°C
Temperature: 33.0°C
Voltage: 13.589 V
Readiness: 0000 0000
This is from today.
Code:
Wednesday,21,March,2012,19:43:00:53428
VCDS Version: Release 11.11.2 (x64)
Sexy Shawns' Speed Shop
Control Module Part Number: 022 906 032 KU HW: 022 906 032 GP
Component and/or Version: R32-DQ-LEV2 G UM10
Software Coding: 0000178
Work Shop Code: WSC 13363 539 411206
2 Faults Found:
P0300 - 001 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129679 km
Time Indication: 0
Date: 2000.00.00
Time: 19:03:42
Freeze Frame:
RPM: 5689 /min
Load: 58.8 %
Speed: 140.0 km/h
Temperature: 90.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
000774 - Cylinder 6
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129679 km
Time Indication: 0
Date: 2000.00.00
Time: 19:03:42
Freeze Frame:
RPM: 5689 /min
Load: 58.8 %
Speed: 140.0 km/h
Temperature: 90.0°C
Temperature: 27.0°C
Voltage: 13.716 V
Newst code from today...
Code:
Wednesday,21,March,2012,20:12:22:53428
4 Faults Found:
P0300 - 001 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129703 km
Time Indication: 0
Date: 2000.00.00
Time: 20:04:35
Freeze Frame:
RPM: 3809 /min
Load: 25.1 %
Speed: 94.0 km/h
Temperature: 90.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129703 km
Time Indication: 0
Date: 2000.00.00
Time: 20:04:35
Freeze Frame:
RPM: 3809 /min
Load: 25.1 %
Speed: 94.0 km/h
Temperature: 90.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129703 km
Time Indication: 0
Date: 2000.00.00
Time: 20:04:35
Freeze Frame:
RPM: 3809 /min
Load: 25.1 %
Speed: 94.0 km/h
Temperature: 90.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000774 - Cylinder 6
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 129703 km
Time Indication: 0
Date: 2000.00.00
Time: 20:04:52
Freeze Frame:
RPM: 5338 /min
Load: 47.8 %
Speed: 132.0 km/h
Temperature: 91.0°C
Temperature: 27.0°C
Voltage: 13.716 V
https://www.youtube.com/watch?v=7Phyp1uhfuU
https://www.youtube.com/watch?v=YCQHoUPS4co
Any thoughts gentlemen?
