It is for the upshift light on the console.
#1
There apparently were two wires leading into this thing. It was clearly a hack wiring job at one time that didn't stand the test of time. I asked my mechanic friend what it was and he said it doesn't seem to be effecting the car so who cares.
By the_passenger at 2012-03-21
#2
Grounds, Grounds, Grounds Replace them things.
Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
Where are my grounds ?
#3
On my car it is located on the vacuum line just off the dizzy, not sure why yours is way up there.
#5
I didn't realize there was a shift light on this car. Man I really want to hook this up so I can be told I'm not shifting right all the time.
I guess it might be better if I pulled it off and capped the vacuum line properly. Or I could just leave it.
#6
#7
#8
#9
I Agree. That is part number 171919825B.
Interrupts cold-running enrichment above idle on the (CIS) 1988-1989. Called the "cold-running enrichment vacuum switch". The one end is suppose to have that cap on it.
See Kammy's site;
http://www.cabby-info.com/electrical.htm
Regards, jjz
JJZ
1988 VW Cabriolet, 2003 BMW Z4 Dinan, 2003 Toyota Highlander, 1995 Saturn SL2
In order of driving preference...........................
jzinkel@lumc.edu
#10
Thanks I figured it wasn't the shift light thing, since this car doesn't have one. This could explain why it is difficult start every odd day or so.
