VWVortex.com - Mk4 Gli cant figure out front end clunk?
    Results 1 to 15 of 15
    Thread: Mk4 Gli cant figure out front end clunk?
    1. Junior Member
      Dec 6th, 2011
      Maine
      2003 VW Jetta Gli Vr6
      03-22-2012 08:46 AM #1
      Hows it going guys I got an 2003 gli. I have had this pretty loud clunk when going over bumps at a slow speed or cutting my wheel hard when backing up. It sounds like it is coming from the drivers side. I have brought it to 2 different places and no one can seem to figure out what it is. I replaced sway bar bushings and just replaced the control and bushings and upper strut mounts...any ideas what this could be?
    2. Junior Member
      Aug 21st, 2011
      Texas
      2001 Jetta Wolfsburg/1970 Fastback
      04-01-2012 03:26 PM #2
      Same problem with mine. I went and changed out the strut bearings and struts and still have the problem. It's as if something is binding and then breaking free, pisses me off. If you figure it out post it!
    3. Member twin2626's Avatar
      May 11th, 2006
      Niagara falls
      2006 Jetta GLI
      04-01-2012 11:08 PM #3
      if you've already changed your control arm bushings and sway bar bushings, then the only thing left is the ball joint.
      Jan 20th, 2000
      Arlington, VA
      1992 SLC, 2003 GLI, 2015 GLI
      04-01-2012 11:37 PM #4
      Join the club. Bought my '03 GLI new and I started hearing the clunk at around 10k. The dealer and several independent shops have been unable to find anything.
      If you search around, you will see a ton of folks with similar symptoms. Yet another annoying characteristic of the Mk4.
    5. Member stephen9666's Avatar
      Nov 14th, 2009
      Three boring ones, but they all have manuéls
      04-02-2012 12:23 AM #5
      To the OP-
      When you say you replaced the "sway bar bushings," do you mean the bushings in the sway bar links or the mounts on the body?
      My girlfriend's Beetle had a clunk that took a lot of work to find. I replaced the strut mounts, control arm bushings and rear axle bushings. It turned out the clunk was coming from the sway bar bushings where the bar mounts to the body.
      A couple other things to check:
      -subframe bolts, to see if any are loose or broken
      -ball joints
      Do you know how to check things like ball joints? It varies by vehicle design, but I believe on this car you can use a pry bar to see if you can get the joint to move.
    6. Junior Member
      Dec 6th, 2011
      Maine
      04-03-2012 01:48 PM #6
      I checked the ball joints. Only thing I can think of is the actual struts? They were replaced like a year and a half ago so I don't think they would already be bad I avoid all the potholes I can.
    7. 04-09-2012 09:37 PM #7
      I've been having the same issue also... i figure that it could only be the bushing on the sway bar or sway bar links.... if it so... What are some of best places to purchase these items online....
      Mar 27th, 2005
      nyc
      13 GLI Autobahn
      04-10-2012 10:17 AM #8
      Another clunk source are your inner tie rods. I had an annoying clunk a while back. Would happen rolling slowly over bumps and when turning the wheel. I couldnt figure it out. I noticed when the car was parked and i rocked the steering wheel back and forth, it would clunk. My left inner tie rod ran out of grease in the ball joint and was the culprit. This is the last place i wouldve ever thought to look.
    9. Member FigureFive's Avatar
      Dec 21st, 2003
      Nashville, TN
      MkIV R32 (R.I.P), E36 M3 Sedan
      04-10-2012 11:14 AM #9
      CV joint is another possibility. My clunk required a new axle.
    10. Junior Member
      Aug 21st, 2011
      Texas
      08-24-2013 07:59 PM #10
      I figured mine out. It was the LCA rear bushing. I took the LCA off and went to a shop where he pressed out the old and set the new ones for FREE. No more clunk.
    11. Semi-n00b
      Aug 21st, 2013
      Westchester, NY
      08 2.5 Jetta
      09-05-2013 01:36 PM #11
      im having the same problem, i switched my suspension with WRD coilovers and used 034motorsports mounts. turns out the upper strut mounts are allowing the coilovers to move up and down while going over bumps. we checked to make sure everything was tightened and the problem still remains. its driving me crazy ive had my front coilovers removed at least 4 times this week now.
    12. Member G_Lader_91's Avatar
      Dec 27th, 2006
      Abu Dhabi, U.A.E.
      80 Rocco, 90 Rado, 03 Sierra, 09 Seat Leon Cupra
      09-14-2013 09:02 AM #12
      OP,
      My 03 Gli had literally everything you can replace in the suspension done...minus axles. I still had the came clunk you are describing. It was mainly when while turning on a bumpy surface, or going over a decent bump, that would present an audible "clunk". My car was lowered on bilstein sports/neuspeed springs.
      Fast forward a few months from replacing everything, I purchased new axles (went with raxles) and sure as heck, no more clunking. Sucks that the 24v is so freaking expensive for parts imo, great engine, just everything around it falls apart, :mk4problems
      Megasquirt 3 Pro || Tuner studio nerd || Instagram: nathan_corrado_20vt
      My Corrado Build :http://forums.vwvortex.com/showthrea...-1990-0007-G60
      My Mk1 Rocco progress: http://forums.vwvortex.com/showthrea...1#post87739861
    13. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      09-23-2013 02:03 AM #13
      These are all great suggestions.
      The things I check in order are:
      Sway Bar end links (disconnect them to see if it goes away before replacing)
      Ball Joints & Tie Rods
      Control arm bushings
      Also, check out the sub frame bolts to make sure they are all tight.
      Thanks,
      Glen @ AMI
      eurocollective
      sales@eurocollective.com
      Toll Free 1 (888) 362-3117
      BB Exhausts - FK - KW - Magnaflow - Solo Werks - ST - Wagner Tuning & more
      www.eurocollective.com - Contact us for a personalized quote!
    14. Member
      Mar 2nd, 2002
      San Jose, CA
      2002 GTI 1.8T Tip (previous), 2004 GTI 1.8T 5MT (for sale), 2012 Ford Escape V6 AWD (current)
      09-23-2013 02:20 PM #14
      Everyone else has come up with a pretty thorough list...one more thought: The captured nut inside the subframe that receives the front LCA bushing bolts are notorious for becoming un-captured when the tack weld fails. Could be something that went and is rattling around?
      Original owner, Aristos w/ Michelin PSS. TT Short Shift, Hawk HPS, ECS SS lines, 034Motorsport StreetLine Engine/Trans Mounts, H&R OE Sports w/ STR.Ts, R32 rear LCA & BFI Poly-Graphite front LCA bushings, TyrolSport solid subframe & steering rack mounts, Powerflex street front strut mounts, Raxles, TT front rotors & 11" rear rotors, APR TIP
    15. Member Doctor Meat Does Housecalls's Avatar
      Aug 27th, 2010
      Boston
      Bagged emkay6 Jetta 1.8T on stock rimz, emkay2 Wolfsburg Coupe without a rear seat.
      10-21-2013 12:01 PM #15
      Still having this issue after the ENTIRE front end has been replaced. No matter what level the air ride is set at. Its aggrivating the **** out of me.
      IlleststanceGangBang2011|DoctorMeatDoesHousecalls|EnthusiastExchange|WTH:VolkswagenGF2011Survivor|YourPriusIsNotGreen|Instagram
      Quote Originally Posted by MurryEB View Post
      Doctor Meat is doing a housecall right now
