Results 1 to 5 of 5
Thread: Need help with relay numbers on my S2 conversion
    May 5th, 2006
    Wilton NH
    91 corrado tdi/ 2000 A4TQ Avant sportline/94 cummins 5 speed 4x4(haul'n cool cars to rallies)
    03-22-2012 11:45 AM #1
    Hey everybody, there was little activity in the 200 forum so I thought I would place the question here. I am about to try and start my S2 converted 91 CQ. It has a 3B from a 91 200 TQ. The red taped engine harness has a spot for 2 multi-plug relays side by side. If anybody has those numbers for the relays that would be great. I have tons of relays but I don't want to put the wrong ones in that might fry the ecu.
    Oct 2nd, 2004
    CT
    200 20v 90q 20v
    03-25-2012 08:52 PM #2
    The one with the brown socket is for the afterrun relay/control unit which is also brown. The black one isn't used for anything.
    May 5th, 2006
    Wilton NH
    03-25-2012 10:27 PM #3
    thanks man , is the over run relay for the coolant recirculating pump for the turbo?
  4. Member
    Oct 2nd, 2004
    CT
    200 20v 90q 20v
    03-25-2012 10:41 PM #4
    Yes the afterrun relay controls the after run fan and electric H20 pump triggered by the two pin coolant sensor on the h20 manifold.
    May 5th, 2006
    Wilton NH
    03-25-2012 10:58 PM #5
    thanks man, I'm too used to building rally cars this street stuff is not my usual forte'
